HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 26, 2019 at 6:19 AM
    #2201
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    :frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty::frusty:
  2. Apr 26, 2019 at 6:23 AM
    #2202
    Lthompson
    Lthompson Well-Known Member
    Just unhook the wire under the seat. It’s a two wire normally closed circuit. Seat senses weight with the circuit closed and turns the light on. Plugging the belt in breaks the circuit and turns it off. Basically it’s thinking it’s always buckled
    Murphinator likes this.
  3. Apr 26, 2019 at 6:28 AM
    #2203
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    @BillDaCat8 spend hundreds of dollars to get rid of rev hang? Although annoying there is much more to be gained here sir! FOCUS! Get it, tune it, go smoke tires! :burnrubber:
    BassAckwards, Roostfactor and Torspd like this.
  4. Apr 26, 2019 at 6:33 AM
    #2204
    Lthompson
    I’ve already forgot most of what I read in the beginning of this. Too much to keep up with
    Roostfactor and JuanitoBonito like this.
  5. Apr 26, 2019 at 6:36 AM
    #2205
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Oh, I’m definitely interested in all the other goodies too. Believe me. But even if my truck was not modified a bit, I would still buy this thing just to get rid of that rev-hang. It makes it miserable to drive. I love everything else about the truck. This is my one big complaint. None of my other stick shift cars do this shit. It drives me nuts. If I ever get my hands on the fucking dude that invented that shit it’s going to be ugly.
    Roostfactor, JustDSM, Norton and 3 others like this.
  6. Apr 26, 2019 at 6:37 AM
    #2206
    Hacktacular
    Robert
    :rofl::rofl::rofl:
  7. Apr 26, 2019 at 6:54 AM
    #2207
    ThomasMore66
    Dallas/Fort Worth & Durango
    Ok. It didn’t work. I was sad.
    loginfailed likes this.
  8. Apr 26, 2019 at 6:58 AM
    #2208
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    If anyone has a Bully Dog tuner laying around, it can do it.
  9. Apr 26, 2019 at 7:00 AM
    #2209
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :laugh:
  10. Apr 26, 2019 at 7:11 AM
    #2210
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    Ok, got loaded up with @JustDSM stock tune this morning. I haven’t conferred with him since, so he will be reading this with everyone else lol. Initial impression is positive. I haven’t had a ton of seat time since the flash but overall drivability seems improved. I don’t think there are big gains to be made without bolt ons, but the power seems more linear than before. I’ve never had a pedal commander or the like so I can’t compare to that. The place I think most of the improvements happen are 2.5-4K WOT, seems to pull harder there than before (perfect for highway passing). I will be hitting the rollers on the 9th and we will see if it’s all in my head. Would I buy it again, I’d say yes. I’ll be driving more over the next few days and update. After I get on the dyno to get baselines the bolt ons will start. I’ve always run 93 octane when available so I feel like I’m getting my money’s worth now :rofl:
  11. Apr 26, 2019 at 7:35 AM
    #2211
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Really?? So there is a reason for me to open the $500 box sitting in my closet for my carb sticker? Interesting..
  12. Apr 26, 2019 at 7:40 AM
    #2212
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    YES please post some stock and baseline tune numbers, that would be insanely awesome!!! Good to hear positive reviews of the baseline tune, my HPT comes in today, but wont be able to pull the cal till monday to get it over to JustDSM to have him sprinkle magic on it. *cry*
  13. Apr 26, 2019 at 7:41 AM
    #2213
    DiamondW
    Kent
    Gonzales Co. TX
    Already got my time booked. I was hoping to get it in sooner but that was the best they could do.
  14. Apr 26, 2019 at 7:49 AM
    #2214
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Yep, I turned my chime off with the Bully Dog back when I first installed the supercharger.
  15. Apr 26, 2019 at 7:58 AM
    #2215
    Sacrifice
    KS
    DCSB OR 4X4 LT
    So when are we shipping it around? Lol
  16. Apr 26, 2019 at 8:00 AM
    #2216
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'd be concerned that it would affect the airbag system. It operates different if your seatbelts isnt fastened.
  17. Apr 26, 2019 at 8:12 AM
    #2217
    Lthompson
    It thinks it is fastened. It’s a two wire plug. To me it’s It’s the only way it can work to affect the light and alarm There’s a weight sensor. And a seatbelt plug. Break the circuit it thinks it’s plugged in
  18. Apr 26, 2019 at 8:18 AM
    #2218
    Lthompson
    Could test it by jumping the plug and seeing if the alarm comes on.. then remove jumper and alarm and light go off.
  19. Apr 26, 2019 at 8:18 AM
    #2219
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I would, but I threw it in the trash a good while ago. Bully Dog and I have a history.
  20. Apr 26, 2019 at 8:20 AM
    #2220
    nd4spdbh
    SoCal
    Do it the right way, easy to do on the 12+'s with a techstream cable or have the dealer do it for free.
    Norton and JustDSM like this.
