HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jul 11, 2019 at 7:23 PM
    #3661
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    He is fine. His time is simply occupied by other responsibilities currently.
    Please no one send extra pm's as it will only take more of his time when he gets back to us.
    Just trust that all is good with him but his focus is elsewhere (for now).
    Thanks,
    Roost
    nd4spdbh, Norton, Wild Heart and 3 others like this.
  2. Jul 14, 2019 at 8:58 PM
    #3662
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Trans temps are similar to any other reordered numbers of mine, simply because i almost ALWAYS make sure im in lockup in 4th or 5th, I hate running in non lockup in 4th or 5th at speed (HWY speeds) under load... temps just get out of hand way way too quick regardless.
    That stated, the v10 trans tune + 2nd revision of my ACIS changes (which i will post about in full detail tomorrow) has made it to where I dont have to baby the truck under those circumstances nearly as much to get it to stay in lockup. Just got home from a total of 1150 miles of loaded down driving, and I gotta say this last revision of my trans tune was the ICING on the cake. Being able to pull rolling hills in 5th lockup the entire time with a bed and cab full of camp gear, while towing a trailer with a Honda Grom and a Kawi 650sx standup jetski was awesome. Also being able to hold 4th gear lockup at 65-70 up the backside of the grapevine (4k ft elevation gain in not many miles) in 104*F heat was indeed AMAZING to help trans temps stay under control.... as even with being in lockup, due to coolant temps and ambient temps being way up... trans temps were up around the 200*F mark as well.
    FYI.... the VCM Scanner software already has both trans pan (Tran Fluid Temp) and torque converter output (Trans Fluid Temp B) available in the channels.
    Glad to hear he is OK as in still standing on this earth, what ever he is going through is WAY WAY more important than us here on tacomaworld. I hope he comes out from whatever is going on in his personal life OK. There is NO rush to get back to us!
  3. Jul 15, 2019 at 4:21 AM
    #3663
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Ill be putting your trans tune in when i get a chance (this latest one if your uploading it) i despise having to baby it to watch trans temps. If i could use 5th a little more without having to watch temps all day, thatd be great
  4. Jul 15, 2019 at 9:29 AM
    #3664
    nd4spdbh
    SoCal
    Ill try and get V10 up today all in one post so you can get my latest with the much more aggressive 4th n 5th lockup. Id HIGHLY recommend it over v9!
  5. Jul 15, 2019 at 9:39 AM
    #3665
    Sacrifice
    KS
    DCSB OR 4X4 LT
    I havent loaded any trans tunes :anonymous: im out of town anyways. No rush for me
  6. Jul 15, 2019 at 9:49 AM
    #3666
    nd4spdbh
    SoCal
    hahaha sounds good
  7. Jul 15, 2019 at 10:35 AM
    #3667
    ThomasMore66
    Dallas/Fort Worth & Durango
    Different with a supercharger?
  8. Jul 15, 2019 at 11:03 AM
    #3668
    nd4spdbh
    SoCal
    No different with or without super. The logic of the NA vs TRD tune as far as shift points and tcc lockup are identical stock. The only thing different between the two is the Stock TRD calibration actually applies LESS pressure to gear clutch packs than the stock NA tune... yes, LESS, which could be the cause of some of the flare the supercharger guys are seeing.
    Murphinator likes this.
  9. Jul 15, 2019 at 11:37 AM
    #3669
    nd4spdbh
    SoCal
    Alrighty, V10 as promised.
    V9 here - https://www.tacomaworld.com/threads/hp-tuners-for-2005-2015.600793/page-161#post-20781692
    The changes from v9 to v10 are in the following areas:
    • 5 to 4 downshift
      • Increased DS rpm in mid throttle area to get rid of a wacky dip, this brings the 5 to 4 downshift in those mid bulk-of-the-driving throttle range closer to when it pops out of lockup
    • 4th tcc release
      • Doubled negative values to hold onto 4th lockup WAY longer and get it closer to the 4 to 3 downshift
    • 5th tcc release
      • Essentially doubled values as well to hold onto 5th lockup A LOT longer vs stock which pairs well with the increased 5 to 4 downshift
    After doing 1150 miles of driving in the last 6 days while loaded full of camp gear + motorcycle and stand up jetski on a trailer, the much more aggressive lockup is SOOOO WELCOMED. Rolling hills are tackled with much less popping out of lockup, and cruise control behaves a lil better now due to it (unfortunately we cant fix cruise logic)
    Also note, these changes are made for my truck, essentially a stock truck: mild 2in lift, 265/75R16's and sliders. The shift points themselves (mainly upshifts) are tailored to my desire of a smooth driving grandpa truck...we can DEFINITELY get more aggressive with upshifts to hold onto a gear way longer, those with bigger tires and or gearing changes would probably benefit more from being more aggressive with upshift changes and that is something I can work on if someone wants to be my guinea pig!
    As always, feel free to ask questions, hit me up, tag me, quote me, pm me etc etc!
  10. Jul 15, 2019 at 11:52 AM
    #3670
    ThomasMore66
    Have you ever had 4-5 flare?
  11. Jul 15, 2019 at 1:03 PM
    #3671
    nd4spdbh
    SoCal
    I have not, but the NA tune even stock has higher gear pressures than the TRD tune in the lower throttle openings and obviously has less power without a supercharger. But could see how it could occur with a super and the TRD cal especially in those taller gears which require more clamping pressure.
    Im working on shift pressures and will get that out soonish.
  12. Jul 15, 2019 at 1:13 PM
    #3672
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    loginfailed likes this.
  13. Jul 15, 2019 at 1:49 PM
    #3673
    ThomasMore66
    loginfailed and BassAckwards like this.
  14. Jul 15, 2019 at 3:40 PM
    #3674
    nd4spdbh
    SoCal
    Yeah.... it has something to do with the Logic of the TRD cal, but id be curious if changing gear pressures to at least what the NA cal has, if not my conglomeration of pressures of the NA cal across the board would help or solve the issue.
  15. Jul 15, 2019 at 7:07 PM
    #3675
    ThomasMore66
    I’d like to try this. A bit timid because I don’t want to break anything and I’m clueless on the trans. You’re a pioneer. @JustDSM changed a couple of things and it’s very crisp now.
  16. Jul 15, 2019 at 7:39 PM
    #3676
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    It’s not a mechanical problem. It is related to the TRD calibration. Mine never did it with the NA ECU combined with the UCON. As soon as I started running the TRD flash the flare started.
    Mine actually hasn’t done it in a long time since I added 10% to an area of cells in the OTT table.
  17. Jul 16, 2019 at 6:01 AM
    #3677
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Sorry, haven't super payed attention to this thread, did HPTuners fix the rev hang on a 6 speed? Should be getting a new axle in the truck semi soon...looking into this tuner more and more now :D
  18. Jul 16, 2019 at 6:14 AM
    #3678
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    It has been deleted and can also be adjusted if desired. It is awesome.
    Also recommend the clutch accumulator delete.
    https://www.tacomaworld.com/threads...nkier-than-5speed.606032/page-2#post-20592628
    https://www.tacomaworld.com/threads/05-tacoma-clutch-shuttle-valve-removal.376677/#post-19738014
    Norton likes this.
  19. Jul 16, 2019 at 6:22 AM
    #3679
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    I had the same thing occur. I'm almost at the point of going for a transmission rebuild to get rid of the flare.
    If it is indeed TRD tune related, using this HP Tune widget can help get rid of it?
    loginfailed[QUOTED] likes this.
  20. Jul 16, 2019 at 6:39 AM
    #3680
    VolcomTacoma
    Jeff
    NorCal
