HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 6, 2019 at 6:39 PM
    #381
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Ya I don’t no anything about that lol. My mongoose cable always works.
    Hacktacular[OP] likes this.
  2. Apr 6, 2019 at 6:43 PM
    #382
    Hacktacular
    Hacktacular [OP] Well-Known Member
    Robert
    2010 Tacoma X-Runner Turbo
    800cc Siemens/Deka Injectors URD Fuel Pump Upgrade Haltech Elite 2500 Custom Power Fab Precision Turbo 6676 @8 PSI 3" Custom Exhaust from turbo out
    My cable worked too but can one of you run the test and post the results? I would like to know the outcome. Please...
  3. Apr 6, 2019 at 6:46 PM
    #383
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    I can Monday morning.
  4. Apr 6, 2019 at 6:49 PM
    #384
    o0opackersfano0o
    Tony
    North Berwick, ME
    2005 xrunner swb
    What happens when u hit next? And the key is on right
  5. Apr 6, 2019 at 6:50 PM
    #385
    Hacktacular
    Robert
    Thanks.
  6. Apr 6, 2019 at 6:51 PM
    #386
    Hacktacular
    Robert
    I can run through all tests but the K and L line test come back red or NG. all other tests pass and turn green.
    Torspd likes this.
  7. Apr 6, 2019 at 7:49 PM
    #387
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    My next question to those in the know, is @OVTune or HP Tuners, going to support the 2TR?
    Boring, 05Taco4x4 and JustDSM like this.
  8. Apr 6, 2019 at 7:50 PM
    #388
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Can't speak for OVT, but there's been some talk with HPTuners. Not sure it's on their immediate radar. I know the 2GR is right around the corner though.
  9. Apr 6, 2019 at 7:51 PM
    #389
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    But but but....
    12TRDTacoma and JustDSM like this.
  10. Apr 6, 2019 at 8:10 PM
    #390
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    I don’t think any tune will be that much different solely from a 2.85 vs 2.7 swap on our trucks. That’s only about 10/15 rwhp. Not much difference cause even the TRD tune can surffice that
    JuanitoBonito and 12TRDTacoma like this.
  11. Apr 6, 2019 at 8:12 PM
    #391
    TRON
    Yup^^^
  12. Apr 6, 2019 at 8:15 PM
    #392
    12TRDTacoma
    Rob
    Concordia
    Boosted
    So you are meaning to tell me that if we plug in OVTune's numbers that he showed in his most recent post that we will instantly gain better power output as a whole and it may even be able to handle all the different pulley size options out there? I know the computer is capable of compensating up to 30% changes, possibly even more so if we have a proper baseline, it should suffice?
  13. Apr 6, 2019 at 9:13 PM
    #393
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I am pretty sure the tune he posted is mine from when he dyno’d my truck :eek:
  14. Apr 6, 2019 at 9:15 PM
    #394
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Are you running 2.7 or 2.5 my dude?
  15. Apr 6, 2019 at 9:24 PM
    #395
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    @Murphinator, and that was on a 2.8 pulley?
    @OVTune if that tune is on the handheld, I agree, there were a couple guys who saw 20 rwhp gains on the 2.8 and stock 3" pulley, but I found the gains to be diminished when stepping down to 2.7 then 2.5 pulley. 2.7 was slightly too lean for me on your tune until I boost referenced fuel pressure... causing pig rich afrs. At 2.5 and boost referencing an extra 10psi fuel pressure, I'm still super rich at WOT but switched back to TRD tune.
    Long story short, OVTune was better for me on 2.8 pulley...TRD tune feels better for me on 2.5 pulley.
  16. Apr 6, 2019 at 9:28 PM
    #396
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    That was on a 2.85” urd pulley. Mods at the time were:
    Afe intake
    Jba shorties 2/ stock cats
    Stock ypipe
    3” exhaust
    255lph fuel pump,
    Stock valvebody
  17. Apr 6, 2019 at 10:03 PM
    #397
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's crazy. Apparently the running the TRD Tune boost referenced with the FPR mod on smaller pulleys is just an absolutely killer combination.
    Interesting... I'd like to see if we can net improvements on HPT with the smaller pulleys.
  18. Apr 6, 2019 at 10:25 PM
    #398
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    Not doubt it can. OVTUNE already demonstrated how much the TRD tune can be cleaned up on the 2.85 pulley. Imagine having a dialed in tune for the 2.5...or 2.3 in your case?
    TodayWasTHeDaY likes this.
  19. Apr 6, 2019 at 10:32 PM
    #399
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    One thing I'm jealous of the UCON guys is they still have the cam gears!
    Interested to see how beneficial they are over stock with this software.
    Hawk373 and loginfailed like this.
  20. Apr 6, 2019 at 10:41 PM
    #400
    TRON
    The TRD tune or reflash for old school peeps is the best tune for the higher boosted TRD SCed hands down. And it’s proven! I think the TRD engineers knew this and helped us out! But yes I still say @12TRDTacoma that if you have a tune dialed “no matter the tune” in for the 2.85 and drop to 2.7 there will not be much change in tuning. Unless the injectors are a factor!
    BassAckwards and 12TRDTacoma like this.
