HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 29, 2019 at 4:09 AM
    #2301
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    got the truck running yesterday and put a fresh tank of 93 in it. excited to start figuring out this tuning stuff!!! gonna rain for a while tho. and she doesnt usually come out in the rain.
    Roostfactor, 1slow4.0, Torspd and 5 others like this.
  2. Apr 29, 2019 at 8:15 AM
    #2302
    ThomasMore66
    Dallas/Fort Worth & Durango
    You 2wd people...
  3. Apr 29, 2019 at 8:25 AM
    #2303
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    its my baby and i dont need to drive it. tying to keep it nice.
  4. Apr 29, 2019 at 8:27 AM
    #2304
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I know, it's funny how many different purposes one vehicle can be used for. My truck specifically comes out in inclement weather. Seems like the worse it is out there, the better the truck performs in comparison to others.
  5. Apr 29, 2019 at 11:43 AM
    #2305
    ThomasMore66
    Usually when a baby is blue that's a bad thing.
  6. Apr 29, 2019 at 11:57 AM
    #2306
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    just took this dark
  7. Apr 29, 2019 at 12:17 PM
    #2307
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    so does the laptop have to be connected to the MPVI2 in order to even open the tune? im guessing so since everytime i try otherwise it fails.
  8. Apr 29, 2019 at 12:17 PM
    #2308
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Yes. You also need internet connection to do initial read and when doing a write.
  9. Apr 29, 2019 at 12:18 PM
    #2309
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Well thats annoying. I wanted to be able to edit it without sitting in the damn truck all the time
    loginfailed likes this.
  10. Apr 29, 2019 at 12:20 PM
    #2310
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Mobile hotspot with your phone. I tweaked my tune the other day that way.
    Norton and JustDSM like this.
  11. Apr 29, 2019 at 12:26 PM
    #2311
    Sacrifice
    KS
    DCSB OR 4X4 LT
    yeah thats what i did too. i was just wanting to look through what is available while im at work is all.
  12. Apr 29, 2019 at 12:50 PM
    #2312
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
  13. Apr 29, 2019 at 12:51 PM
    #2313
    1slow4.0
    Nick
    Colorado
    2012 TRD OR
    Sorry, not sure how your link got there.
  14. Apr 29, 2019 at 12:53 PM
    #2314
    1slow4.0
    Nick
    Colorado
    2012 TRD OR
    Also, can someone tell me how you link a member in a Post.
    Thank you.
    loginfailed and JustDSM like this.
  15. Apr 29, 2019 at 12:55 PM
    #2315
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Id be inclined to keep shift scheduling for fault stock. I am going to do some "work" at work here shortly on an excel doc that im going to share here that has driveshaft output speeds vs real speeds vs what gear to make things easier to tune trans shift points.
    use the @ symbol before typing their name @1slow4.0
  16. Apr 29, 2019 at 1:00 PM
    #2316
    1slow4.0
    Nick
    Colorado
    2012 TRD OR
    Okay thanks, I have the fault stock and have been slowly adjusting the Normal. Its working really well and the truck drives a lot better. Obviously everyone will have their own thought on how it should shift. Looking forward to your findings and post.
    And thanks for the how to link a member.
  17. Apr 29, 2019 at 1:03 PM
    #2317
    ThomasMore66
    I just type in their name as @1slow4.0.
    1slow4.0[QUOTED] likes this.
  18. Apr 29, 2019 at 1:17 PM
    #2318
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Use the "@" before their username.
  19. Apr 29, 2019 at 1:21 PM
    #2319
    1slow4.0
    Nick
    Colorado
    2012 TRD OR
    Thanks guys!
    JustDSM likes this.
  20. Apr 29, 2019 at 1:31 PM
    #2320
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You just need the MPVI2 plugged into the laptop via USB. You don’t have to be connected to the truck.
    I set them to be the same.
    Norton and 1slow4.0[QUOTED] like this.
