HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 4, 2019 at 8:05 PM
    #3221
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    This is awesome! Nice work, nd4spd. I may send you my current VVTi tune when I get to Oregon next week to change my values but only have enough time right now to sneak away from packing/loading to check this thread. Having 4th stay locked longer is one of the things I'm looking for.
  2. Jun 4, 2019 at 8:11 PM
    #3222
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    **Cam Gear Folks**
    Please see the latest announcement here: 165
    Biscuits and 12TRDTacoma like this.
  3. Jun 4, 2019 at 8:24 PM
    #3223
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    PM'd ya my email, take 15 min total from packing to send me your cal have me change the stuffs and flash the trans changes to the truck!
    DesertRatliff[QUOTED] likes this.
  4. Jun 4, 2019 at 8:33 PM
    #3224
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    And I shall. Truck runs so smooth!
    Roostfactor likes this.
  5. Jun 4, 2019 at 9:18 PM
    #3225
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @nd4spdbh I'm jealous of your tuning knowledge man. Thanks for being in this thread. I'm learning. 3* behind everyone else.
  6. Jun 4, 2019 at 9:45 PM
    #3226
    Jesse
    Poulsbo
    15' DCSB OR S/C
    In good time, with good cause greatness can be achieved. @JustDSM you're helping out. I'm patient for what's to be had. Thank you sir for the update.
    Roostfactor and JustDSM like this.
  7. Jun 4, 2019 at 9:49 PM
    #3227
    nd4spdbh
    SoCal
    Why thank you! But...
    I dunno about tuning knowledge, trans shift point changes are child's play compared to JustDSM's knowledge of fueling / ignition and VVTi and sheer amount of changes within those tables he did...
    The trans tuning is pretty easy once you wrap your head around how to make it do what you want it to do, that's why I made the Excel doc so I could see visually how changes would interact and be able to overlay them
  8. Jun 4, 2019 at 9:50 PM
    #3228
    JustDSM
    Justin
    Ogden, UT
    Your spreadsheet makes it easy! ;):hattip:
  9. Jun 4, 2019 at 9:53 PM
    #3229
    nd4spdbh
    SoCal
    I had to! I was shooting relatively blind without it. Gotta have the right tools to do the job!
    It's definitely made it much easier to see what im feeling in the truck and how I can change it.
  10. Jun 4, 2019 at 11:03 PM
    #3230
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Because regardless of proper size injectors or not, the fuel pressure regulator on the rail when boost referenced helps alleviate unwanted pressure in the fuel system and non 1:1 boost to fuel pressure rises caused by the blower while in boost.
    In an ideal situation you want a matching fuel pressure in accordance with the amount of boost being demanded at all times. As mentioned it helps equalize the fuel system so boost and fuel pressure are not fighting each other. It's like both systems are performing a handshake when you are referenced.
    Many manufacturers which offer a boosted setup from the factory have the FPR already configured in a boost referenced setup. There is a reason they do that.
  11. Jun 5, 2019 at 1:22 AM
    #3231
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Lower the shift rpm a little, raise the rev limiter, stop driving like a hoon or all three lol.
  12. Jun 5, 2019 at 2:55 AM
    #3232
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Typically... Shifting while in lockup is hard on the input shaft. The shock from the shift can shear the shaft unless it was designed for that. I don't what Toyota did for the input shafts but I've seen it happen on another brand...
    :anonymous:
  13. Jun 5, 2019 at 5:08 AM
    #3233
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I’d love to..... but I don’t have to balls to start tweaking that stuff plus I don’t have a lab top. My main focus would be to get rid of that cancer you guys have all dumped.
    Biscuits and BassAckwards like this.
  14. Jun 5, 2019 at 5:10 AM
    #3234
    ThomasMore66
    Dallas/Fort Worth & Durango
    Cancer?
    How does a person not have a computer in 2019? Dude, you’ve got to keep up. You don’t want to be the only old guy in the home that can’t online game.
  15. Jun 5, 2019 at 6:41 AM
    #3235
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I got a computer......not one I can take into my truck. Sai = cancer
    12TRDTacoma, Norton and BassAckwards like this.
  16. Jun 5, 2019 at 8:08 AM
    #3236
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Hp tuner is your oncologist.
  17. Jun 5, 2019 at 8:10 AM
    #3237
    nd4spdbh
    SoCal
    Big time! It would be like power shifting a manual, and even then thats easier on a trans cus clutch slippage. this is why the logic in the trans does not allow a shift while lockedup to occur
  18. Jun 5, 2019 at 8:51 AM
    #3238
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    For those running fpr mod. Why not do a one way valve to boost reference and NOT vacuum reference? Seems like that's the best of both worlds and is a super easy mod to do. I've ran mine this way since boost referencing without issue.
  19. Jun 5, 2019 at 8:54 AM
    #3239
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I plan on going to fpr now that I can tune for it. Thanks @JustDSM for the example tune. Will give me a nice baseline to tune from.
    12TRDTacoma likes this.
  20. Jun 5, 2019 at 9:01 AM
    #3240
    nd4spdbh
    SoCal
    Because there will be vacuum present at points unless you have modded the blower bypass. ? (i dunno i dont have a blower, *sad panda*)
