HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 9, 2019 at 2:49 PM
    #2661
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    Thanks man, much appreciated!
  2. May 9, 2019 at 2:53 PM
    #2662
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yeah I’m just used to bikes where you throw it in 4th at 2-2.5k depending on the bike and then send it. Makes it super consistent and easy to see changes. Especially on a bike that revs to 12-18k. Allows you to see the driving range quite nicely.
  3. May 9, 2019 at 2:55 PM
    #2663
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Could do the same thing with a manual taco as well. Just takes a lil more effort on an auto trans.
    Norton and snowsk8air2[QUOTED] like this.
  4. May 9, 2019 at 2:59 PM
    #2664
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Finally hooked up the tuner. Can’t beleive how fast it worked and started messing with stuff. Had to leave work tho. But now I can sit on the couch and mess around with things. Played with a Mazda 3 speed on the way home tonight. He lost...
    1slow4.0, JustDSM and BassAckwards like this.
  5. May 9, 2019 at 3:00 PM
    #2665
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  6. May 9, 2019 at 3:00 PM
    #2666
    ThomasMore66
    Dallas/Fort Worth & Durango
    Livin' the Mexican dream.
  7. May 9, 2019 at 3:08 PM
    #2667
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Coronas on me!
  8. May 9, 2019 at 3:09 PM
    #2668
    nd4spdbh
    SoCal
    Sorry for the incoming barrage of questions
    Can you explain the graph, looks like im only seeing 2 pulls?
    I assume 3 pulls, one was stock config with it attached, 1 was unhooked with the flapper in a resting position, and 1 was unhooked and flapper in non resting position.
    EDIT - am i seeing a dotted line that closely follows both other varying pulls? Either way, which line is which and what is position a and position b?
    JustDSM likes this.
  9. May 9, 2019 at 3:11 PM
    #2669
    ThomasMore66
    Meh! There is better Mexican beer.
  10. May 9, 2019 at 3:11 PM
    #2670
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    @nd4spdbh
    I think there's three graphs shown, but one is partially eclipsed by another.... and you can see the crossover point in the middle when the valve actuates. makes sense actually.
    Torspd and JustDSM like this.
  11. May 9, 2019 at 3:19 PM
    #2671
    nd4spdbh
    SoCal
    Yeah i see it now, one line that closely follows both, but that doesnt fall inline with what i see on the ACIS settings. The valve is only activated between ~2200-4200 rpms at higher loads if im reading things correctly.
    Waiting to here from @Torspd as to which graph line is which before speculating more.
    JustDSM likes this.
  12. May 9, 2019 at 3:23 PM
    #2672
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    So i found out my GTO is already tuned...LTFTs are disbaled right now. A previous owner must have tuned it for the kooks headers/mid pipes but it still had a stock airbox :rolleyes:
    12TRDTacoma likes this.
  13. May 9, 2019 at 3:25 PM
    #2673
    ThomasMore66
    Needs boost!
  14. May 9, 2019 at 3:27 PM
    #2674
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Id love to slap a LSA blower on it or even a tvs2300.
    Whats the recommended dual wideband guage? Innovate? Does aem have one? Ive seen aem recommended a lot
  15. May 9, 2019 at 5:46 PM
    #2675
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Let me know how that works. I said that a month ago and 2k bucks just flew away to the cause.
  16. May 9, 2019 at 5:47 PM
    #2676
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm very pleased with aem's x series wide band afr's.
  17. May 9, 2019 at 6:06 PM
    #2677
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    To be honest, I don't see how the results show that small of a gain. My truck pulls a lot harder at partial and wot than pre-tune. Although my truck has a Y-pipe, intake, manifold spacer, etc..., I feel that his truck should have been at least a little better on the dyno.
  18. May 9, 2019 at 6:07 PM
    #2678
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I found Seattle to be excellent for adding water injection. 20190503_194941.jpg 20190503_195017.jpg
  19. May 9, 2019 at 6:10 PM
    #2679
    DiamondW
    Kent
    Gonzales Co. TX
    If I hadn’t seen it for myself I wouldn’t believe it.
    JustDSM likes this.
  20. May 9, 2019 at 6:37 PM
    #2680
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Thats only available in single afr display though isnt it? Or am i missing the dual?
    Issue is my midpipes have cats. So i need to put them before those where i cant do a single in the x further back.
    I think part of the butt dyno is because of the throttle mapping. The engine "pulls" harder because its being told to without flooring it everywhere. Driveability is definitely way up with that being said
    deeezy[QUOTED], JustDSM and DiamondW like this.
