HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 6, 2019 at 9:22 PM
    #2521
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
  2. May 6, 2019 at 9:24 PM
    #2522
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    @loginfailed, thanks again for poking a hole in my wallet:) I mean for thinking about your hp brethren with those injectors. Really appreciate your efforts for me/us.:cheers:
    loginfailed[QUOTED] likes this.
  3. May 6, 2019 at 9:39 PM
    #2523
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You install ‘em yet?
  4. May 6, 2019 at 9:45 PM
    #2524
    Jesse
    Poulsbo
    15' DCSB OR S/C
    No. Been a process for me. Complete gauge/electrical rewire on Saturday, helped @crashnburn80 get his radiator in on Sunday. He loaded my laptop with hp tuners files. Now appointment with our hp tuning help specialist, then injectors. Apartment living sucks. But being patient and having TW support buddies rule! It's just a matter of time. Bottom line is I'm grateful to save on the group buy. I'll never be first in the pack, but I'm in it.:thumbsup:
  5. May 6, 2019 at 11:37 PM
    #2525
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Hahah Apartment living does suck, but I sure got alot done during week days I had off and no one was parking behind the complex. Most of my mods done during working hours....painted fenders for 3 days straight while no cars were there, brought the fenders back up to the apartment to gas off during the night. Wife hated it, but still worked HAH.
  6. May 7, 2019 at 6:18 AM
    #2526
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Has anyone got a wideband to successfully work with the logger yet? Using the analog input with AEM 4110. Google hasn't helped so far and HPTuners Forum seems to have more than a few unresolved threads on this issue. Probably going to submit a ticket
  7. May 7, 2019 at 6:24 AM
    #2527
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    A few folks have.
    You'll want to add your wideband AFR output to your channel list by adding it through the Transform function versus the MPVI2 Pro input.
    Post up a screenshot of what you're adding the PID to the channel list.
  8. May 7, 2019 at 6:26 AM
    #2528
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Did you go with their stage 3+?
  9. May 7, 2019 at 10:14 AM
    #2529
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I ended up with the 2+ cause I needed a clutch fast. Thought I was only installing a new throwout bearing at the time. Spec usually only builds to order especially for our tacomas. But the 2+ is rated 440 hp and has great drivability. Anyway, I would have probably gotten the 3+ if I had more time.
  10. May 7, 2019 at 10:29 AM
    #2530
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I did. :D
  11. May 7, 2019 at 11:30 AM
    #2531
    BassAckwards
    I thought you were running a twin disc..
    Is their stage 3+ a single disc?
  12. May 7, 2019 at 12:11 PM
    #2532
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    On the OEM transmission I used the SPEC 3+. When I moved to the T56, I also purchased a 3+. It is the same 12" disk as a 97-01 Camaro, with a Tacoma hub.
    Then went crazy and had the twin disk developed, by McLeod Racing.
  13. May 7, 2019 at 12:13 PM
    #2533
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    jezus a twin disk on a tacoma. lordy.
  14. May 7, 2019 at 12:23 PM
    #2534
    BassAckwards
    Gotcha, thanks for the info, sounds like SPEC stage 3+ will be my next choice when it's time for another clutch. How many miles did you have on yours whenever you swapped trannys for the T56? Im really hoping the SPEC will have a better lifespan than the URD clutches
    TodayWasTHeDaY likes this.
  15. May 7, 2019 at 1:19 PM
    #2535
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I couldn't tell you the mileage. I can tell you that the competition clutch 6puck couldn't hold the torque my engine made. Started slipping far too soon after install. Sold it. Got the 3+ rated at 550 engine torque. Held 550 wheel torque, without hesitation. Daily even. :D
    Most people will be good with the 2+, like @TRON has.
  16. May 7, 2019 at 1:51 PM
    #2536
    VolcomTacoma
    Jeff
    NorCal
    I mean in URD Stage 3's defense, I'm hard AF on my clutch. It's not really a surprise it grenaded. I drop the clutch often on mine. I don't baby my clutch, I realize this, so I wasn't terribly upset that the clutch failed. Just glad the trans didnt fail. Once I get into a better financial situation I will be looking into more upgrades for my driveline to prevent what happened this time.
  17. May 7, 2019 at 2:24 PM
    #2537
    nd4spdbh
    SoCal
    Back to tuning.
    Im thinking I am going to try and change just the 4 to 5 shift by the 170 / 200 rpms to see how that affects drive ability. I might also play with downshiftings in the lower gears to see if I can get it to hold a gear longer before downshifting. This should keep the upshift smoothness and help eliminate some of the hunting at lower rpms. All speculation, but if I get the chance tonight ill give it a try.
  18. May 7, 2019 at 3:13 PM
    #2538
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Is your t56 notchy? Mine is unless i spin it up more especially the 1->2 and 2->3 shift.
    Then i also have issues with getting it in first at a stop light unless i do it while slowing down. Its likenit gets locked out of first unless i let the clutch in/out. Makes zero sense. Has the issue even if the car isnt running
  19. May 7, 2019 at 3:32 PM
    #2539
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    When is the last time you changed your transmission fluid? I run redline oils D4 ATF.
    If that doesn't help, then you may have some transmission issues.
    Could be something with the throwout bearing. Do you have the spacer on the bearing itself, or between where it mounts to the transmission?
  20. May 7, 2019 at 8:18 PM
    #2540
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    So any heartbeat on 2TR-FE support?
    I'll be more than glad to send in an ECM.
    BassAckwards, loginfailed and Torspd like this.
