HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 4, 2019 at 11:04 AM
    #3181
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Any question you dont know the answer to is a valid question! It's why we all discuss things here. :D
  2. Jun 4, 2019 at 11:30 AM
    #3182
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I'm gonna have to read through this more.. been MIA lately due to work and traveling.. but definitely interested in whats going on in here.. :popcorn:
  3. Jun 4, 2019 at 11:41 AM
    #3183
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Look who came to play again!
  4. Jun 4, 2019 at 11:54 AM
    #3184
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    :wave: I'm just curious at this point really. I've been on the fence lately about changing up from the factory TRD tune.. simply due to the simplicity and safety of it. I have and still do beat on this thing.. and with all the sand drags, wheeling, pulling expo trailers, etc.. it has never failed me or given me any issues, and runs strong. just got back from a 2500 mile roadtrip LOADED down (full extra set of wheels, tools, camp gear for 2 people, personal gear, etc) up to the Sierra Nevada's and it ran great. I love feeling confident in it currently.. I just worry if I start changing things.. it may start acting up.
  5. Jun 4, 2019 at 11:59 AM
    #3185
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Honestly itll be just as reliable as the trd tune especially if ur setup remains the same. Better mpg....
    Torspd, 12TRDTacoma and BassAckwards like this.
  6. Jun 4, 2019 at 12:01 PM
    #3186
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Buy the hp tuner man. If you dont like it in a month I'll buy it from you and give it to a tw buddy. It's a great setup when properly dialed.
  7. Jun 4, 2019 at 12:04 PM
    #3187
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    My main reason for not jumping on board yet either. I fought my ucon for 6 months before it decided to cooperate. Now that its running good, i dont have the desire to go thru anything like that again
  8. Jun 4, 2019 at 12:05 PM
    #3188
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @JustDSM, did we remove my speed limiter?
    Had an odd rev limiter/speed limiter reaction this morning. On a closed course I got on it from 50 to who knows. Rev limited it shook the truck. Speed unknown. It happened fast.
  9. Jun 4, 2019 at 12:08 PM
    #3189
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I respect your decision. Without tuning help I never would have aborted trd tune. It's good and safe. But this truck runs perfectly now.
    BassAckwards[QUOTED] likes this.
  10. Jun 4, 2019 at 12:11 PM
    #3190
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I could be wrong but two ucon advantages are guardian feature, and on the fly calibrate for methanol. If I max things out for methanol tuning I'm in big trouble with any hiccups. So I use it as octane, cooling, and a safety net.
    BassAckwards likes this.
  11. Jun 4, 2019 at 12:15 PM
    #3191
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    We did. It's possible you hit the rev limiter. I know @loginfailed has had some "delay" in shifting causing a momentary bump onto the revlimter. Trans shift points can be adjusted to account for the delay it takes to shift now that you're spinning the motor up faster the transmission has less time to make the change.
    loginfailed likes this.
  12. Jun 4, 2019 at 12:18 PM
    #3192
    BassAckwards
    Yes sir, those are reasons 2 and 3 for why im still on that train.. Love the guardian feature, it's saved me countless times while i was having issues. The adaptives for meth are pretty cool too. Mine cuts about 15% fuel at WOT when the meth is spraying
  13. Jun 4, 2019 at 12:18 PM
    #3193
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I think I was in 5th. Think. The 5 or 6 rev limited hits caused the entire drivetrain to surge resulting in an odd shaking. I've never pushed speed until today. Wow, the torque this thing makes at freeway speeds is very impressive.
    TodayWasTHeDaY and BassAckwards like this.
  14. Jun 4, 2019 at 12:21 PM
    #3194
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Good reasons. You will yield the best rewards from that. I think ucon is a sweet setup.
  15. Jun 4, 2019 at 12:36 PM
    #3195
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    @JustDSM absolutely killing it again! Have there been any changes to your "baseline optimization tunes" since VVTi Changes?
    Also, look out for a revised ND4's auto shift helper excel doc sometime today with added TCC charts and some new shift point changes I am going to test after my longer drive this past weekend.
  16. Jun 4, 2019 at 12:40 PM
    #3196
    nd4spdbh
    SoCal
    Its actually quite a LONG time from when the ECU commands a gear till the trans actually shift on the auto. 1st to 2nd gear shifts are actually rather conservative, around the 5100rpm mark because things do spin up so quickly compared to other gears, which are closer to a 5400-5500 rpms.
    1slow4.0 and JustDSM[QUOTED] like this.
  17. Jun 4, 2019 at 12:52 PM
    #3197
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    So what all is involved then? I'm seeing talks of cam gears and injectors.
    I wouldn't mind leaning it out some.. to gain a few more ponies..
  18. Jun 4, 2019 at 1:01 PM
    #3198
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Buy the hp and be satisfied. All aftermarket changes are sweet adjustments. If anything get after @JustDSM for those gears before they're no longer available. My 3 cents.
  19. Jun 4, 2019 at 1:07 PM
    #3199
    nd4spdbh
    SoCal
    HPTuners MPVI2 + 4 universal credits + JustDSM tune.... and live it up. Gains on the supercharger TRD tuned trucks are pretty damn good apparently cus the TRD tune is so dog rich from the factory
    https://www.ebay.com/itm/HP-Tuners-MPVI2-Tuner-w-4-Universal-Credits-/263889735544
  20. Jun 4, 2019 at 1:14 PM
    #3200
    GT7
    Grant
    Phoenix
    2013 DCLB
    Hell come drive mine. Might make your decision easier. Dont have 4.56 tho
    Biscuits and XPOTRPR[QUOTED] like this.
