HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Mar 25, 2019 at 7:07 PM
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    It is a limitation of the OEM ECU not having flex fuel capabilities from the factory. If the vehicle is flex fuel ready, then it can be used. By the way, it is only 299 for the mpvi2 plus 4 credits @ 50 each so 499 for engine and trans tuning capabilities isn't bad IMO. If I could do E85 I'd be trying this out. I may try it out just to tinker...
  2. Mar 25, 2019 at 7:29 PM
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Maybe the pro feature set isn’t really necessary, I just thought it would be nice to be able to log my widebands and fuel pressure sensor.
  3. Mar 25, 2019 at 8:02 PM
    Hacktacular
    Robert
    Then go pro. 749 plus tax all in.
    Biscuits, Roostfactor and loginfailed like this.
  4. Mar 28, 2019 at 12:47 AM
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    Well I just bought one, ill share some screen shots once I get it. It should be here Saturday.
  5. Mar 28, 2019 at 5:29 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Can't wait to hear some results.
    Norton and loginfailed like this.
  6. Mar 28, 2019 at 5:40 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    Sub’d, I wanna see some numbers.
    Would also be nice if I could use it on my 3UZ-FE
  7. Mar 28, 2019 at 5:52 AM
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    While it may not be flex fuel capable you can run E85 by using appropriately sized injectors, and then using the injector scaling function to bring the trims back to normal. In my prior EVO/Subaru days this was how we did it. It was common to run 1000cc/min injectors on ~400-430whp cars with injectors scaled back to near stock numbers. You can then calibrate the open loop fuel and ignition tables to meet the needs of your engine package.
    If you ever need to run pump fuel due to E85 availability or whatever, you can simply convert back to a calibration that is set-up for pump fuel. While not as convenient as flex-fuel capable, with a little work on the laptop you can effectively do it manually should that be an option.
    I'm extremely excited this came out.
    eljedi68, RA77, lilgerber and 7 others like this.
  8. Mar 28, 2019 at 12:58 PM
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    :spy::spy:
  9. Mar 28, 2019 at 3:57 PM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    To those of you with tuning experience (I have none)
    If starting with a TRD flash and HP Tuners, how complicated will it be to get the ECU to run with 640cc instead of the the 455c injectors?
  10. Mar 28, 2019 at 8:16 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Depends completely on the software.
  11. Mar 28, 2019 at 9:07 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  12. Mar 29, 2019 at 5:52 AM
    JustDSM
    Justin
    Ogden, UT
    Much like Torspd said, it depends on the software. But the little experience I have with HPtuners fiddling on friends vehicles I can confidently say it'll be a simple change getting the injectors scaled back. Since we're virtually breaking new ground with this kind of access to our ECU it's going to take a little fiddling to fine tune your injectors unless you have the response data (latency) on your injectors. Each make and model of injector has a different latency. There is a table (2D) in the ECU to define that opening delay based typically on voltage.
    You typically can make a gross adjustment with the injector scaling function, getting the trims dialed in 90% of the way which will allow you get out and drive/further tune. Simply doing this will get you back on the road however, you'll generally notice that your trims wander a bit and this is a result of the factory injectors having a different response curve compared to the new injectors. Tweaking or simply inputting the mfg. supplied data in VCM Editor software will complete tune the larger injectors.
    Hope that helps somewhat. I've the HPTuners setup ordered and will be happy to help anyone in the DFW area with dialing in their trucks.
  13. Mar 29, 2019 at 6:10 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Appreciate the info. I’m planning to get rid of the UCON and go back to the TRD flash. I’d rather keep the larger injectors. Sounds like from what you’re saying that I can at least get it running and then tune it further from there.
    I’ll be looking forward to hear your thoughts once you get yours and have a chance to try it out.
  14. Mar 29, 2019 at 6:22 AM
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    This is all I have for the injectors I'm running. Maybe I can find the actual tables if I dig some more.
  15. Mar 29, 2019 at 6:32 AM
    #35
    redtaco2007
    redtaco2007 Well-Known Member
    2007 Red Tacoma - TRD Off Road DCSB
    not much yet!
    Oh man. I really hope we can get someone with an NA setup on a dyno soon, with this tuner, to see what kind of gains can be made!:D:D
    TacomaSport86 likes this.
  16. Mar 29, 2019 at 6:38 AM
    #36
    JustDSM
    Justin
    Ogden, UT
    Your wish will be granted my friend.
    I have a 2015 6spd N/A with a custom intake using a Volant scoop and stock airbox and a URD Spec-U Exhaust. Which will be tuned using HPTuners. Don't expect anything in immediate future, I promise you it's coming!
    sloshy, zerotimeouts, TAC1 and 7 others like this.
  17. Mar 29, 2019 at 8:21 AM
    #37
    redtaco2007
    not much yet!
    :bananadance::bananadance::bananadance::bananadance::bananadance::bananadance:
    :burnrubber:
    JustDSM[QUOTED] likes this.
  18. Mar 29, 2019 at 8:29 AM
    #38
    JustDSM
    Justin
    Ogden, UT
    This is extremely helpful and has a lot of info. Depending on the VCM Editor software and the logic Toyota used, a good bit of the data provided in this sheet may very well be used in properly scaling these injectors for use with our ECU. A lot of the data here is used in GM applications which is where my experience with HPTuners comes from (admittedly it's not much at this point).
    Once my stuff comes in, I'll be sure to post up loads of screenshots and we'll be able to see what we need to properly scale injectors on this application.
  19. Mar 29, 2019 at 3:57 PM
    #39
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    You da man!
  20. Mar 29, 2019 at 3:57 PM
    #40
    Roostfactor
    TX panhandle
    I'm definitely interested in this. I need a TRD ecu though.
    Biscuits and loginfailed like this.
