HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jun 25, 2019 at 1:43 PM
    #3501
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I think it's up to 5 or 6 that have told me that ;)
    TRON, BillDaCat8 and BassAckwards like this.
  2. Jun 25, 2019 at 3:41 PM
    #3502
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Was going to wait until I had a full tank through to provide a comment on MPG numbers, but I'll have to follow up with that.
    I have been running the @JustDSM N/A base tune optimizations since Friday and it's made me look forward to driving my truck more than any other modifications I have made. Even with much more spirited driving than normal I am on pace to match or exceed my normal miles per tank.
    I don't care if it's not actually making higher peak #'s - the truck feels lighter and drives like I've always felt it should. This is how the 6-speed should have felt from the factory (well it should have had the taller FJ 6th gear, but I digress).
    I'm so hooked I've ordered cam gears and am looking forward to seeing the results.
    Thanks JustDSM!
  3. Jun 25, 2019 at 3:59 PM
    #3503
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    Awesome, be careful though... it’s a slippery slope. Don’t ask how I know :confused:
  4. Jun 25, 2019 at 4:08 PM
    #3504
    smelly621
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    Oh, I've tumbled down it before. Still have a spare TDI long block in the garage I've been trying to sell. At least my current Tacoma has a Toyota motor in it still. ;)
  5. Jun 25, 2019 at 4:20 PM
    #3505
    JustDSM
    Justin
    Ogden, UT
    I'm so happy to hear you're enjoying it!! :D Thank you for taking the time to post your thoughts and experience.
    DiamondW likes this.
  6. Jun 25, 2019 at 5:23 PM
    #3506
    Halligan
    Halligan Old School
    Cam
    BC Canada
    2015 DCSB Gearjammer
    OME 887s, OME Dakar Heavys, 265/70/17's, Truetrac, 6sp manual
    So I’ve ordered HP tuner but haven’t received it.... can someone confirm weather or not the throttle crack adjustments are present or not?
    It’s the main reason I ordered it.
    DiamondW and JustDSM like this.
  7. Jun 25, 2019 at 5:32 PM
    #3507
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yup they are there in the beta software, even on my auto's calibration! (though speed is set to 150mph so it doesnt do anything)
  8. Jun 25, 2019 at 5:35 PM
    #3508
    JustDSM
    Justin
    Ogden, UT
    It's present, and functional.
  9. Jun 25, 2019 at 5:43 PM
    #3509
    Halligan
    Halligan Old School
    Cam
    BC Canada
    Thank goodness.
    Cheers guys.
    BillDaCat8 and JustDSM[QUOTED] like this.
  10. Jun 25, 2019 at 11:04 PM
    #3510
    JustDSM
    Justin
    Ogden, UT
    For folks who have either been tuned by me, or need to collect datalogs for me. Please use the following channels config. file for general purpose logging when sending me logs. If you're conducting testing/etc. for me, please use this config file as well unless I provide you an alternate prior to testing.
    Unzip to the following directory:
    \Documents\HP Tuners\VCM Scanner\Channel Configs
    Once you have the "TacomaworldGeneral.Channels" installed in the above directory, you'll want to open your VCM Scanner and locate the "Channels" tab. Open the tab and locate the yellow folder with a gear. Open that and select the TacomaworldGeneral.Channels file.
    ***You'll want to add in any Widebands or external sensors if you are logging those***
    This will set-up your VCM Scanner to collect the data required to make corrections.
    seedy_tea, kcasner, Norton and 5 others like this.
  11. Jun 25, 2019 at 11:13 PM
    #3511
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Some of the new pid hawtness? (I’m on the ipad not the pc tonite. Can’t see.)
    JustDSM[QUOTED] likes this.
  12. Jun 25, 2019 at 11:18 PM
    #3512
    JustDSM
    Justin
    Ogden, UT
    Yes sir! These include some of the new PIDs. I don't need to see all of the ones released, but the good stuff is in there :D
    DiamondW and BillDaCat8[QUOTED] like this.
  13. Jun 25, 2019 at 11:23 PM
    #3513
    BillDaCat8
    Jake
    PHX
    Reminds me. I need to get you some recent logs. Was hoping you could glance at my data and perhaps sprinkle a bit of yer magic.
    I’ll futz with the laptop in the morning and load up the new config.
  14. Jun 25, 2019 at 11:25 PM
    #3514
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I may need a walk-through on the phone on what to do again. After all, like anything, tech saavy skills are a perishable skill. ;)
  15. Jun 25, 2019 at 11:26 PM
    #3515
    JustDSM
    Justin
    Ogden, UT
    I've got some new part throttle enrichment sauce that's tasting pretty good.
  16. Jun 25, 2019 at 11:26 PM
    #3516
    JustDSM
    Justin
    Ogden, UT
    You've got my #!
    12TRDTacoma[QUOTED] likes this.
  17. Jun 25, 2019 at 11:27 PM
    #3517
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Part throttle enrichment settings (NON PE!) tested and approved!! @BillDaCat8 :thumbsup:
    JustDSM likes this.
  18. Jun 26, 2019 at 4:41 AM
    #3518
    DiamondW
    Kent
    Gonzales Co. TX
    Sweet, something to play with while I’m at work. I’ll get them loaded tonight so I can play.
    BassAckwards likes this.
  19. Jun 26, 2019 at 4:53 AM
    #3519
    DiamondW
    Kent
    Gonzales Co. TX
  20. Jun 26, 2019 at 7:03 AM
    #3520
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I compared the copy of this file you sent me yesterday to the one you sent last month and, unsurprisingly, found several changes. I assume we should use the latest/newest version this file and no need to keep old versions, unless otherwise instructed?
