HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 1, 2019 at 2:54 PM
    #3141
    ThomasMore66
    Dallas/Fort Worth & Durango
    You’re doing it wrong. Right foot goes further.
    nd4spdbh likes this.
  2. Jun 1, 2019 at 8:13 PM
    #3142
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Big thanks to @JustDSM. Just got some tuning done for my injectors. In today's tear down I noticed less gasket at the intercooler than I think should be. Truck must have got hungry. Can someone tell me if that foam gasket is supposed to be on the bottom and sides?
    garciav and JustDSM like this.
  3. Jun 1, 2019 at 8:43 PM
    #3143
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Yes, it should cover the intercooler on three sides.
  4. Jun 1, 2019 at 8:59 PM
    #3144
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Hmmmm. Well, I have about half that.o_O
    BassAckwards and garciav like this.
  5. Jun 2, 2019 at 6:18 AM
    #3145
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    @JustDSM have u got a tune for running the 650 injectors? Or atleast a close baseline
  6. Jun 2, 2019 at 7:21 AM
    #3146
    Jesse
    Poulsbo
    15' DCSB OR S/C
    He did mine yesterday. What a fun process.
  7. Jun 2, 2019 at 7:25 AM
    #3147
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @JustDSM even took the time to simulate how the truck would drive if the air injection failed. I took it for a short neighborhood drive. Damn, it cripples the truck with limp mode. So glad its gone.
  8. Jun 2, 2019 at 9:27 AM
    #3148
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Good, now give me my damn ECU back moocher! :D:D:D:D:D:D
  9. Jun 2, 2019 at 9:33 AM
    #3149
    Roostfactor
    TX panhandle
    I'm not planning on going back and I dont think anyone else that has switched to HP has any plans on going back and I know a few as well.
  10. Jun 2, 2019 at 11:22 AM
    #3150
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    I miss my truck, so I'm still lurking. Glad you got it all tuned up!
  11. Jun 3, 2019 at 2:08 PM
    #3151
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I need to install my 650s already:rolleyes:
  12. Jun 3, 2019 at 2:34 PM
    #3152
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Curious if anyone has seen how the 650 injectors run on the baseline TRD tune before tuning
  13. Jun 3, 2019 at 2:41 PM
    #3153
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    The truck runs about 40% richer than it should.
    BassAckwards and JacksonTacoma like this.
  14. Jun 3, 2019 at 2:43 PM
    #3154
    ThomasMore66
    Anybody with the 650's installed keep the fpr mod?
  15. Jun 3, 2019 at 2:44 PM
    #3155
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    no
  16. Jun 3, 2019 at 3:19 PM
    #3156
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    So i finally did a good drive with the @JustDSM VVTi tune (paired with my shift point changes) this past weekend...
    WOW talk about so much better driveability and welcomed power.
    This was for a camping trip, bed / back seats of truck LOADED to the max with all sorts of gear. Between the GF and all the extra gear in the truck itself, that was 800-1000lbs of stuff, then my jetski trailer @ ~500lbs, standup jetski @315lbs + 5gallons of extra gas @ 30lbs, + firewood 75lbs + easy up @30 = 950ish. So i was loaded half decent with around 1750-2000lbs of extra weight.
    The drive, From sealevel, up over the grapevine (4144ft) down to Bakersfield (essentially sealevel) back up to lake Isabella @ 2500ft. Total elevation gain of around 6700-7000ft (acounting for ups and downs) doing 65-70mph (shhhh dont tell CA LAW). Trip up I managed 18.6 mpg, and back was 18.0 (with a good chuck of around town driving and spelunking around the lake on the "back" tank).... THAT IS INSANE!!!!! If i was unloaded and just me in the truck doing those speeds thats the kinda MPG's I would be somewhat expecting / decently exited to get... but loaded n towing, unheard of in my past!!
    I got a few tweaks I would like to do to my trans tuning changes revolving around 4th gear TCC lockup / release. But overall DAYUM, so so much better as far as the truck not hunting as much for my driving style.
    Biscuits, Norton, Torspd and 6 others like this.
  17. Jun 3, 2019 at 3:22 PM
    #3157
    JustDSM
    Justin
    Ogden, UT
    Awesome feedback and sounds like an even more awesome trip. I need to get away from the keyboard and get back out under the sun. Inspiration.. :D
    Sounds like your shift point revisions have paired up well with the motor tuning!
  18. Jun 3, 2019 at 3:29 PM
    #3158
    nd4spdbh
    SoCal
    That it definitely has! And you definitely deserve some time out n about!
    JustDSM[QUOTED] likes this.
  19. Jun 3, 2019 at 3:45 PM
    #3159
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I did.
    Torspd and JustDSM like this.
  20. Jun 3, 2019 at 3:48 PM
    #3160
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Should I reverse the fpr mod?
