HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 6, 2019 at 11:44 PM
    #3901
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    well tried to write to the truck tonight, after you turn the key off for 10 sec and then on it tried to write for a sec and an error message popped up and said "error timeout". now the throttle body buzzes and won't start and it won't connect to the ecm anymore, also my scan guage wont connect either. leaving the batt disconnected for the night, but think she fucked. ill be opening a ticket.
    GT7 likes this.
  2. Aug 7, 2019 at 12:14 AM
    #3902
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Try disconnecting all the plugs from the PCM behind the glovebox and leave them unplugged for like an hour. That'll drain all the internal capacitors without a doubt. Also pull the PCM fuse I believe it is IGN 1 along with those plugs.
    S.B.[QUOTED] likes this.
  3. Aug 7, 2019 at 7:09 AM
    #3903
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    yes, justin has been my guy. I'm just trying to self educate.
  4. Aug 7, 2019 at 7:57 AM
    #3904
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I am 4.88 on 37s and it is perfect for me. I am an AT and the highway cruising is perfect. I am close 6k lbs and get 15-16mpgs at 80mph, 2250 rpms.
    Taco box is next in lieu of 5.29 for me.
  5. Aug 7, 2019 at 8:23 AM
    #3905
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Yeah taco box would be nice. I’m 4.56 and planning on 37’s. Figure when the time comes I’ll jump to 5.29. Truck isn’t my daily so I’m not super concerned about hwy rpm
  6. Aug 7, 2019 at 8:46 AM
    #3906
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    uh oh thats not good. Hopefully a full discharge of the PCM / truck does the trick.
    I always make sure, that blower is off, radio if off, bluetooth off on phone so a call doesnt come through the radio, all lights are off on the truck, key turned to run and let the electric boosted master cylinder pump up the accumulator (TRD OR 4x4 things). Let the truck sit for 30 secs, tap the brake pedal again so the accumulator pump does its thing one more time so it doesnt run in the middle of a flash. Laptop is above 50% charge and has been on for at least 5 min for all the software bits of windows to do their thing, windows updates paused. Plug in the MPVI2 and get everything up ready to write. Click write, wait for it to ask for it to turn the key off for 10 secs, flip the key off and let it beep 10 times, turn key on let it beep 3x click ok and walk away, dont touch or breathe on the truck! haha. I have flashed, god, probably 30-40 times without an issue. *fingers crossed, knocks on wood*
    Hawk373 and Norton like this.
  7. Aug 7, 2019 at 8:54 AM
    #3907
    S.B.
    Sean
    San Diego
    15 Taco
    Yup, did pretty much all of that (no electronic booster). As soon as it turned the key back on from being off the 10seconds, almost immediately gave the error. Didn't have time this morning to mess with it.
  8. Aug 7, 2019 at 8:57 AM
    #3908
    nd4spdbh
    SoCal
    Faaawwwwwk.
    What version of the VCM suite are you using?
    Help -> About within either VCM Scanner or VCM Editor (or in control panel -> programs and features)
  9. Aug 7, 2019 at 9:28 AM
    #3909
    S.B.
    Sean
    San Diego
    15 Taco
    Which ever the current one was about a week ago, I'll look when I get home
  10. Aug 7, 2019 at 9:30 AM
    #3910
    OVTune
    OVTune Well-Known Member
    OVTune
    unplug the battery for 10-15 mins, then try to start the truck.
    If you're lucky it will start up. If not the ECU is likely bricked.
    Torspd likes this.
  11. Aug 7, 2019 at 10:02 AM
    #3911
    S.B.
    Sean
    San Diego
    15 Taco
    Tried that last night, no luck. Figured to let it sit overnight, but yeah.
  12. Aug 7, 2019 at 10:04 AM
    #3912
    nd4spdbh
    SoCal
    Cool deal please report back the full version number.
  13. Aug 7, 2019 at 10:07 AM
    #3913
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    Is bricked totally f#cked? I wonder if techstream could fix it by trying to reflash with it. If not, seems like its a problem that if solved could make someone a bit of profit.
  14. Aug 7, 2019 at 10:11 AM
    #3914
    nd4spdbh
    SoCal
    Maybe? One would have to have access to the original cal file from toyota.
  15. Aug 7, 2019 at 10:11 AM
    #3915
    OVTune
    OVTune
    usually with these ECUs bricked means you open it up and start soldering to the NBD and recover it the hard way. via CAN is dead.
    S.B. and mightytacoman like this.
  16. Aug 7, 2019 at 10:23 AM
    #3916
    S.B.
    Sean
    San Diego
    15 Taco
    This, techstream can't do shit.
    I've flash hundreds of vehicles with techstream (gotta love recalls...), Then I do my own with this hptuner and shit goes south.
    Torspd and mightytacoman like this.
  17. Aug 7, 2019 at 1:35 PM
    #3917
    ThomasMore66
    Dallas/Fort Worth & Durango
    Whoa. I've always known it was possible, but this is a first in this thread.
  18. Aug 7, 2019 at 1:44 PM
    #3918
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Not a first :anonymous:
  19. Aug 7, 2019 at 2:07 PM
    #3919
    S.B.
    Sean
    San Diego
    15 Taco
    Ever find the reason why it happened?
  20. Aug 7, 2019 at 2:15 PM
    #3920
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    It was a loose pin in the obd2 port for me. Intermittent connection
    Torspd and S.B.[QUOTED] like this.
