HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 10, 2019 at 6:26 PM
    #3301
    Gunerbey
    Gunerbey Well-Known Member
    2015 Tacoma
    It stops you from engine braking smoothly, it'll abruptly slow down when it transitions to open loop mode though (feels the same as turning off the ignition while in gear) but only after some random amount of time at 0% throttle input. While shifting, assuming you've used the synchros to get it I to the next gear, when you release the clutch you have to do it relatively slowly or it'll jerk because the engine Rpms are way higher than they want to be. This makes day to day driving maddening compared to an old cable throttle. It's been so long now I've almost forgotten how satisfying it is to be able to properly shift as if you didn't even need to use the clutch. That's another thing that's damn near I possible to do. Shift without using the clutch. Bring Rpms up in gear, pop into neutral, Rpms stay high for some unknown amount of time, then they drop like a stone blowing past the target rpm so you have to blip the throttle up to the target rpm again. It's a constant battle.
    Norton, Biscuits and TodayWasTHeDaY like this.
  2. Jun 10, 2019 at 6:28 PM
    #3302
    Gunerbey
    2015 Tacoma
    @loginfailed according to mike sweers and another Toyota engineer I've talked to that is the case. You'll see it with many new, manual vehicles. Honda had a really hard time a while back because customers were pissed. They had to offer a different tune. Not sure how the emissions were dealt with.
    12TRDTacoma, BillDaCat8 and Biscuits like this.
  3. Jun 10, 2019 at 6:37 PM
    #3303
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I'm sure there's some sort of default overrun angle for the throttle blade in the ECU somewhere. Maybe HP Tuners will find it eventually.
    Biscuits likes this.
  4. Jun 10, 2019 at 8:04 PM
    #3304
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    It’s not just wide open up shifts either. Just normal driving. First to second gear. And then second to third. Shifting at like 2500 rpm. Push in the clutch, switch to third gear and then keep holding the fucking clutch until the motor slows down enough for a smooth shift. SOFA KING annoying!
    I’ve always owned manual trans cars. Side-draft carbureted Datsuns, MR2’s, Mini Coopers etc. Even the wife’s 14 Clubman shifts like a dream. Give me a direct link to the throttle and I can shift them just fine. This truck tho. Ugh!
    I refuse to just “get used to it” It’s wrong. It’s evil. It needs to die.
    I beg of you Chris @HPTuners I’m really begging here. PLEASE!
    There’s definitely something VSS related to the problem. I read somewhere that someone using different logging software was seeing another mode flashing in and out. Something between open/closed loop and OL drive. Can that be true? “BS emission mode” maybe?
    Norton, GT7, Gunerbey and 3 others like this.
  5. Jun 10, 2019 at 8:32 PM
    #3305
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Been known about for year and there was no "cure", minus alleviating the shuttle valve on the side of the manual transmission. Only helps with half of the problem.
    For those that don't know, there is a shuttle valve removal thread.
    I love my Haltech and its pure throttle control. :D :boink:. You guys will get there though.
  6. Jun 10, 2019 at 8:37 PM
    #3306
    ThomasMore66
    Dallas/Fort Worth & Durango
    And about the 4-5 shift flare on autos... way tired of that.
  7. Jun 10, 2019 at 8:45 PM
    #3307
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Sounds like driving an old Detroit Diesel. First thing is to slam your hand in the door and drive it pissed off. :bananadead:
  8. Jun 10, 2019 at 11:57 PM
    #3308
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    One could always force the engine slow down faster, electrically.
    Relay + RPM switch + timer.
    Example:
    If clutch pressed & RPM > X = Cut power to coils for X seconds.
  9. Jun 11, 2019 at 2:57 AM
    #3309
    Gunerbey
    2015 Tacoma
    @loginfailed a product called qrevs does something like that except it cuts power to the injectors based on throttle position and Rpms.
  10. Jun 11, 2019 at 3:12 AM
    #3310
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Injectors would work better since there’s no extra fuel being wasted. What website sells them?
  11. Jun 11, 2019 at 3:18 AM
    #3311
    Gunerbey
    2015 Tacoma
  12. Jun 11, 2019 at 3:26 AM
    #3312
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I don’t see a price or a link to purchase it there. I’ll read through it again later, maybe I missed it.
  13. Jun 11, 2019 at 3:33 AM
    #3313
    Gunerbey
    2015 Tacoma
    It's a case by case basis as in built to order. You have to send him an email. Super nice guy though.
  14. Jun 11, 2019 at 6:55 AM
    #3314
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    I always thought my truck felt like a tractor rig in stop and go traffic, never really new why, this explains it... I do have the torque-u heavy flywheel in my truck and the only way i can get smooth shifts when getting after it is by blipping the throttle on upshifts... anyone else do this ?
  15. Jun 11, 2019 at 7:11 AM
    #3315
    BillDaCat8
    Jake
    PHX
    That thing was yanked years ago. I revamped the mechanical stuff completely at that point. Updated the pedal, master, pivot ball, slave, and the clutch itself. I even did the fancy stainless sleeve on the quill t/o bearing for good measure. Works great. But, not the problem here. The current programming of the ecu IS.
    I ran haltech in my 510 back in the day. Worked great. Was still running a cable with that setup tho.
    Torspd[QUOTED] likes this.
  16. Jun 11, 2019 at 7:21 AM
    #3316
    Gunerbey
    2015 Tacoma
    @BillDaCat8 what did you do for the pedal? Mines floppy like a rabbit ear and has even been replaced by the stealership complete with new bushings.
  17. Jun 11, 2019 at 7:27 AM
    #3317
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    A lightweight flywheel might serve you well sir
    TodayWasTHeDaY and Norton like this.
  18. Jun 11, 2019 at 7:31 AM
    #3318
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I wondered if this might mitigate the the dreaded rev-hang.
    BassAckwards[QUOTED] likes this.
  19. Jun 11, 2019 at 7:38 AM
    #3319
    BassAckwards
    I have one in mine and it seems to have helped some. If anything, its another option to try in a mechanical sense before trying to chase it down electrically in the ECU.
    Norton[QUOTED] likes this.
  20. Jun 11, 2019 at 7:38 AM
    #3320
    Gunerbey
    2015 Tacoma
    There's no way it a heavy flywheel for a couple reasons.
    1: when it's cold there is no rev hang at all.
    2: when you do wait long enough the Rpms drop like a stone very suddenly right as it changes fuel strategies.
    3: while in gear there is no engine braking sensation of course until #2 happens. Even with a monster flywheel you would still feel it trying to slow the vehicle down, albeit, a little sluggishly. Try switching your ignition off while moving in gear, it's a totally different sensation than the rev hang but closer to what one would expect for engine braking a manual.
    Biscuits, Torspd and Norton[QUOTED] like this.
