HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 29, 2019 at 1:44 PM
    #2321
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    I set them to be the same.[/QUOTE]
    Awesome, thanks!
    Only the shift 1-2 is different from normal to normal fault on the stock cal.
  2. Apr 29, 2019 at 2:37 PM
    #2322
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Attached is a quick excel doc i have made to help with shift scheduling.
    Keep in mind the following:
    • Indicated speed is done by ABS sensor aka wheel speed,
    • Gearing changes will NOT effect indicated speed but will effect engine rpm at a given speed
    • Numbers below are for a stock geared v6 truck (3.73's).
    Biggest bit of info here is the indicated speed to output rpm constant, once we have that we have everything else via simple math.
    I took a few quick readings (just via dash gauges) on my lunch in 4th lockup 1:1 and the constant of 41 rpm / indicated mph is pretty much spot on. (45mph looked around 1850 rpms, 60mph looked a smidge under 2500). This is further solidified via the fact that 5th lockup will occur at the slowest speed of right around 32mph according to toyota service manual. If you do the math 32 x 41 = a driveshaft speed of 1312 rpms, which on the stock tune the absolute soonest it will allow the truck to shift to 5th is at 1300 DS rpms.
    So a constant of "41" with 3.73 gears is damn close enough in my book, especially given the fact this is at lockup, not accounting for torque converter slip.
    I have made the following excel doc to help with those wanting to play with different shift points. Do NOT mess with the RPM constant box, if you have different gears other than 3.73 you can change your gearing ratio (in box B11) and that will reflect the RPM constant, DS RPMs, and Engine RPMs accordingly.
    ALSO things to note, Accelerator pedal position boxes on each of the upshifts and downshifts. There are the same number of "tuneable" spots, but each of the accelerator pedal positions are DIFFERENT. So if you are trying to raise / lower engine rpms at a given throttle position make note, the 4th box in for 1st gear is not the same pedal position as the others etc.
  3. Apr 29, 2019 at 2:54 PM
    #2323
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Ah ok. Thanks :thumbsup:
    So much room for activities now too
  4. Apr 29, 2019 at 3:52 PM
    #2324
    HPTuners
    HPTuners Well-Known Member
    If you are having problems with the scanner not showing Toyota Enhanced PIDs please download and install 4.3.604 or later to resolve the problem. (This problem only exists for some non TRD calibrations).
    Roostfactor, 1slow4.0 and loginfailed like this.
  5. Apr 29, 2019 at 3:54 PM
    #2325
    nd4spdbh
    SoCal
    Are there any specific PID's you would like me to test this evening?
  6. Apr 29, 2019 at 4:01 PM
    #2326
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    You guys are awesome, and I will test this out, this afternoon.
  7. Apr 29, 2019 at 4:04 PM
    #2327
    HPTuners
    Not really it's an all or nothing kinda bug, if you see any PIDs that aren't SAE (such as Knock Feedback) it's working.
    loginfailed and nd4spdbh[QUOTED] like this.
  8. Apr 29, 2019 at 4:07 PM
    #2328
    HPTuners
    Also, a fix for the bug of VCM Editor 4.3 Beta crashing on first launch after install has been checked in. Download 4.3.604 or later.
  9. Apr 29, 2019 at 5:46 PM
    #2329
    Lthompson
    Lthompson Well-Known Member
    I still haven't made a purchase, but im still not sure on whether or not I should go ahead and get the pro tools or whatever. Do I need this to do datalogging and such? I want to be able to log stuff to send to you smart guys to fix.
  10. Apr 29, 2019 at 5:50 PM
    #2330
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    You can always upgrade to the pro version at a later time. It isn't really cost savings to buy it all at once.
    Norton and Lthompson[QUOTED] like this.
  11. Apr 29, 2019 at 5:56 PM
    #2331
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    You can data log with the base one. If you're supercharged the pro allows a Wideband afr gauge to be input through the mvpi2 for data logging.
    Norton and 1slow4.0 like this.
  12. Apr 29, 2019 at 6:03 PM
    #2332
    Lthompson
    If it can be later upgraded if I so choose, then that's good. I was kinda under the impression you had to buy it with the stuff already there and wasn't exactly "upgradeable"
  13. Apr 29, 2019 at 6:17 PM
    #2333
    HPTuners
    The only cost benefit is you save on small shipping cost for the Pro-Link device if you order it upfront it comes in the box with the MPVI2.
  14. Apr 29, 2019 at 6:55 PM
    #2334
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    You answered your own question. Buy it, wire in your afr gauge, log and then send logs to tune tweakers (is that the PC term?)
    Pro version and four credits. $750. (Plus tax on the hp site. Which surprised me.)
    Mine shipped today. Giggity.
    Roostfactor, zippsub9 and loginfailed like this.
  15. Apr 29, 2019 at 8:01 PM
    #2335
    deeezy
    Dana
    Hawaii
    @HPTuners I downloaded the latest beta software per above and now my scanner is able to log the enhanced PID's. Thank you for your prompt resolution for my issue. I will reply to the ticket also. :cheers:
  16. Apr 29, 2019 at 8:21 PM
    #2336
    nd4spdbh
    SoCal
    Applied the JustDSM tune today. Going to be good and not flash some of the trans shift points I would like to for the next week or so to get a baseline MPG.
    I did flash a modified JustDSM tune with some changes I made to lower throttle opening upshifts and im liking what im seeing as far as auto trans behaving better! But like stated went back to the OG JustDSM tune, to get mpg numbers and take a little more time to wrap my head around shift points etc.
    Have very few miles on the JustDSM tune other than startup, and one or two passes up n down the street. Throttle response changes are instantly noticed, less mushy pedal feel for sure which makes sense given the changes made to pedal mapping in the tune, There is much more than that though to the tune that has been changed as well.
  17. Apr 30, 2019 at 3:07 AM
    #2337
    asgardengineering
    asgardengineering Well-Known Member
    Sydney, Australia
    Toyota Hilux SR5
    I see this is listed as only supporting the Tacoma 1GR-FE but anyone know (HPtuners or otherwise) if it works with the 1GR-FE and A750 in the Hilux? Software number through techstream is 89663-0KD50. I'm willing to be the guinea pig :)
    Hawk373, Roostfactor and loginfailed like this.
  18. Apr 30, 2019 at 3:44 AM
    #2338
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    That looks like the ECU number. The number you would need to know is the calibration ID.
    Norton likes this.
  19. Apr 30, 2019 at 3:49 AM
    #2339
    HPTuners
    I don't have that file sorry! Is this an Australian vehicle or ? I am working on the Hilux diesels at present.
    Roostfactor likes this.
  20. Apr 30, 2019 at 3:53 AM
    #2340
    asgardengineering
    Sydney, Australia
    Toyota Hilux SR5
    Yeah its Australian, the V6 gets neglected down here, diesel tuning guys are a dime a dozen but other than alientech (painful) and bit edit (very painful) there aren't any options for the V6, Even more so when you want to do it yourself.
