HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 8, 2019 at 10:09 AM
    #3941
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I'll be making a case with hptuner about it. If credits registered to the VIN then once you write the VIN ( through techstream) then it should work
    For the immobilizer you short 2 pins on the obd port for 30mins with key on, that registers the immobilizer with the ecm
  2. Aug 8, 2019 at 10:15 AM
    #3942
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeahhhh, even tho i havnt had issues with flashing *knocks on wood* Im gonna look into keeping a voltage supply to the truck while doing so. Ill do some testing this weekend with key on and see how much draw we are talking with everything off.
    Musubi3 and Norton like this.
  3. Aug 8, 2019 at 10:16 AM
    #3943
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Everytime I hook my battery up to a running vehicle
    snowsk8air2 and nd4spdbh[QUOTED] like this.
  4. Aug 8, 2019 at 10:23 AM
    #3944
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    ....moving the subject away from brick'ing :D
    Is there anyone working on a 91/93 octane tune? Don't recall seeing it, but I could have missed a page,,, or 12.
  5. Aug 8, 2019 at 10:41 AM
    #3945
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Were you able to get tuned up since you got the MPVI2? Just curious.
  6. Aug 8, 2019 at 10:46 AM
    #3946
    nd4spdbh
    SoCal
    Not sure. The timing strategy of our 2nd gens is pretty neat in the fact that its pretty darned good at self advancing. There are likely gains to be had but possibly not much!
    Edit - Speaking of timing, for us auto guys... what do the tuning gurus think of reducing the spark retards for up and downshifts? Stock its pulls like 25* of timing, considering reducing everything by 25ish%?
  7. Aug 8, 2019 at 11:56 AM
    #3947
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    See this for @loginfailed's post on how to pair the ECU/Immobilizer: 330
    loginfailed and Norton like this.
  8. Aug 8, 2019 at 12:01 PM
    #3948
    JustDSM
    Justin
    Ogden, UT
    Your HPT license is to the VIN and Calibration ID.
    If you brick your ECU, source a replacement, Use a Mongoose/Tactrix OpenPort 2.0 Cable to reset your VIN via tools available with a TIS subscription and you'll be able to tune from there without having to spend an additional 4 credits.
    S.B.[QUOTED] and Norton like this.
  9. Aug 8, 2019 at 12:03 PM
    #3949
    JustDSM
    Justin
    Ogden, UT
    I've worked up 86/87 and 91/93 tunes out there. I'm sure others have worked stuff up too.
    Torspd likes this.
  10. Aug 8, 2019 at 12:20 PM
    #3950
    S.B.
    Sean
    San Diego
    15 Taco
    When I get this sorted, I'll be contacting you for your tune
  11. Aug 8, 2019 at 12:48 PM
    #3951
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I have what I need to get started, but I haven’t done it yet. Life keeps getting in the way. :annoyed:
    I do need to check in with JustDSM on a 91 tune though, just for fun. But I do want to go in some order though, JustDSM 87 tune first, then add nd4spdbh trans mods, then a 91 tune. I’ll get to it though.
  12. Aug 8, 2019 at 1:13 PM
    #3952
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Dude. You live in Texas. 93 octane! More timing = more powa!
  13. Aug 8, 2019 at 1:29 PM
    #3953
    nd4spdbh
    SoCal
    Must be nice... get 93 octane for probably a dollar cheaper than i can get lovely e10 87 here in cali.... that awesome gas makes gains via spark kinda hard....
  14. Aug 8, 2019 at 1:36 PM
    #3954
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    ~$2.86 or something like that recently.
  15. Aug 8, 2019 at 2:01 PM
    #3955
    nd4spdbh
    SoCal
    :censored::censored:
    Anyways, anyone have thoughts on reducing spark retard on shifts for the autos? Always felt like it dropped way to much power between shifts on these trucks.
    Turdyota3000 likes this.
  16. Aug 8, 2019 at 2:34 PM
    #3956
    S.B.
    Sean
    San Diego
    15 Taco
    Cool, that's what I was thinking
  17. Aug 8, 2019 at 5:35 PM
    #3957
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Very true, but you don’t have to travel all that far before it turns to 91, and I hate planning and retuning that far ahead.
  18. Aug 10, 2019 at 9:10 AM
    #3958
    nd4spdbh
    SoCal
    For NA Just tune for the octane you use the most. If that's 91/93 awesome, and then don't worry if you get somewhere n have to run less... The way these trucks work as far as knock detection is pretty damned good so it will pull timing where needed.
    It is interesting in looking at stock calibrations. 12+ trucks work off of a KCL initial value of 14* and work their way up, 11- trucks work off a KCL init value of 21* and work their way down. Also their knock detection retard amounts are more linear on the 12+ trucks. This was likely due complaints of knock on the early trucks.
    Hawk373, 1slow4.0 and Torspd like this.
  19. Aug 10, 2019 at 11:41 AM
    #3959
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Is there enough range in the adjustment to run 87 if there is a 91 tune in? My assumption was no, but your description sounds like I may be wrong? ...again... :D
  20. Aug 10, 2019 at 3:19 PM
    #3960
    nd4spdbh
    SoCal
    From what i can tell yes. There is a low octane map, high octane map base and base limit maps for timing. Honestly not sure how they interact. But with the range a KCL value can be i dont see why you couldnt optimize timing maps for 91 / 93 and run 87... You will undoubtedly have a good chunk less in performance vs an optimal tune on 87. But the knock sensors and logic is there to keep the motor happy n safe.
    Lurkin[QUOTED] and 1slow4.0 like this.
