HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 22, 2019 at 9:51 AM
    #2981
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    No. I have them. But haven't installed them yet. Still running the TRD injectors that came with the blower.
  2. May 22, 2019 at 9:55 AM
    #2982
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Both banks ~+20%?
  3. May 22, 2019 at 9:57 AM
    #2983
    BillDaCat8
    Jake
    PHX
    Yes. You've seen my logs. They're like twins.
    JustDSM[QUOTED] likes this.
  4. May 22, 2019 at 11:36 AM
    #2984
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Mine was doing something similar after I installed my FIC injectors. It turned out to be that the o-ring on the supercharger lid had a crack in it. Sprayed brake cleaner all around the lid and it never acted like you would expect it to for having a leak.
  5. May 22, 2019 at 1:15 PM
    #2985
    BillDaCat8
    Jake
    PHX
    I will quadruple check the lid tonight. Although, I haven't fooled with it since the blower was installed. We'll see.
  6. May 22, 2019 at 5:13 PM
    #2986
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    @JustDSM definitely knows his sh&! but even cooler is his willingness to teach people!
  7. May 22, 2019 at 5:27 PM
    #2987
    Roostfactor
    TX panhandle
    Last week @JustDSM received a very reasonable labor rate from me. I figured its the least we can do to assist in this tuning movement! (I drank the beer :D)
  8. May 22, 2019 at 5:49 PM
    #2988
    JustDSM
    Justin
    Ogden, UT
    I owe @Roostfactor huge for his labor, parts, porting, meeting Eve, driving a highly modified S/C truck, and more!
  9. May 22, 2019 at 6:28 PM
    #2989
    Roostfactor
    TX panhandle
    I ask but of one thing dear NEO,...……….keep passing it forward as you have been!!! That is all the payment I need.
    P.S. Oh Eve!, yes very nice mod right there!
    5thGearPinned, RacecarGuy and deeezy like this.
  10. May 23, 2019 at 5:03 AM
    #2990
    5thGearPinned
    5thGearPinned Light Speed
    Texas
    2013 DCLB 4x4
    TRD Supercharger
    Eve was one for the ages, what a knock out.
    Justin, I’m so stoked on my tune. Huge thanks again!
    JustDSM and Roostfactor like this.
  11. May 23, 2019 at 9:16 AM
    #2991
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    This would be possible on the 3rd Gens, as the ECUs control the voltage, but the Alt-S circuit doesn't go through the ECU on 2nd Gens so it's not possible.
    mulisharydr[QUOTED] and JustDSM like this.
  12. May 23, 2019 at 9:50 AM
    #2992
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Still haven’t gotten a solution from hptuners. They insist I need to purchase credits even though I already have 4
    Edit update: somehow I believe it licensed loginfailed’s tune which has his VIN. So when trying to write the copied tune it refuses because I licensed his vehicle. Im still talking with hp to resolve it
  13. May 23, 2019 at 11:26 AM
    #2993
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I had a similar thing happen to me. Are you using the latest software? Did you download the standard version and then the beta version over that, then use the beta to write your tune?
    05Taco4x4 likes this.
  14. May 23, 2019 at 11:29 AM
    #2994
    GT7
    Grant
    Phoenix
    2013 DCLB
    No just the beta. It was working just fine.
  15. May 23, 2019 at 11:36 AM
    #2995
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I mistankenly used the standard version (before the standard version worked on Tacomas) and when I went to write JustDSM's modification of my tune, it didn't work, saying I needed to license the tune. When I wrote a ticket, they thought that I was using a custom tune and needed to license it, but didn't realize it was JustDSM's modification of my tune. When I downloaded the new software (standard version first, beta second and then used the beta to read and write), everything worked like it is supposed to. While you're waiting for an answer, might be worth a shot...
    JustDSM, 05Taco4x4 and Torspd like this.
  16. May 23, 2019 at 11:37 AM
    #2996
    GT7
    Grant
    Phoenix
    2013 DCLB
    Hm ok Ill give it a go tonight if they dont get me lined out before then
  17. May 23, 2019 at 11:53 AM
    #2997
    Todd_Kobell
    Todd_Kobell Well-Known Member
    Great Plains
    2010 Tim. Mica DCSB 4x4 SR5
    for someone who has ZERO experience with tuning, can someone break down what something like this from HPtuners could benefit me and my stock 2010 4.0? In other words, can I see some definitive HP gainzzz with JUST a tune?
  18. May 23, 2019 at 11:55 AM
    #2998
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    I don't think you would see much, if you had a supercharger I think it would make a good bit of difference.
  19. May 23, 2019 at 1:24 PM
    #2999
    Roostfactor
    TX panhandle
    @JustDSM is naturally asprirated and saw some gains from just a tune.
    Are you standard or auto?
    There are many things you are able to do even with a completely stock eng/trans. Adjust timing, throttle mapping, vvti, trans shift points and firmness to your liking and driving style, etc. I think there are mpg improvements to be had and there is definitely a lot of fine tuning to get YOUR truck running perfectly! No two engines are exactly the same and Toyota has to program the ecu for emissions, not power. With a good tune you can increase both.
    You can make your truck drive totally different than stock and tailor it to your liking!!! Throttle mapping alone can make your truck feel so much more responsive you would think someone put a bigger engine in it.
    Roost
  20. May 23, 2019 at 1:30 PM
    #3000
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Was waiting for someone with more knowledge to chime in on this. Well said.
