HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 10, 2019 at 4:26 PM
    #3961
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Found the problem. I have a diode in with the alt-s fuse, so bat at 12.5, but ecm getting 12.0. So mystery solved.
    05Taco4x4 and KTM753 like this.
  2. Aug 10, 2019 at 4:40 PM
    #3962
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    ooof, that will do it. Im sorry dude!
  3. Aug 10, 2019 at 4:42 PM
    #3963
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Thanks, this gets more and more interesting. :thumbsup:
  4. Aug 10, 2019 at 4:46 PM
    #3964
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Can it? Yeah. Would I do it? Nope.
    But that’s me.
    Edit:
    If you want to run it on 86/87, tune it for that. If you know what you’re doing, you can set it up to take advantage of the 91/93 when you run it. But I would NOT tune it for 91/93 and rely on the knock control to dial the timing back for use on 86/87.
  5. Aug 10, 2019 at 4:49 PM
    #3965
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Tell me more. I doubt I would unless I had to, but am curious as to the capability or not.
  6. Aug 10, 2019 at 5:11 PM
    #3966
    JustDSM
    Justin
    Ogden, UT
    The capability and how adaptive the system is really comes down to the calibration and how it’s calibrated. It’s quite flexible, but still has limitations.
  7. Aug 10, 2019 at 7:39 PM
    #3967
    nd4spdbh
    SoCal
    Correct. I wouldn't be running a 91/93 tune and running 87 on the regular... That stated I wouldn't have a problem putting 87 in on a 91/93 tune for one tank here n there if absolutely necessary.
    1slow4.0 and JustDSM like this.
  8. Aug 10, 2019 at 7:50 PM
    #3968
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    I ran @JustDSM n/a 87 tune with 91 with no issues. His 87 tune runs really well and I like it very much but there is definitely more pep with the 91 tune! My truck just runs so much smoother with the 91 tune.
    JustDSM likes this.
  9. Aug 10, 2019 at 10:32 PM
    #3969
    S.B.
    Sean
    San Diego
    15 Taco
    Live and learn. All in all wasn't that expensive of a lesson, hopefully won't have to buy 4 more credits
  10. Aug 11, 2019 at 7:23 AM
    #3970
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    think i just bricked mine too :(
  11. Aug 11, 2019 at 7:45 AM
    #3971
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    https://thetuningschool.com/
    I know they dont have toyotas but they have excellent beginner courses. Im looking at getting the GM for beginners for my camaro.
    https://forum.hptuners.com/forum.php
    Some very good info on here as well.
  12. Aug 11, 2019 at 8:06 AM
    #3972
    nd4spdbh
    SoCal
    correct. Id have no problem running higher octane on the regular than a tune was designed for. Its not going to be quite as optimized as it would be if it was tuned for 91/93 but its going to run better.
    But like stated if you were tuned for 91/93 and were forced to run 87, i wouldnt have a problem... but i wouldnt be doing any WOT pulls!
  13. Aug 11, 2019 at 8:07 AM
    #3973
    nd4spdbh
    SoCal
    oh shit.... what happened? What Software version?
  14. Aug 11, 2019 at 10:56 AM
    #3974
    nd4spdbh
    SoCal
    Whelp..... @HPTuners you got some problems with your software / internet check cus i just bricked my truck too. Everything was proper, battery charged >12.5v, truck was just running no issues. Went through the same procedure as i always have done ... this time, got about 4-5% and poof, write error: time out.
    FAWWWWWK.
    So to get me back up and running.
    1. Buy ecu on ebay for my truck
    2. put in
    3. resync imobilizer
    4. have dealer change vin number?
    FYI. This was on Beta 4.5.407.0 which i had previously flashed a tune to the truck a few days ago (before the two others bricked their truck) without issue.
    @S.B. @mightytacoman
    EDIT - @HPTuners ticket #182304 submitted.
    EDIT 2 - SO PISSED RIGHT NOW.... truck was running just fine and i literally was changing some trans torque management timing tables for kicks n giggles. sigh.
  15. Aug 11, 2019 at 11:09 AM
    #3975
    S.B.
    Sean
    San Diego
    15 Taco
    Well shit!
    Yeah, with teachstream you can write/rewrite the VIN
    I guess the diode on mine wasn't the only problem...
    nd4spdbh[QUOTED] likes this.
  16. Aug 11, 2019 at 11:30 AM
    #3976
    JustDSM
    Justin
    Ogden, UT
    The USB cable between the computer is really pretty fragile. I’ve had issues with mine from all the toting around from all the tuning I’ve done.
    I noticed that mine would recognize the connection but the slightest tweaking/movement of the USB cable would cause a break in the connection intermittently. And that is enough to brick.
    I’d recommend giving the USB a thorough check.
    I have a cable I ONLY use for flashing and another that I use for transport/general use/etc to keep my flashing USB cable pristine.
  17. Aug 11, 2019 at 11:54 AM
    #3977
    mightytacoman
    Kel
    4.5L 1grfe
    Bricked mine with the latest version. I download it right before and it happened earlier today. 12.9 V prior to flash.
  18. Aug 11, 2019 at 11:54 AM
    #3978
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    Yikes. There has to be a better way to do this no? Maybe someone can make some heavy duty usb cables? I want an hptuner but sure as hell don’t wanna brick my ecu :eek:
    Norton, Musubi3 and JustDSM like this.
  19. Aug 11, 2019 at 12:24 PM
    #3979
    S.B.
    Sean
    San Diego
    15 Taco
    For me the USB cable is brand new/the one it came with, highly doubt that that's the problem
  20. Aug 11, 2019 at 12:24 PM
    #3980
    JustDSM
    Justin
    Ogden, UT
    It's a USB-A to USB-C cable.
    When I noticed mine had some connection issues, I picked up the standard replacement from Summit Racing (as they're in "my neighborhood", and in stock) but truth be told, I'd suggest finding a heavier duty cable to use between the MPVI2/Computer as you mentioned.
