HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 11, 2019 at 7:47 AM
    #3321
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Must be a TRD tune issue, i have none of that on my truck.
    Is it under part throttle or WOT?
    12TRDTacoma and 1slow4.0 like this.
  2. Jun 11, 2019 at 11:16 AM
    #3322
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    My man. :cheers: You're ahead of the curve.
    12TRDTacoma likes this.
  3. Jun 11, 2019 at 9:08 PM
    #3323
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    There’s a TSB. I don’t have all the info currently. But, basically you install all the late 2nd gen stuff. Master, pedal, spring, all new bushings, etc. I pulled the entire maternal fornicator out, bracket and all. Then, assembled it on the bench. Slave cyl and pivot ball also get changed. So, tranny out, etc...
    EDIT: See attachments
  4. Jun 12, 2019 at 9:59 PM
    #3324
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Holy smokes I just read through a hundred and sixty seven pages!! I’ve had my Mag. S/C sitting in storage for almost 2 years waiting for something like HP Tuner capability to come out. They wait maybe over for S/C install!!
    Biscuits, 05Taco4x4, JustDSM and 9 others like this.
  5. Jun 12, 2019 at 10:05 PM
    #3325
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Time to void another warranty!
    Biscuits, 05Taco4x4, JustDSM and 2 others like this.
  6. Jun 12, 2019 at 10:10 PM
    #3326
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    Warranty. Boooo.
    BassAckwards and 12TRDTacoma like this.
  7. Jun 12, 2019 at 10:22 PM
    #3327
    12TRDTacoma
    Rob
    Concordia
    Boosted
    About time you join the club. Welcome!
    SonnyBones[QUOTED] likes this.
  8. Jun 12, 2019 at 10:27 PM
    #3328
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have owned a lightweight flywheel before. While there was a small difference in quickness of revs I would not say it was immensely notable. To say it would mitigate rev hang on these trucks would be sort of a stretch if I'm being totally honest. Of course if someone proves me wrong I would gladly retract this statement. Lol.
    Norton[QUOTED] likes this.
  9. Jun 13, 2019 at 5:41 AM
    #3329
    HPTuners
    HPTuners Well-Known Member
    Can someone please confirm the rev hang issue for manual trans only occurs in 1,2,3 gear
  10. Jun 13, 2019 at 5:50 AM
    #3330
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Great question
  11. Jun 13, 2019 at 7:00 AM
    #3331
    BillDaCat8
    Jake
    PHX
    I’ve seen it between 3-4 and 4-5 when accelerating hard to get onto the freeway and the like. Pretty sure it’s not just in the lower gears.
    Gunerbey and Norton like this.
  12. Jun 13, 2019 at 7:04 AM
    #3332
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  13. Jun 13, 2019 at 7:12 AM
    #3333
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Concur. I believe it's present across all gears, though less noticeable beyond third, where you don't generally wind the RPMs as high or shift as quickly.
    Curious to get @JuanitoBunito's take on this too...
  14. Jun 13, 2019 at 7:57 AM
    #3334
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I’d definitely say all gears....most notable in 1, 2, 3,..... and 4, 5, and 6 when accelerating hard such as merging on the freeway.
    Norton likes this.
  15. Jun 13, 2019 at 7:58 AM
    #3335
    ThomasMore66
    Dallas/Fort Worth & Durango
    Hey buddy! You're still checking in on us.
  16. Jun 13, 2019 at 8:33 AM
    #3336
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
  17. Jun 13, 2019 at 10:38 AM
    #3337
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  18. Jun 13, 2019 at 11:09 AM
    #3338
    BassAckwards
    Been wanting an X. that'd be the one to buy. Too bad i cant afford it :(
    Hacktacular[OP] and Biscuits like this.
  19. Jun 13, 2019 at 11:18 AM
    #3339
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Built right. Great kit. Great tune with the Haltech Elite 2500. I think it has 660 or 800 ccm injectors. From URD.
    Could fairly easily be changed to use the HP Tuner.
  20. Jun 13, 2019 at 12:10 PM
    #3340
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I heard Cadillacs are better
