HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 10, 2019 at 1:49 PM
    #2741
    OVTune
    OVTune Well-Known Member
    OVTune
    The 3.5L loses a lot of torque if the ACIS is open at low RPM and high throttle. It's definitely something that requires a dyno to find the optimal point.
  2. May 10, 2019 at 1:50 PM
    #2742
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    That's pretty interesting. What are the factory opening/closing points on the 3.5L?
  3. May 10, 2019 at 1:50 PM
    #2743
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Yes, please :D
    JustDSM[QUOTED] likes this.
  4. May 10, 2019 at 1:52 PM
    #2744
    OVTune
    OVTune
    3650RPM. I actually have a whole write up on the ACIS dyno tuning. Opening it really early results is huge losses.
    The stock point is *pretty close* to optimal.
  5. May 10, 2019 at 2:21 PM
    #2745
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I feel so neglected! :rofl:
  6. May 10, 2019 at 4:03 PM
    #2746
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Ahhh, the little old man with bum knee who needs others work on his truck is really pushing the buttons today.
    There will be meth one day for safety.
  7. May 10, 2019 at 4:04 PM
    #2747
    nd4spdbh
    SoCal
    thats for the 3.5L though correct?
  8. May 10, 2019 at 4:07 PM
    #2748
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    When you buy a system I highly recommend buying braided lines. Pumps are fitted at manufacturers for either compression fittings or 6an.
    Roostfactor[QUOTED] likes this.
  9. May 10, 2019 at 4:09 PM
    #2749
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The first three runs were on the OEM ECU.
    The thick blue run, was done with the Haltech controlling the engine.
    I unplugged it, and zip tied it in one direction and did pull. Then the opposite. Then plugged it back in and did the next with it operating as is should from the factory.
    Roostfactor and JustDSM[QUOTED] like this.
  10. May 10, 2019 at 4:15 PM
    #2750
    JustDSM
    Justin
    Ogden, UT
    Thank you for the clarification! That helps make a little more sense of things.
    Torspd[QUOTED] likes this.
  11. May 10, 2019 at 4:16 PM
    #2751
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The intake and ecu functions were OEM. Thus the ACIS was functioning as designed. Independent of what internals the engine had inside. That operation is still observed and clearly follows all other cataloged N/A Dyno runs.
    Either I am confused or you all are. Long runners are for torque. Short for HP. Pop the hood and have someone rev the engine. Watch where it operates in conjunction to rpm. As well as tps if you can.
    Roostfactor likes this.
  12. May 10, 2019 at 4:19 PM
    #2752
    nd4spdbh
    SoCal
    I think the confusion is, does 1 (aka on) with HPTuners mean the intake runners are in the long position. And why is the intake runner not in the long position in the Low rpm High TPS range stock. Unfortunately dyno charts below 2k rpms are not common.
  13. May 10, 2019 at 4:19 PM
    #2753
    JustDSM
    Justin
    Ogden, UT
    This is what’s interesting, that all OEM cals show short runners (ACIS off) are used whether the Throttle is < or > than 60°.
    Interesting anecdote is that OV is seeing torque loss with the 2GR’s with the AICS on at low rpm. Hmm!
  14. May 10, 2019 at 4:22 PM
    #2754
    nd4spdbh
    SoCal
    Also, looks like a tipping point back to short runners (modding the mid-high zone boundary) to 4250ish could have some gains in that range like justdsm stated.
  15. May 10, 2019 at 4:23 PM
    #2755
    JustDSM
    Justin
    Ogden, UT
    Look at the logs I screenshotted earlier. You can clearly see ACIS difference between on and off.
    The log where airflow flat lines is with ACIS on (long runner greater than 4250).
  16. May 10, 2019 at 4:24 PM
    #2756
    nd4spdbh
    SoCal
    Big time, thats why i stated 4250 as it looks like from the dyno charts that torspd attached as well as your logs, moving it up a lil bit could be beneficial.
  17. May 10, 2019 at 4:28 PM
    #2757
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Maybe the confusion is what is considered "On" versus "off". ;)
  18. May 10, 2019 at 4:29 PM
    #2758
    JustDSM
    Justin
    Ogden, UT
    Good point! To put it out there, on= long runner. Off= short runner
    1slow4.0 likes this.
  19. May 10, 2019 at 5:03 PM
    #2759
    ThomasMore66
    Dallas/Fort Worth & Durango
    Lol!
  20. May 10, 2019 at 5:04 PM
    #2760
    ThomasMore66
