HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 9, 2019 at 7:30 PM
    #2681
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    My truck picked up 3 mph on my Dyno Hill at WOT, doesn't shift to 3rd (like it did before) but holds 4th when pulling the same hill at the speed limit (60mph), I got to get rid of the prone-to-failure SAI system and my fuel economy improved significantly. I've got sliders, skids, a bumper, 2.5 inch lift and rolling E-rated 275 70 R17's on the DCLB and the truck feels livelier than our very stock 2006 DCSB and is getting better fuel economy.
    With all due respect to the dyno results, I'm more than satisfied with JustDSM's HP Tuners results and haven't even started on the mechanical engine mods yet.
  2. May 9, 2019 at 7:31 PM
    #2682
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Yeah, throttle mapping is part of it but my truck pulls harder at wot. That's where my truck kinda sucked pre-tune.
    1slow4.0 and JustDSM like this.
  3. May 9, 2019 at 7:47 PM
    #2683
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pull 3, is with it in normal operation. One pull strictly torque, and drops off in the higher RPM's. The other is for HP, and you can see the difference.
  4. May 9, 2019 at 7:57 PM
    #2684
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    What year truck was this if I might ask?
  5. May 9, 2019 at 7:58 PM
    #2685
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    What was that website you posted before that sold all the silicone hoses and stuff?
  6. May 9, 2019 at 7:59 PM
    #2686
    JustDSM
    Justin
    Ogden, UT
    Ive used these guys before:
    https://www.intakehoses.com/
  7. May 9, 2019 at 8:11 PM
    #2687
    ThomasMore66
    Dallas/Fort Worth & Durango
    http://www.siliconeintakes.com/
    Spending money...
  8. May 9, 2019 at 8:18 PM
    #2688
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Gotcha, Interesting. the strictly torque one was that in the resting state of the flapper (IE truck off)?
  9. May 9, 2019 at 8:27 PM
    #2689
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    High vacuum causes it to stay in a "torque range", then with parameter changes the ACIS valve changes and it becomes HP range.
  10. May 9, 2019 at 8:29 PM
    #2690
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Congruently, that flap is a major reason why throttle body spacers don't work.
  11. May 10, 2019 at 5:52 AM
    #2691
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Had too many brewskis last night. The ACIS valve switches states for runner length at roughly 4100 RPMs, to increase the HP. That graph is the long serrated dashes.
  12. May 10, 2019 at 5:57 AM
    #2692
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This was of my 2006 truck. With the stroker engine and cams, running with the OEM ECU in charge. VVT-I locked out.
    Here is after some tuning.
    JustDSM[QUOTED] likes this.
  13. May 10, 2019 at 6:10 AM
    #2693
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I ordered all the necessary pieces along with the AFe scoop.
  14. May 10, 2019 at 6:54 AM
    #2694
    JustDSM
    Justin
    Ogden, UT
    There’s actually two RPM switching points and a Hi/Low TPS switching point.
    2200 and 4100RPM
    60° Throttle Angle
    Below 2200RPM is considered Low
    2200-4100RPM is considered Mid
    Above 4100RPM is High
    Stock configuration on all the cals I’ve seen only actuate at Mid/High TPS.
    Torspd[QUOTED] likes this.
  15. May 10, 2019 at 7:00 AM
    #2695
    JustDSM
    Justin
    Ogden, UT
    The AFE scoop is a bit more attractive due to the price point, but I’ve heard that it had a 4” outlet vs the 3.5” on the Volant.
    loginfailed[QUOTED] likes this.
  16. May 10, 2019 at 7:08 AM
    #2696
    ThomasMore66
    Is the consensus that it does work?
  17. May 10, 2019 at 7:10 AM
    #2697
    JustDSM
    Justin
    Ogden, UT
    I did a little tinkering yesterday in Mexico, and it’s very obvious looking at the logs, that it works. I’ll post some data/screenshots here in a bit. Day job duties...
    BassAckwards likes this.
  18. May 10, 2019 at 7:13 AM
    #2698
    ThomasMore66
    Mexico is so popular right now.
    55 degF here this a.m. which is odd, but it did lead to a CEL for high MAF flow...
  19. May 10, 2019 at 7:33 AM
    #2699
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I assumed it would be a little different and just figured I'd make it work.
  20. May 10, 2019 at 8:35 AM
    #2700
    nd4spdbh
    SoCal
    This is correct.
    From the dyno charts it does look like we stay in a "long intake runner" mode until ~4100 rpms
    Ideally yes, at around 4100-4200 rpms (the "high rpm zone") you switch over to "position A" - assuming thats short intake runner mode, due to lack of hp n torque in the lower rpms.
    What doesnt make sense to me is if we say 0 is "long intake runner mode" and 1 is "short intake runner mode", looking at the stock config it doesnt make any sense if we compare to the dyno charts. Its only in "short intake runner" mode in Medium RPMS 2200-4100 range when by the looks of the dyno, it should be in the same state that it is at lower rpms in the medium zone then switch to short intake at the Hi RPM zone.
    Im almost tempted to put a camera n light under the truck to make a recording of how it acts stock, its possible that HPTuner ACIS control is a lil messed up / miss-labeled, would make more sense if that 1 was in the Hi RPM - Hi Tps zone as thats what we see occur on the dyno charts.
