HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 28, 2019 at 9:10 AM
    #3081
    ThomasMore66
    Dallas/Fort Worth & Durango
    Oh, I got pro help. After @loginfailed had issues with his install I figured I had no business doing this on my own. Also, I had a vibration issue that I had convinced myself was the torque converter because we had been through all the normal drive-shaft angle, balance, etc. I figured the entire trans was coming out anyway. So, my mechanic installed the VB, performed a flush and then added some extra ingredient to the trans fluid. Vibe went away. Shifts were awesome.
    I did read all the instructions and figured if I had access to a lift it all seemed straight forward. I would not want to do it laying on my back.
  2. May 28, 2019 at 10:20 AM
    #3082
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I went from a $30 shift kit to a used trans for $1500 + $4500 IPT build. No biggie. :D
  3. May 28, 2019 at 10:31 AM
    #3083
    ThomasMore66
    Yeah, that's what I'm talking about. Makes my valve body seem rather cheap.
    loginfailed[QUOTED] likes this.
  4. May 28, 2019 at 10:53 AM
    #3084
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I ended up with what I originally wanted anyway. It ate up my Figgs reservoir budget, though. :boink:
    Roostfactor, Norton and GT7 like this.
  5. May 28, 2019 at 11:38 AM
    #3085
    ThomasMore66
    Now, that's a cheap little thing. All the cool kids have one.
  6. May 28, 2019 at 1:18 PM
    #3086
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    Okay, I'm a little lost here and there's a lot of pages to sort through. Cliff's Notes?
    1) Buy MPVI2 with 4 credits from HPtuners for my truck
    2) Create my own tune
    or
    3) Buy a tune from someone who has more free time/knowledge/patience than I do?
    Also, where are we at in terms of the naturally aspirated tunes? Better driveability, improved shifting, improved MPGs, etc.?
  7. May 28, 2019 at 1:59 PM
    #3087
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    You got it! This is the link i used, easy all in one place, a little discount, direct from Hinson https://www.ebay.com/itm/263889735544
    As far as NA tunes, most are rocking the @JustDSM tune better smoother power, more responsive due to throttle pedal mapping, and better mpgs under higher loads.
  8. May 28, 2019 at 2:52 PM
    #3088
    Capt. Obvious
    Darrick
    Gig Harbor
    '12 DCLB TRD
    @JustDSM are you selling your tune, or sharing it with the masses out of the kindness of your widdle heart? :)
  9. May 28, 2019 at 2:56 PM
    #3089
    nd4spdbh
    SoCal
    Send him a PM directly.
    JustDSM likes this.
  10. May 28, 2019 at 2:56 PM
    #3090
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    $50 Donation is all I ask. I leave it open to further tweaking and will be more than happy to work with you to dial it in specifically for your own vehicle should you like too.
    justdsm at gmail is my PayPal.
  11. May 28, 2019 at 2:57 PM
    #3091
    JustDSM
    Justin
    Ogden, UT
    Thank you. I do prefer PM's so we can work out the specifics and not clutter up the thread.
  12. May 28, 2019 at 3:13 PM
    #3092
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    Trust me, as someone who’s trucks been a little of a pain, the $50 to have @JustDSM to help you is CHEAP. If there was an award for someone who helps people the most, and is completely thorough with his “customers”, it’s him.
  13. May 28, 2019 at 4:00 PM
    #3093
    Lthompson
    Lthompson Well-Known Member
    what kind of vibes were you having? ive done several drain and fills, a flush, added lubeguard shudder stop, adjusted the lockup solenoid, replaced the trans mount.. Im pulling my hair out every time I drive it because of vibes.
  14. May 28, 2019 at 6:44 PM
    #3094
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I'll make you a JFR res @loginfailed :thumbsup:
  15. May 28, 2019 at 6:48 PM
    #3095
    Roostfactor
    TX panhandle
    Are you lifted? Check driveline angles and driveshaft carrier bearing.
  16. May 28, 2019 at 11:38 PM
    #3096
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Before that, the other thing!
    Roostfactor[QUOTED] likes this.
  17. May 28, 2019 at 11:48 PM
    #3097
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Fuck.
  18. May 28, 2019 at 11:49 PM
    #3098
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Water under the bridge, brother!
    Biscuits[QUOTED] likes this.
  19. May 28, 2019 at 11:50 PM
    #3099
    Biscuits
    I realize that, and I'm completely jealous, but still. Wow.
    Norton and loginfailed[QUOTED] like this.
  20. May 28, 2019 at 11:54 PM
    #3100
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Ain’t nobody got time for an A750 with no 5th gear. So I squeezed them lemons and made lemonade.
