HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 16, 2019 at 4:58 PM
    #2861
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Start you own thread with tuning tips. And the first post u can add what ever you want. When ever u want. And then sell tunes that you want too. Along with cam gears lol. And future things...
  2. May 16, 2019 at 5:00 PM
    #2862
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    If you ever decide to build those I'd take one.
  3. May 16, 2019 at 6:48 PM
    #2863
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Thanks man, but I hope to never have to do it again, lol. It’s been like a year later and I’m still finding aluminum shavings stuck to my socks!
    Roostfactor and TodayWasTHeDaY like this.
  4. May 16, 2019 at 7:25 PM
    #2864
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    always doing awesome work sir!!! If i get some time this sunday ill test my 25 / 50% throttle scenarios of acis functions and how it affects MAF numbers.
    Also am i correct in assuming that 25% throttle would mean a throttle angle of 84deg X .25 = 21.25deg and 50% would be 84deg x .5 = 42deg. Reason I ask is for the tests id like to set it to where if i mash the throttle i get a max of those respective percentages for consistency sake.
    Biscuits and JustDSM[QUOTED] like this.
  5. May 16, 2019 at 7:44 PM
    #2865
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    You give me too much credit! But it is very rewarding to know that what I'm able to put out is helpful.
    You're "pretty much" correct, but 25% would be 21deg
  6. May 16, 2019 at 8:00 PM
    #2866
    nd4spdbh
    SoCal
    how in the hell did i manage to divide 84 by 4 and get a decimal is beyond me.... jezus... maybe its the 4th day in a row of a 10-13hr day at work on top of a hella busy month. o_O
    At least my thinking was on the right page :D.
    Like stated if i get a chance on sunday ill test those two throttle positions for more data points with ACIS in its 3 modes (stock, short runner, long runner). 25% is about what it takes to cruise at 55-60mph in my truck (21ish % for 55 23ish for 60 25ish for 65), so im rather curious within that 25% range what ACIS could do. And 50% (42 deg) seems to be around what a normal acceleration would be to merge on a freeway.
    Ill be honest I am primitive in thinking that more MAF airflow at a same throttle position means a more efficient motor and thus more fuel efficient / more powerful motor .... so correct me if i am wrong.
    JustDSM[QUOTED] likes this.
  7. May 16, 2019 at 8:01 PM
    #2867
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Just use a magnet and clean em' up!
  8. May 16, 2019 at 8:04 PM
    #2868
    nd4spdbh
    SoCal
    Get the greenhorn to do it, also make sure he collects an air sample of the welding air to make sure its osha compliant :rofl:
  9. May 16, 2019 at 8:15 PM
    #2869
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    :rofl:
  10. May 16, 2019 at 8:29 PM
    #2870
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Pretty good huh?
  11. May 16, 2019 at 8:31 PM
    #2871
    Jesse
    Poulsbo
    15' DCSB OR S/C
    When I worked in a lumberyard we got the noobs to ask contractors if they needed left or right handed studs.
    Roostfactor and Biscuits like this.
  12. May 16, 2019 at 8:36 PM
    #2872
    nd4spdbh
    SoCal
    Back to tech talk @ThomasMore66 Your shift flare. I got a TRD cal from @mightytacoman (and would love to compare your stock TRD cal PM me *kissy face*), and noticed some interesting things with regards to auto trans and the TRD cal vs the NA cal.
    @mightytacoman correct me if i am wrong you are an auto right?
    If the directly above answer is YES then the following is true of the stock tunes:
    There are some differences in the auto trans tuning as far as shift pressures etc between the TRD cal and NA cal which might account for shift flare.
    First: TRD cal has grouped gears 1/2 pressures together, and gears 3/4/5/6..... YES 6TH... WTF??? FYI: NA cal has gear pressures of gear 1/2 identical and 3/4/5 identical, so its not soooo weird, but why in the hell is there a 6th gear mention when there isnt a 6th gear for an auto in a 2nd gen taco.
    (left TRD CAL, right NA)
    Second: Different (less) gear pressure for 1/2 gears for the TRD cal in lower throttle openings vs N/A at less than 40% throttle.
    Third: Different (less) gear pressure for 3/4/5/6 (lawls 6th) gears for the TRD cal in lower throttle openings vs N/A at less than 30% throttle
    (again left TRD CAL, right NA)
    Outside of those difference, everything else from what I can tell is identical to the NA cal as far as the trans.
  13. May 17, 2019 at 3:25 AM
    #2873
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Serves me right for purchasing non-ferrous aluminum. But at least my socks won’t rust.
  14. May 17, 2019 at 5:00 AM
    #2874
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    @nd4spdbh you are correct in that I drive an auto and that it was flashed with toyotas latest trd calibration 3ywg3200. Maybe @ThomasMore66 is running a different stock calibration? I run the ratiotek kit which completely eliminated my shift flare and I have the slu solenoid turned in about a 1/4 turn.
  15. May 17, 2019 at 5:11 AM
    #2875
    mulisharydr
    mulisharydr Well-Known Member
    johnny
    2015 black TRD Sport
    Magnuson s/c 2.85 URD stealth pulley Total chaos Lt front with king shocks Dmz fab rear spring under kit with kings triple bypass shocks Dmz fab bolt in bed cage King 4” hydro bump stops Harrop rear elocker 4.30 Detroit gears nfab light bar bumper mount with 40” lightbar relentless roof mount with 50" radius led lightbar bfg TA KO2 285/70/17 powdercoated black trd sport wheels flowmaster super 10 muffler. JBA Shorty headers. ratiotek shift kit.
    Would I be able to increase the voltage output on my truck to let’s say 14.5v with this software? The increase Would be for running a larger agm battery. Then I wouldn’t have to buy a voltage booster.
    garciav and Norton like this.
  16. May 17, 2019 at 5:15 AM
    #2876
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I have a special fuse that is doing that for me as I have a northstar. If you want details it's in the lighting thread.
  17. May 17, 2019 at 5:18 AM
    #2877
    mulisharydr
    johnny
    I read in another thread about a voltage booster that replaces the alt fuse, but since I already have the hp tune, was just curious if it could do it
  18. May 17, 2019 at 5:31 AM
    #2878
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Yes, that would be cool if the tune could correct that.
  19. May 17, 2019 at 6:25 AM
    #2879
    nd4spdbh
    SoCal
    Thats what i thought. Very interesting the reference to a 6th gear. if Thomas wants to hit me up id love to compare, sounds like your trans has had some mechanical magic sprinkled on it haha.
  20. May 17, 2019 at 7:37 AM
    #2880
    ThomasMore66
    Dallas/Fort Worth & Durango
    So you've been busy. I haven't had time to look at the trans stuff at all.
    I do have a WAT valve body that vastly improves the shifts, but I do still get 4-5 flare. It's worse when I manually shift from 4-5. I'd love to look at this today, but my wife has the home computer in Arizona. My work computer won't allow me to install outside software... The other thing I'd really like to improve is the kick-down when I start leaning on the gas I'd like that to happen faster. If it's in 5th and I stomp the gas, it seems to think about it way too long for me.
