HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 12, 2019 at 4:11 PM
    #2781
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    Yeah, ever since then it’s not happy.
  2. May 12, 2019 at 4:11 PM
    #2782
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    hmm weird. worked perfect for me every time, every beta, even added some of my own channels for monitoring other things.
  3. May 12, 2019 at 4:17 PM
    #2783
    DiamondW
    Kent
    Gonzales Co. TX
    It probably has more to do with the laptop itself... It hasn’t been used in a long time.
  4. May 12, 2019 at 4:54 PM
    #2784
    Liveaboard74
    Liveaboard74 Well-Known Member
    LUKE
    Elizabeth City, NC
    2006 Toyota Tundra 6 speed, camper shell
    2.5 inch lift, 265/75/16s Smittybilt awning. Custom Bed Stereo. Rear View camera. Light bar forward and backwards. Front cooler rack. Leds front and under steps. Garmin off road gps. Garmin one road GPS . Two different units. CB, Roof Rack with custom Tent mounts. Traction Boards. Bliston Shocks.
    Just make sure the cost to gain a few HP and torque numbers will be worth the wait.
    Have a convertible G6 V6 shop on the forum there was selling modded ECMs like crazy. I didn't buy into it, but they ran a special at Christmas. I gained about 28 HP Not enough to make that much difference for the full cost they were asking. Gas unless your modding your not going to see a lot of gain with HP tuners. Modded,, O ya, I"ve use it with a toy I had on the street , You can also tame a cam down with HP tuners and injectors. Make it sound any way you want it to sound. Fun stuff but like mentioned, stock, your spending a whole lot of money for very little gain and you won't know what you have unless you run a before and after dyno. . Another thing to think about will burning 93 be worth the cost to you for the gain you get. We just come back from the mountains. 93 was 80 cent a gal more than reg. I have two ecms with the G6. Ran it for a while but its been off it for a long time.
  5. May 12, 2019 at 4:57 PM
    #2785
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    For me, the ability to eliminate the SAI and its associated limp mode failure risk is worth it all alone.
  6. May 12, 2019 at 5:08 PM
    #2786
    nd4spdbh
    SoCal
    This right here. 500 bucks, for all sorts of driveability improvements, possible mpg improvements etc etc. well worth it in my book. Plus i like to tinker! As mentioned before, the justdsm tune has made the truck pull smoother through all the revs, and overall just more lively. And this is all on shitty california 87 octane.
  7. May 12, 2019 at 5:12 PM
    #2787
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I'm sure it has been answered before in here and apologies because I forgot, but can you disable just the limp mode from the SAI? I know the whole thing can be disabled but I don't know if I want to go through the trouble of removing it entirely.
  8. May 12, 2019 at 5:14 PM
    #2788
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Just tuned the truck for the first time. Gonna drive it tomorrow morning and see how it feels. Just removed speed limiter. And removed codes for cats. And the p0136 code I keep getting for my 02 sensor. And did the @JustDSM throttle mapping. Can’t wait to see how it feels.
  9. May 12, 2019 at 5:16 PM
    #2789
    ThomasMore66
    Dallas/Fort Worth & Durango
    NA guys are such downers...:D
  10. May 12, 2019 at 5:18 PM
    #2790
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    Yep sure can.
  11. May 12, 2019 at 5:26 PM
    #2791
    ThomasMore66
    $0.60 more per gallon here. Don’t care. 93 is going in the truck. Still cheaper than a gallon of milk.
  12. May 12, 2019 at 5:35 PM
    #2792
    Liveaboard74
    LUKE
    Elizabeth City, NC
    Supercharge nitrous and meth yellow vette. 960/945.
    And boosted is fun, but you don't always have to be boosted to fly. Be careful of that spray to. :) PS. us NA guys ain't all bad either but we will sneak a button in there on ya. . :)
    Thomas if you haven't tried meth yet, try it some time. Pure meth. No water meth mix. or those aftermarket mixtures. It added 45 HP to the vette. Got to turn the timing up by 2.
    DesertRatliff likes this.
  13. May 12, 2019 at 9:24 PM
    #2793
    nd4spdbh
    SoCal
    You can, problem is if the valve actually does get stuck open now you have exhaust going out the valve.
  14. May 13, 2019 at 6:01 AM
    #2794
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    The smoother driveability and the MPG gains I'm seeing, I would purchase the HP Tuners product and seek out JustDSM's help in tuning again without question. I could have done headers or y-pipe for about the same cost with similar nominal gains, but there's so much more you get with this system that opens the door to future tunability and improvements to get the most out of any mod, even if it's not as big of gains as the boosted guys.
    We just took the 2014 truck out on the first camping trip of the season. Loaded with 1500 pounds of gear, dogs and humans, driving a few hundred miles of highway, 50 miles of BLM Roads and some slower bumping around in 4Lo getting to camp spots. On our last trip before winter in October, driving the same route, same speeds, same load, I averaged 15.5MPG. This time with everything else the same but after having added a Demello bumper that is definitely not as aerodynamic as the stock tupperware, I averaged 19.1MPG. My wife also commented how the truck doesn't downshift to 3rd as much to climb hills on the highway and how she's never seen 200 miles on a half tank of fuel in the 10 years she's had her 2006 (we were averaging in the low 20's to Moab before we started dirt...even with a head wind).
  15. May 13, 2019 at 6:51 AM
    #2795
    DiamondW
    Kent
    Gonzales Co. TX
    Got it working this morning. An update on my POS laptop and reinstall of VCM seems to have fixed everything. I’ll be going to lunch in a few hours and I’ll get a good log. It will be with @JustDSM V1 tune.
    BassAckwards likes this.
  16. May 13, 2019 at 7:15 AM
    #2796
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    anyone done what ovtune has showed us on page 19? @JustDSM ive been going back and re reading this thread its taking me a while lol
  17. May 13, 2019 at 7:40 AM
    #2797
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    There’s a lot of chatter, but there’s also some very good tech sprinkled through this thread too.
    I’ve not used what he posted. Let us know how it works if you try it!
  18. May 13, 2019 at 8:17 AM
    #2798
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    With this in mind. Would it be ideal for an NA guy to get the TRD Flash for the extra resolution and then configure the tables down to NA; also leaving the door open for FI in the future. Or too much work?
  19. May 13, 2019 at 8:18 AM
    #2799
    OVTune
    OVTune Well-Known Member
    OVTune
    You lose ACIS by doing this, among some other things. Best to do it with boosted setups IMO.
    Hawk373[QUOTED] and DocME like this.
  20. May 13, 2019 at 8:22 AM
    #2800
    Hawk373
    2012 TRD Sport DCLB
    I see, thank you.
