HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 8, 2019 at 8:03 PM
    #2601
    ThomasMore66
    Dallas/Fort Worth & Durango
    My house is in Sky Ridge at 6900’. My 80 series basically sucks there. You’re playing an entirely different game.
    DesertRatliff[QUOTED] likes this.
  2. May 8, 2019 at 8:17 PM
    #2602
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    No filter? Not even the thinnest Belgium linen?
  3. May 8, 2019 at 8:17 PM
    #2603
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Shalona Hill to Purg is a N/A 6-cylinder killer; 1FZ, 5VZ, 1GR. I should just be happy I'm not still trying to pull it in my 22RE!
  4. May 8, 2019 at 8:23 PM
    #2604
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Good datapoint! Again, all feedback is welcome. Doesn't sound like the VVTi changes are too popular with the butt-dynos :) If you guys like the stock mapping (VVTi) rock it! :D we'll readdress VVTi later
    PS: Everyone is going to have slightly different tune versions, they're not consistent between folks, each truck I work with will get a slightly different version number depending on how much testing/tuning we've done.
  5. May 8, 2019 at 8:27 PM
    #2605
    JustDSM
    Justin
    Ogden, UT
    Stock air filter in stock airbox.
  6. May 8, 2019 at 8:30 PM
    #2606
    ThomasMore66
    Running to Purg I shift down and run 4000 rpm in the 80. The big 6 can take it!
    Edit: above Silverton on the Alpine Loop in November. Don’t get in a hurry. This is why turbo is the plan.
    Norton and DesertRatliff[QUOTED] like this.
  7. May 8, 2019 at 8:44 PM
    #2607
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Thanks for being so gracious. I hope you know I wasn't trying to come off as ungrateful; I couldn't be more thankful of your efforts and all you've done for all of us, including letting me flash and beta test another one of your awesome tunes. Thanks JustDSM!
    With everything you've done, I feel like the very least I can do is provide you with relevant feedback. I feel like I still don't have enough windshield time to do that. Some data logging between the two versions on the same stretch of road vs. just trying to feel what the hill is telling me on only two passes (with potential head wind, temperature, and all the other variables) is what I need to provide you. I'll try to knock that out this weekend.
    deeezy and JustDSM[QUOTED] like this.
  8. May 8, 2019 at 8:56 PM
    #2608
    JustDSM
    Justin
    Ogden, UT
    Not for one second did I think any of you were ungrateful! Just to be clear feedback that isn't "glowing" is just as welcome as the good stuff! I welcome it all, it's how we can all learn and develop this platform. :)
    I appreciate everyone's willingness to give this experiment a whirl and report back with your findings. All is good my friends :D
    deeezy and DesertRatliff[QUOTED] like this.
  9. May 8, 2019 at 9:05 PM
    #2609
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Thanks to @JustDSM. Did some live data transfer with him. Hoping it will be a reference point to help others. I just tried to not crash. Damn, this thing had more go than ever. Seriously had a tough time slowing it down on a regular course. Thanks again justdsm!
    DesertRatliff and JustDSM like this.
  10. May 8, 2019 at 9:05 PM
    #2610
    05Taco4x4
    2TR-FE Enthusiast
    Ah, i see it now haha
  11. May 8, 2019 at 9:07 PM
    #2611
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm curious what my 0-60 times are. One block and I do it.
  12. May 9, 2019 at 5:36 AM
    #2612
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    So whats the process for datalogging without the pc connected? I dont enjoy having to hook up my pc everytime i want to do something so itd be easier to log on my way to work/home. Will it do 2 vehicles this way? I want to dial in my gto which UG doesnt display LT or they are always zero :notsure: ST jumps up to 18 sometimes..
  13. May 9, 2019 at 5:41 AM
    #2613
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Do you have the MPVI2 Pro version? Apparently you can log data without a laptop if you have the Pro version. If not, you're stuck rolling around with the laptop perched somewhere.
  14. May 9, 2019 at 5:45 AM
    #2614
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Nope. Well that sucks. Oh well, i need to do some logging and figuring this shit out now that i bought it, lol
  15. May 9, 2019 at 5:46 AM
    #2615
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I used a Home Depot yard sprinkler 4” cap off and then RTVd it to the inner fender. I can snap a pic if you like.
  16. May 9, 2019 at 5:51 AM
    #2616
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I have the pro version and I haven't figured out how to log without the laptop yet:confused:
    zippsub9 likes this.
  17. May 9, 2019 at 6:07 AM
    #2617
    zippsub9
    Halfmoon, NY
    14 DCLB
    I have a feeling I will be upgrading to the Pro Version as soon as I finish moving and closing on a new house.
  18. May 9, 2019 at 6:40 AM
    #2618
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Wow. This new tune setup is so nice. Truck just all around performance is very smooth. Feels incredible. I need to focus on being consistent to check mileage. I know its improved.
    Norton, nd4spdbh and DesertRatliff like this.
  19. May 9, 2019 at 6:42 AM
    #2619
    JustDSM
    Justin
    Ogden, UT
    :oldglory:
  20. May 9, 2019 at 7:10 AM
    #2620
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Pro here too. Haven’t seen anything about logging without the laptop. Would be cool tho.
