HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 20, 2019 at 8:00 AM
    #2921
    redtaco2007
    redtaco2007 Well-Known Member
    2007 Red Tacoma - TRD Off Road DCSB
    not much yet!
    Yes! The shifts sound so much better
  2. May 20, 2019 at 12:17 PM
    #2922
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    @JustDSM, I'm sure I'm not the first to comment on mileage improvements. But, wow! Did a weekend offroad excursion and I was amazed. I actually thought the tank float got stuck while wheeling. On the highway I got almost 90 miles on a quarter tank. With e-load 285's, 4" lift, (areo dynamical challenge) and a mountain pass, 75 mph. I was getting almost 20 mpg?!? Awesome!
  3. May 20, 2019 at 12:20 PM
    #2923
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Not to mention while doing some hard core offroad driving it still ran like a champ. I actually cleared a hill on one attempt that a Polaris buggy made on his second. Rad tuning skills man!
  4. May 20, 2019 at 12:59 PM
    #2924
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Just placed my order for new axels! 4:10 gears and a trutrac reverend! So exite!
  5. May 20, 2019 at 1:16 PM
    #2925
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    You will like the trutrac. I tested out my oem lsd diff yesterday and it is awesome.
  6. May 20, 2019 at 1:17 PM
    #2926
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Just got it finalized! So stoked!
    Murphinator likes this.
  7. May 20, 2019 at 1:19 PM
    #2927
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Now need to find a local guy that wants a deal on an e-locker rear!
  8. May 20, 2019 at 1:19 PM
    #2928
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    So I jsut wanted to give @Hacktacular and @JustDSM a big shout out. @Hacktacular pointed me in the direction of upgrading my supercharged taco while @JustDSM tuned this beauty fast and easy. Justin walked me through the whole process and simply broke it down for noobs like me to understand.
    Just upgrading the pulley from a 3" to 2.8" and tuned, it feels like a whole new truck! I still want to play with the HPT to see if I can do other things to my truck. But for the guys that aren't sure, I say do it!
  9. May 20, 2019 at 2:15 PM
    #2929
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I'm considering the same, where did you order and whats the damage to the debit card?
    BassAckwards likes this.
  10. May 20, 2019 at 2:17 PM
    #2930
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    4 cylinder trucks came with 4.10s if you can find a wrecked 4cyl, 4x4, you could pull the diffs and use those to regear. I found a front diff out of a wrecked 4cyl and regeared my 4wd with it. Had the rear 4.10s from my 4 banger. Good option to regear on a budget
  11. May 20, 2019 at 2:45 PM
    #2931
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I've considered going that route but I was also wanting lockers front and rear as well so I'm less likely to get stuck at the Whataburger drive-thru. So since I'll have to open them up, might as well re-gear the existing ones.
    BassAckwards[QUOTED] likes this.
  12. May 20, 2019 at 2:55 PM
    #2932
    ThomasMore66
    Dallas/Fort Worth & Durango
    I want Harrop's front and rear like my Land Cruiser's. I keep thinking that the 9"or the Dana 60 would be a better investment. I'd still like it all to work with my ATRAC if possible.
    loginfailed[QUOTED] likes this.
  13. May 20, 2019 at 3:07 PM
    #2933
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    why would you get rid of the stock elocker?
  14. May 20, 2019 at 3:39 PM
    #2934
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I searched out and bought a 3rd member and complete rear axel. With labor and a trutrac AND shipping from Colorado to Washington its 2k!!
  15. May 20, 2019 at 3:41 PM
    #2935
    Jesse
    Poulsbo
    15' DCSB OR S/C
    It's an amazing set up but I'm turning ponies that need a more solid dual tire bite on the pavement.
  16. May 20, 2019 at 3:41 PM
    #2936
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    The way I see it its only ~2k more to get the d60 w/locker and regear then it would be on the stock rear adding gears and a locker
    ThomasMore66 likes this.
  17. May 20, 2019 at 3:42 PM
    #2937
    nd4spdbh
    SoCal
    does it get more solid than completely locked? Do they even make a trutrac that fits to replace the elocker diff?
    GT7 likes this.
  18. May 20, 2019 at 3:43 PM
    #2938
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I used my a-trac this weekend. I would NEVER do a mod to delete it. That is a priceless opportunity when your in a major offroad thing. I would have totalled my truck without it yesterday.
    Norton and 05Taco4x4 like this.
  19. May 20, 2019 at 3:45 PM
    #2939
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    I think the elocker doesnt do much for you on the street is the thing. You don’t want to be driving on pavement with it locked because it will make the diff very unhappy when trying to turn.
  20. May 20, 2019 at 3:50 PM
    #2940
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'm not sure. E locker is fucking amazing off road. Trutrac isnt as good but still great. Better as 99% of my driving is street dominance. But with lower gears this truck would be better. It dominates offroad .doest do justice but its known as the hill of doom. I made it down and up. 4 low, atrac, locker on 3k rpm, and made it. Polaris side by side took two tries. Me just one.
    TodayWasTHeDaY and BassAckwards like this.
