HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 25, 2019 at 10:41 AM
    #3481
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Previous posts about off-highway racing made by me in this thread have been edited. I in no way condone or promote the removal of factory installed emissions equipment on street legal vehicles operated on the highway.
    Because Race Truck.
    12TRDTacoma, Biscuits and JustDSM like this.
  2. Jun 25, 2019 at 10:53 AM
    #3482
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Maybe we need an extra credit to unlock offroad use only parameters...
  3. Jun 25, 2019 at 12:03 PM
    #3483
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    This... my truck is for snow days and play.
    I’ll sign whatever waivers are needed.
  4. Jun 25, 2019 at 12:17 PM
    #3484
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    This is what I was discussing the other day, guys. HP Tuners has to protect themselves and this is how that plays out.
  5. Jun 25, 2019 at 12:41 PM
    #3485
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Question, if you have a 05-08 tacoma with UCON, how do you make it work with HPTuners ? if you pull the UCON you can't load the TRD reflash to those ECU's right ?
  6. Jun 25, 2019 at 12:46 PM
    #3486
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    From the reports I've seen, the UCON is not happy if you use HPTuners in the background to tune things like throttle mapping (@BassAckwards could tell you more). However,
    You can pick up a spare ECU from a wrecking yard, have that flashed to a TRD Calibration ID and keep your stock ECU with a N/A Calibration ID should you ever need to revert back.
    Or just have your current ECU flashed to TRD spec if you're not concerned with going back to a N/A setup.
    ..Or flash your current ECU to TRD spec, and use a window switch to control your ACIS valve and rock the expanded ignition/VVTi tables if you're one who likes to live on the edge.
    BassAckwards and garciav[QUOTED] like this.
  7. Jun 25, 2019 at 12:48 PM
    #3487
    garciav
    Houston, TX
    TRD SC,HPTuners
    I was under the impression that you could not load a trd calibration ID to a ECU that was pre 08, and the only way to get the supercharger to work was to run UCON ?
  8. Jun 25, 2019 at 12:50 PM
    #3488
    JustDSM
    Justin
    Ogden, UT
    That would be news to me. But I won't claim to be the expert on that subject.
    If that's the case however, I'd make an adapter harness and run a 2009 ECU with a TRD/HPTuners modified tune.
  9. Jun 25, 2019 at 12:51 PM
    #3489
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I did not know this.
    There are calibrations for 08- starting on page 55:
    http://toyotaparts.sparkstoyota.com/install/PTR29-35120inst.pdf
  10. Jun 25, 2019 at 12:54 PM
    #3490
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Yep, i can confirm, you cannot flash the ecu with the UCon still plugged into the stock ecu. Youll need to separate them, plug in the stock ecu, flash it with HP, and then take it out and put it back in with the UCon.
  11. Jun 25, 2019 at 12:55 PM
    #3491
    JustDSM
    Justin
    Ogden, UT
    Sounds like fun!
  12. Jun 25, 2019 at 12:56 PM
    #3492
    BassAckwards
    Lol it sucked, but it was worth it to ditch the SAI stuff. Would do it again in a heartbeat if i needed to!
  13. Jun 25, 2019 at 12:58 PM
    #3493
    JustDSM
    Justin
    Ogden, UT
    Did you use the throttle mapping?
    BassAckwards likes this.
  14. Jun 25, 2019 at 1:00 PM
    #3494
    BassAckwards
    No sir i did not.. went back to stock because i was having an issue with the SAI max throttle angle being limited.. went back to stock because (to isolate the problem) and i didnt want to separate the UCon from the ecu to flash it and then have to do it again if the throttle mapping didnt work with UCon. Wish i wouldve known better looking back, but itll get done eventually, just trying not to mess with anything right now since the trucks running good for once
    JustDSM[QUOTED] likes this.
  15. Jun 25, 2019 at 1:03 PM
    #3495
    garciav
    Houston, TX
    TRD SC,HPTuners
    Friend of mine has a 07 tacoma mexican spec. When he installed his TRD supercharger the dealer couldnt load the calibration file, something about the ID's not matching up.. he opted out for UCON, but im wondering if it was bc of an ECU from a foreign truck ?
  16. Jun 25, 2019 at 1:07 PM
    #3496
    JustDSM
    Justin
    Ogden, UT
    If he still has it, I'd love to know what his Calibration ID is.
    loginfailed and garciav[QUOTED] like this.
  17. Jun 25, 2019 at 1:12 PM
    #3497
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    They had a different calibration file for my pre 08 model FJ, the calibration files were updated in LATE 08. It would be news to me to say that the TRD calibration couldn't be loaded on an 07 or earlier.
  18. Jun 25, 2019 at 1:15 PM
    #3498
    JustDSM
    Justin
    Ogden, UT
    Could it be that he'd have to flash from a early N/A Cal ID, to the current prior to attempting the TRD cal flash since Techstream would be looking for the current N/A cal ID? Hmm.
  19. Jun 25, 2019 at 1:41 PM
    #3499
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    In the manual I posted above, it shows the calibration ID that Techstream needs to see before it will flash to the TRD cal.
  20. Jun 25, 2019 at 1:42 PM
    #3500
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Always fun getting rid of the UCON. :D
