HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 7, 2019 at 10:35 AM
    #3261
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OK, so im not going crazy as i thought haha. I im curious as to how far the throttle plate actually opens, almost to the point of pulling off the intake and have someone hold it WOT (engine off obviously).
    I wish there was a Degree value within the logs, or an actual throttle plate percentage value, I would expect to see given throttle pedal mapping, when the accelerator pedal position is at 100%, so is the throttle position %.
    @HPTuners any insight on this?
  2. Jun 7, 2019 at 10:42 AM
    #3262
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    From memory, my logs showed 84deg at WOT. But.. My throttle mapping was set to a max of 86deg. I think there's additional mapping/modifiers/limiters in place that aren't currently defined.
    However, as you said, It would be helpful to add the PID's for all cals to be able to log throttle angle (in deg).
  3. Jun 7, 2019 at 10:46 AM
    #3263
    nd4spdbh
    SoCal
    Which would make sense to me have it set to 84* max and have it open to an allowed max of ~81 deg for a 3deg little buffer so it doesnt hurt the servo / plate / tbody housing due to overshoot. Thats why im wondering if it the Throttle position data point that currently displays in Percentage should really just be degrees.
    What PID did you use to get "actual degrees"?
  4. Jun 7, 2019 at 10:47 AM
    #3264
    OVTune
    OVTune Well-Known Member
    OVTune
    Minimum 0 maximum 85, above 85 will cause a fault,
    requesting throttle above....89.09 (I think!) on throttle tables = immediate throttle fault on start up.
  5. Jun 7, 2019 at 10:49 AM
    #3265
    JustDSM
    Justin
    Ogden, UT
    You can change where that fault value is. That was done as part of me changing to a 86deg max.
  6. Jun 7, 2019 at 10:55 AM
    #3266
    OVTune
    OVTune
    Curious why?
    Almost every DBW setup out there are usually limited to 0-85 or 0-89%.
    Going from 85 to 86 won't make any power, but the further you get from that 85 the higher chance of a throttle fault.
    If you are experiencing less throttle than you expect to get at full accel, check your load tables
    Biscuits and Torspd like this.
  7. Jun 7, 2019 at 11:04 AM
    #3267
    JustDSM
    Justin
    Ogden, UT
    Because I knew you'd ask why. :)
  8. Jun 7, 2019 at 11:07 AM
    #3268
    OVTune
    OVTune
    sigh.. ok.
    (not directed at justDSM).
    if the issue is throttle angle being reduced or not hitting target angle, changing fault angle limit is not the fix.
  9. Jun 7, 2019 at 11:12 AM
    #3269
    JustDSM
    Justin
    Ogden, UT
    Just so I understand, where was it suggested that changing the fault angle limit was the fix to throttle angles not reaching target?
  10. Jun 7, 2019 at 11:14 AM
    #3270
    nd4spdbh
    SoCal
    Thats the thing, i dont know what the actual throttle angle is as all loggable values within VCM scanner are percentages, none of which relate to the throttle plate angle in a percentage manor that would make sense at WOT
    If 81* is a demanded max standard allowed angle and absolute max being 84* (having a 3* buffer for overshoot), id expect to see some percentage related to Throttle Plate at 81/84 = 96.4ish% but that is not the case.
    Even without he motor running, you can hear the throttle plate open and close, but it will only ever show a % of 80.8-81.2 on my truck
    EDIT - im sure its opening up all the way and not a problem with the truck, just an issue with logging and data we are seeing out and how its being interpreted by HPTuner.
    JustDSM likes this.
  11. Jun 7, 2019 at 11:30 AM
    #3271
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think currently we do not have access to all of the load tables. (with HPTuners)
  12. Jun 7, 2019 at 11:46 AM
    #3272
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    How about unbolting the throttle and looking at it with the accelerator pedal pressed to 100%.
    Hacktacular[OP] likes this.
  13. Jun 7, 2019 at 11:52 AM
    #3273
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Just look at it.
    https://youtu.be/EF8GhC-T_Mo
  14. Jun 7, 2019 at 11:56 AM
    #3274
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    Stop using logical thoughts Torspd! Hahahaha
    Torspd[QUOTED] likes this.
  15. Jun 7, 2019 at 11:58 AM
    #3275
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    This.
    I can oversimplify anti-gravitational propulsion and nuclear fusion. Lol
    Biscuits likes this.
  16. Jun 7, 2019 at 12:29 PM
    #3276
    nd4spdbh
    SoCal
    JustDSM likes this.
  17. Jun 7, 2019 at 1:15 PM
    #3277
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    What’re you afraid of? Didn’t you used to say “redline a day keeps the carbon away”
  18. Jun 7, 2019 at 1:20 PM
    #3278
    nd4spdbh
    SoCal
    LOL not about to be looking down the throat of the beast WOT running.
    And you know me, I aint afraid to bang on revlimiter here n there on any of my vehicles.
  19. Jun 7, 2019 at 2:43 PM
    #3279
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So is it off yet? :boink::D
    12TRDTacoma, loginfailed and JustDSM like this.
  20. Jun 7, 2019 at 2:44 PM
    #3280
    nd4spdbh
    SoCal
    :rofl::rofl:
    ya know i can get away with quite a bit at work... but doing hood open work on my truck mid day.... eh, probably couldnt pull that off.
