HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 15, 2019 at 3:18 AM
    #3361
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    @HPTuners of topic question. Any idea on when the 2019 tundra will be avalible to tune? Just ordered one.
  2. Jun 15, 2019 at 4:43 AM
    #3362
    HPTuners
    HPTuners Well-Known Member
    Same as 2018, until Toyota release an update we cannot support them since we haven't worked out how to read the flash directly from the processor on these newer PCMs. It took about a year before they released an update for the 2018.
  3. Jun 15, 2019 at 4:59 AM
    #3363
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I’m looking forward to this. I’m fairly certain a Tundra will be replacing the Taco at some point in the future.
  4. Jun 15, 2019 at 5:08 AM
    #3364
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    Get both like me lol. I’m trading my 2010 in for a new one. Got the x runner for a sports truck. Best of both worlds. Just don’t no if I want to mod the tundra like the xrunner.
  5. Jun 15, 2019 at 5:19 AM
    #3365
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Well, technically the Taco won’t be going away. But my son will be likely be getting a nicely modded Taco for his 16th birthday.
  6. Jun 15, 2019 at 5:22 AM
    #3366
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    And then you both drive to Coffee and Cars?!?!
  7. Jun 15, 2019 at 5:31 AM
    #3367
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Damn! That’s awesome
    05Taco4x4 and 12TRDTacoma like this.
  8. Jun 15, 2019 at 7:07 AM
    #3368
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I hadn’t considered that, but it is a great idea!
  9. Jun 15, 2019 at 9:30 AM
    #3369
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    So one thing I'm still curious about is how this will play with upgraded valve body's. With all this talk about shift points and rev hang, I'm wondering if having my IPT valve body will have negative affects or combat the advantages of the HP tuner.
    Biscuits and loginfailed like this.
  10. Jun 15, 2019 at 9:33 AM
    #3370
    GT7
    Grant
    Phoenix
    2013 DCLB
    Does great with em. Rev hang for the manuals
    XPOTRPR[QUOTED] likes this.
  11. Jun 15, 2019 at 9:46 AM
    #3371
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Oh yeah I forgot you had a valve body too!
    And yes for manuals.. mines an Auto but i just wanted to check if there was any other things that might not mesh just in case.
    GT7[QUOTED] likes this.
  12. Jun 15, 2019 at 9:49 AM
    #3372
    GT7
    Grant
    Phoenix
    2013 DCLB
    I like mine. I need to use @nd4spdbh fancy spread sheet this weekend and make some changes
    Biscuits and XPOTRPR[QUOTED] like this.
  13. Jun 15, 2019 at 9:55 AM
    #3373
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It works amazingly with the modified valve body. No issues.
    Manuals do not get valve bodys.
    Biscuits likes this.
  14. Jun 15, 2019 at 10:13 AM
    #3374
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I know this.. lol
  15. Jun 15, 2019 at 11:11 AM
    #3375
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I have the complete IPT built trans and torque converter. Everything works as expected.
  16. Jun 15, 2019 at 12:09 PM
    #3376
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    @JustDSM let me know when you can hook me up with the rev hang delete tune!!
    may be time for me to dump the torq-u heavy flywheel and go back to stock...
  17. Jun 15, 2019 at 12:12 PM
    #3377
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    You do have a point. Manufacturers try and implicate delays as not to destroy drivetrain. Glad to here there's a solution for my 3 pedal buddies!
  18. Jun 15, 2019 at 2:10 PM
    #3378
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I just re-read your first post. I really gotta stop reading and posting while I'm at work and trying to speed reply lol.
    I am also! They have needed some love for a long long time. :thumbsup:
  19. Jun 15, 2019 at 2:11 PM
    #3379
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    nah you're good man. I should have phrased it better. :thumbsup:
    12TRDTacoma[QUOTED] likes this.
  20. Jun 15, 2019 at 2:16 PM
    #3380
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Just a random shout out to @JustDSM amongst all of you guys I want to say thanks for making my truck scream. Couldn't imagine this without ya'll. Big thanks.
