HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. May 29, 2019 at 4:14 AM
    #3101
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Tremec has a phone app. Get it, and use your phone to calculate your Driveline angles. It will let you know if they need adjustment or not.
  2. May 29, 2019 at 5:03 AM
    #3102
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Thanks, I'll need that soon. Doing an axel and leaf spring swap soon. Bye bye lift blocks. Hello trutrac:)
    Torspd[QUOTED] likes this.
  3. May 29, 2019 at 5:22 AM
    #3103
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    No shit. Too bad t56 swaps are expensive
  4. May 29, 2019 at 5:59 AM
    #3104
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No shit. Lol
  5. May 29, 2019 at 6:10 AM
    #3105
    Sacrifice
    KS
    DCSB OR 4X4 LT
    You still planning awd ever? Or did i miss that?
  6. May 29, 2019 at 6:29 AM
    #3106
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Right now, I only have getting the Magnum in. However, with some recent developments the ability to make it AWD is much easier.
  7. May 29, 2019 at 7:49 AM
    #3107
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Finally got JustDSM to walk me thru pulling the stock file and uploading his tune... whole process took less than an hour... @JustDSM good lookin out, truck was wide awake on the drive to work this morning !
  8. May 29, 2019 at 8:18 AM
    #3108
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Going on a trip this weekend towing my lil jetski trailer and standup + a bunch o camp gear way up into the mtns. Going to be interesting to see what MPG's are like with more load on the truck!
    Also I have been rocking the same trans shift point changes the last week n a half 2 weeks and have been really liking them, smoothness is still 100% there, but the truck tends to hunt less and be in a more proper gear when you need it. I like it! After this weekends trip ill post up exactly what I have changes on trans shift points, you can get them all from my previous big post with the excel doc among other posts of mine but I dont think i have conglomerated them into one post yet.
  9. May 29, 2019 at 10:06 AM
    #3109
    ThomasMore66
    Dallas/Fort Worth & Durango
    It was a 1300-1500 rpm thing that I felt all the time in stop/go traffic. I had decided that it was a converter lock-up in/out issue, but I have zero issues now. All angles had been checked multiple times. Carrier bearing had been replaced. Drive shaft had been balanced.
  10. May 29, 2019 at 10:13 AM
    #3110
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Im starting get some stronger vibes above 65. Ill try a 1 piece driveshaft soonish
  11. May 29, 2019 at 10:22 AM
    #3111
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Apparently they have three offerings for the 750F. The first is a Nomad which the most common, the second is the extreme which is for higher torque engines that need maximum clutch pressures and may cause hard shifts, and the third is a FULL manual race valve body that does away will all electrical control.
    I just went with the same street able one you did. Hopefully I'll have it all together this weekend....I have a long ways to go with the entire interior out for an insulation project.
  12. May 29, 2019 at 10:52 AM
    #3112
    ThomasMore66
    I was going that direction, but now I'm glad I didn't. I think the trans needs to be serviced/flushed on a regular basis and Toyota has failed us with the "sealed" thing. Fluid looked old, but no metal or other debris in the trans. I was worried because I drove with a smaller pulley and no shift kit/valve body for a while.
  13. May 29, 2019 at 10:52 AM
    #3113
    ThomasMore66
    Yeah, I'd really like some Dynamat.
  14. May 29, 2019 at 11:02 AM
    #3114
    GT7
    Grant
    Phoenix
    2013 DCLB
    Fluid is relatively fresh. My drive line angle or tire balance is wonky or something. It wasnt as bad before I beat on the truck a little this last weekend
  15. May 29, 2019 at 1:00 PM
    #3115
    nd4spdbh
    SoCal
    head over to the driveline vibrations thread.... While i love all the well thought out tech talk, and i hate to be a debbie downer, but this is the HP Tuner thread, lets keep it close to that topic?
    EDIT - Luh you guys!
  16. May 29, 2019 at 9:51 PM
    #3116
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    You have to try the "other thing" out before I commit to fabbing one up for you :D
    Actually about the reservoir, I may make an integrated catch can/intercooler reservoir combo. It will simplify mounting and look cleaner. In time.....
  17. May 30, 2019 at 2:46 PM
    #3117
    nd4spdbh
    SoCal
    @HPTuners any info on this?
    1slow4.0 and JustDSM like this.
  18. May 30, 2019 at 2:49 PM
    #3118
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    That is degrees as in throttle blade angle.
    BillDaCat8 likes this.
  19. May 30, 2019 at 2:53 PM
    #3119
    nd4spdbh
    SoCal
    Then why would there be a value range of 0 - 100? Everything else i have seen referencing an actual degree angle of some kind has always been 0-90 range?
  20. May 30, 2019 at 2:55 PM
    #3120
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I'm back on a manual ECU!
    I can say without question there is less rev-hang with the auto ECU. In town driving can be a bit jerky though unless you're really quick with the shifts. After 2-3 weeks driving around on an auto ECU, I can understand why Toyota "engineered" the rev-hang. It's much more "comfortable" and "pleasant" to drive with the manual ECU in town/traffic.
    Oddly, the Auto ECU would always idle a little higher than targeted. Going back to the manual ECU, idle returned to targeted values.
    At this point in time, I'm sticking with the Manual ECU and will continue on with it.
    But manuals can run Auto ECU's and do so just fine. Probably no real reason to use one aside from the fact they're much more plentiful and cost less than the rare manual equivalent.
