HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 5, 2019 at 6:30 PM
    #3881
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    That's exactly what's happening.........
    Ok till you hit a hill...
    I wonder if the cruise uses the torque based throttle maps? I changed those a lot to get full throttle. Because the cruise is way more abrupt than stock...
    I think my trans mods are very similar to the ones you made and the trans is working really good, just shifting slow...
  2. Aug 5, 2019 at 6:56 PM
    #3882
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    It moves better now with throttle mapping than before :laugh:
  3. Aug 5, 2019 at 9:15 PM
    #3883
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    What did you change in those maps and why? Post up a screen shot?
  4. Aug 5, 2019 at 9:20 PM
    #3884
    nd4spdbh
    SoCal
    I'll definitely work with ya to get a trans tune that fits you! My V10 tune fits what I want out of MY truck (not super aggressive shifting and maintaining lockup lots longer in 4th n 5th, on a truck with 265/75s 2in lift and minimal armor... Aka near stock) which may or may not suit your needs. Definitely feel free to hit me up and we can start at one point, go to way the other side and then find a happy medium!
    1slow4.0 likes this.
  5. Aug 5, 2019 at 9:21 PM
    #3885
    nd4spdbh
    SoCal
    I'll tune your trans how you want for your b-day present!
  6. Aug 5, 2019 at 10:07 PM
    #3886
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Awesome! She is heavy (5400lbs) so that might change things up a bit.
  7. Aug 6, 2019 at 4:55 PM
    #3887
    shr133
    Muskego, WI
    2010 V6 Sport
    Some how those maps are use for throttle control. My throttle position logs were very rounded and wouldn't stay at full throttle. So I made the maps much more aggressive so full throttle is more instant and holds steady. So my logs are sharp straight lines. Don't think it's any faster, but I know I'm getting full throttle. I don't see a transient fuel map, so opening the throttle faster may not help much, for now.
    But the ECU may use those maps for other things, like cruise control or traction control, so I'm just testing it out...
    Ultimately that will be in my Dune Map..
  8. Aug 6, 2019 at 6:29 PM
    #3888
    ThomasMore66
    Dallas/Fort Worth & Durango
    So I bought the pro link and pro features. The pro features get activated with my MPV12?
  9. Aug 6, 2019 at 6:47 PM
    #3889
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    you sound as confused as I am. where do I start to get educated on this? or is there no hope for me?
    Norton likes this.
  10. Aug 6, 2019 at 7:36 PM
    #3890
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    I can't fully remember but I did have to resync the interface (under the help tab) on the VCM scanner and probably the editor as well after I upgraded. The mvpi2 has to be plugged in while doing so.
    Norton likes this.
  11. Aug 6, 2019 at 7:37 PM
    #3891
    ThomasMore66
    That makes sense.
  12. Aug 6, 2019 at 7:47 PM
    #3892
    nd4spdbh
    SoCal
    Interesting, my truck has always shown 100% throttle when i stab it regardless with sharp edges.
  13. Aug 6, 2019 at 7:48 PM
    #3893
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    man I can imagine. I re-geared to 4.56 and I still find its lacking.
    snowsk8air2 and S.B. like this.
  14. Aug 6, 2019 at 8:35 PM
    #3894
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    5.29 or bust
    nd4spdbh likes this.
  15. Aug 6, 2019 at 8:50 PM
    #3895
    Jesse
    Poulsbo
    15' DCSB OR S/C
    humbly I ask is there a way one can self teach the ins and outside of hp tuning? I feel like an idiot here and want to understand this. I know its specialized but I want to hang with the cool kids. help plesae....
  16. Aug 6, 2019 at 10:13 PM
    #3896
    nudavinci64
    Robert
    If i was going to 37's id be all in on that. I was conservative with the 285's going with 4.56 but should have known 4.88's. last minute change and regret it. will happen eventually. The SC has consumed me now.
  17. Aug 6, 2019 at 10:14 PM
    #3897
    nudavinci64
    Robert
    I second that. I need to get on board and would be great to know how to tune it.
  18. Aug 6, 2019 at 10:29 PM
    #3898
    nd4spdbh
    SoCal
    Lots have been looking to JustDSM for engine tuning, then changing things on the auto trans side of things either with the help of the info i have provided or just spelunking on their own.
    Norton and nudavinci64[QUOTED] like this.
  19. Aug 6, 2019 at 10:36 PM
    #3899
    nudavinci64
    Robert
    yah may go that route at first as well. Seen him pop up a bunch for tuning help. Need to read up more on the HPT side of things and see what you have suggested. Have not picked up a HPT setup yet.
  20. Aug 6, 2019 at 10:56 PM
    #3900
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It is an internal limitation of the PCM which is why once PE has begun the system goes into open loop, it is simply not capable of handling AFRs past the reported 11.7-11.9 AFR.
    If you were to take a factory Toyota WRAF (AFR) sensor, and plug it into an AEM UEGO or X-Series gauge (theoretically, assuming the plug would fit), you would find it is capable of reading much MUCH lower than the OE PCM. Similar to the UCON and X-1 the circuitry to handle and read out the higher and lower voltages the sensor is capable of reading out is better utilized on dedicated AFR gauges.
    nd4spdbh, BassAckwards and Norton like this.
