HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 5, 2019 at 9:03 AM
    #3241
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    No reason to.
    BillDaCat8 and 12TRDTacoma like this.
  2. Jun 5, 2019 at 9:09 AM
    #3242
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    You don't do the fpr to the blower bypass, it hooks up to where the boost gauge would hook into. A one way valve off the T at this point would allow the fuel rail to only see boost but never the vacuum.
  3. Jun 5, 2019 at 9:11 AM
    #3243
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Grow some balls and buy a laptop....problem solved and cancer free! :D
    Seriously, there are a lot of people here that will help you out for free, including @JustDSM. Or you can give him a small donation and he will remove any guesswork by refining a tune specific for your truck!
    For me personally, I want to tune my own truck so I can see and learn how changes effect each other. @JustDSM has helped me immensely in understanding the tuning process and I know I am only just beginning to understand.
  4. Jun 5, 2019 at 9:15 AM
    #3244
    Roostfactor
    TX panhandle
    :D Just got some Astro A40's and an Elite controller to do just that with my 15 yo. If he wont come spend time with me and my hobbies then I will adjust to spend time with him.
  5. Jun 5, 2019 at 9:20 AM
    #3245
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is no reason to do this if you are properly tuned the fuel pressure regulator mod will not cause you to go pig rich under part throttle instances and will run smoothly and correctly at idle.
    You'll love it man! My tune is so far left field now that I don't think it would be a good baseline for anyone here unless they were similar to my own mods. Lol.
    :rofl:
    Roostfactor[QUOTED] likes this.
  6. Jun 5, 2019 at 9:29 AM
    #3246
    Roostfactor
    TX panhandle
    @JustDSM sent me an example tune to start from so I will have a good baseline.
    I will most likely start by richening all the fueling values slightly then testing expecting it to be rich.
    Something to remember....rich is safe so start rich, then lean out incrementally for power.
    Rich doesnt throw engine pieces out of the block, lean can.
  7. Jun 5, 2019 at 9:33 AM
    #3247
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Correct, but the FPR is there to account for all intake pressures, if you have the one way valve in line the FPR will never open up under low boost, no boost, vacuum to allow fuel to flow back to the tank properly. Your way would essentially make the fpr almost fully closed in high boost mode the entire time.
    Roostfactor likes this.
  8. Jun 5, 2019 at 9:33 AM
    #3248
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Are you going to be doing a full tune on your own for learning purposes?
    I've always been okay with rich even if it's of the pig type. Not that it is desirable because it can foul out sensors, plugs, and the cat converters, but at least it wont cause a big fat boom while you are driving down the road. Lol.
  9. Jun 5, 2019 at 9:37 AM
    #3249
    Roostfactor
    TX panhandle
    How are you doing this? I had thought about this a bit months ago but never did pursue it.
    A one way check valve would hold boost pressure in the line so once you go into boost, fp would stay at the "referenced" pressure and never drop back down.
    How are you able to bleed the pressure back to atmospheric without dipping into vacuum?
  10. Jun 5, 2019 at 9:45 AM
    #3250
    Roostfactor
    TX panhandle
    I've been running my own tune since we got this little Genie!
    I had mucho help from @loginfailed and @JustDSM getting set up and have bounced around a lot of ideas with them.
    Outside of that, it's been playing with different values and seeing what results.
    I have two 5 hour datalogs from my last trip to AR! :D
    I know I'm a nerd but it's so cool to be able to see in real time how gas or other variables effects the data.
  11. Jun 5, 2019 at 9:53 AM
    #3251
    Roostfactor
    TX panhandle
    Exactly what I was thinking, just explained in a different way.
    How do you boost reference AND get pressure to drop back to atmospheric without also going into vacuum?
    A check valve would hold the highest "referenced" pressure and stay there which would essentially be a constant fp increase.
    nd4spdbh[QUOTED] likes this.
  12. Jun 5, 2019 at 10:25 AM
    #3252
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You are auto right? I'd be interested in seeing some shift point modifications and ultimately some line pressure increases to help aid tighter shifting on top of what us already with modded valve bodies have. That is about the only thing missing at this point.
    JustDSM likes this.
  13. Jun 5, 2019 at 10:31 AM
    #3253
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    You'll have mail here in a few min. Any chance you'll be able to try it "on the drive home?" and give me some feedback?
  14. Jun 5, 2019 at 10:39 AM
    #3254
    nd4spdbh
    SoCal
    from what i can tell at WOT you can maybe increase line pressures from 515/520ish to 540 ~4% ... but less that WOT you could definietly increase line pressures to possibly firm up shifts.
    Also as noted before, TRD Cal tunes are actually less in line pressures at lower throttle openings than the N/A counter parts.
  15. Jun 5, 2019 at 10:42 AM
    #3255
    JustDSM
    Justin
    Ogden, UT
    If you want access to my stock file repository to look at transmission stuff let me know. I think I've got just about all of the later models and some of the early trucks
  16. Jun 5, 2019 at 10:46 AM
    #3256
    Roostfactor
    TX panhandle
    Yes I am.
    12TRDTacoma[QUOTED] likes this.
  17. Jun 5, 2019 at 10:59 AM
    #3257
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ahh shoot. I would love to but thinking about it I think I left my laptop at home and wont be back home until late afternoon. Either way I'll be more than happy to test out the new file and get you some feedback, it just wouldn't be today. :)
  18. Jun 5, 2019 at 11:22 AM
    #3258
    nd4spdbh
    SoCal
    That would be cool! But from the TRD cal another member gave me (which has same max line pressures, just different - softer - shift curves), its looking like max line pressure for WOT shifts is pretty much already there. But maybe im looking at things wrong.
  19. Jun 7, 2019 at 10:25 AM
    #3259
    nd4spdbh
    SoCal
    OK. Im having a brain fart..... Im having a hard time wrapping my head around what Log's are saying as far as Throttle % (which seems to top out around 80.8 %) vs mapping that to throttle plate Degrees.
    In my head im seeing WOT accelerator pedal showing 100%, Throttle showing 80.8%.... 80.8 % of 84 max degrees throttle plate angle = 67ish deg, so not fully open?
    Maybe the logs are just showing a % unit instead of degress for the Throttle data point... 80.8 degrees would make more sense as thats way closer to the 84* max
    JustDSM likes this.
  20. Jun 7, 2019 at 10:31 AM
    #3260
    JustDSM
    Justin
    Ogden, UT
    I've struggled a bit with this as well.
    I've got some additional PID's unlocked on my Calibration ID that allow me to see the requested deg versus just percentages for our rev-hang testing.
    There's some oddities I recall observing in the logs in relation to actual degrees versus that PID's reported %. I don't remember specifically what they are off hand, but I can certainly pull up the log and look/refresh my memory. I surely need to do more logging with those PID's to get a better grasp on things.
