HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 11, 2019 at 1:37 PM
    #4001
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    From Chris himself:
    1slow4.0 and Torspd like this.
  2. Aug 11, 2019 at 1:37 PM
    #4002
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I'm with you on this, very suspicious timing for 3 of us to brick in such a small window. I've flashed 30+ times myself.
    Norton, 1slow4.0 and nd4spdbh[QUOTED] like this.
  3. Aug 11, 2019 at 1:45 PM
    #4003
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I just don't understand why there is no buffering / local temp storing of the tune to be put on the ECU on the dongol itself rather than pushed bit by bit from the computer.
    Norton likes this.
  4. Aug 11, 2019 at 1:46 PM
    #4004
    nd4spdbh
    SoCal
    Very. If it was just one ok fine shit happens... But 3 of us. That's a pretty big coincidence
  5. Aug 11, 2019 at 3:11 PM
    #4005
    nd4spdbh
    SoCal
    Those that have gone through the process of putting a different "new" ecu in the truck, If the same part number, it should be as simple as resyncing immobilizer and fire up yes? VIN Number is just data on the ecu that can be sorted with later?
    Also, i must say, in searching around I must consider myself lucky, even tho I have a bricked ecu, my part number is abundant and easily sourced. I am going to rethink my flashing strategy, and maybe wait around till @HPTuners chimes in if they can do anything as far as the wire procedure (pushing to MPVI2 first etc) before flashing again. Ill also source another ecu before flashing to have on hand in case things go sideways again.... oh and new usb cables one for the only sole purpose of flashing thats treated like a delicate flower.
    Norton likes this.
  6. Aug 11, 2019 at 3:35 PM
    #4006
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    Yeah you don’t need the vin# programmed to run the vehicle. You will have a check- engine light on tho, but no limp mode.
  7. Aug 11, 2019 at 3:42 PM
    #4007
    nd4spdbh
    SoCal
    check eng due to the vin # ? or something else ?
    I mean i have an old laptop with tech stream, so i should be able to get the right VIN on. Whats the process for that within techstream?
  8. Aug 11, 2019 at 3:45 PM
    #4008
    OVTune
    OVTune Well-Known Member
    OVTune
    I can recover your ECUs for $75 each + shipping.
    Just make sure to let me know the CAL ID. I have a master NBD tool for them.
    Double check your fuel pump isn't running during a flash. It does on the Tundra and it creates momentary big drops in voltage
  9. Aug 11, 2019 at 3:46 PM
    #4009
    1slow4.0
    Nick
    Colorado
    2012 TRD OR
    Yeah due to no vin programmed. I also used tech stream, I’m sorry I don’t remember right off hand but there is a section that is specific for writing vins.
  10. Aug 11, 2019 at 3:50 PM
    #4010
    420taco
    420taco Well-Known Member
    Justin
    PA
    I got a junkyard ecu, didn’t program VIN, no check engine light, runs great.
  11. Aug 11, 2019 at 3:51 PM
    #4011
    nd4spdbh
    SoCal
    BRUH! You would be a life saver. PM incoming.
    Would it be wise to pull the fuel pump fuse / relay during flashing?
  12. Aug 11, 2019 at 3:53 PM
    #4012
    OVTune
    OVTune
    Worth trying, especially if the flash is slow with HPTuners (no idea). I've never had to because ours flashes the ECU in under 30 seconds. But I've heard of similar stories on the Tundra with 3-4 minute flash times with HPT and they recommend pulling some fuses. (or battery charger)
    Norton likes this.
  13. Aug 11, 2019 at 3:56 PM
    #4013
    nd4spdbh
    SoCal
    Yup, i see about 3-4 min flash time as well with HPT and their latest software. Would make sense as i clicked key on after waiting 10 secs, and click write about 2-3 secs after key on... pump could of been priming.
  14. Aug 11, 2019 at 3:56 PM
    #4014
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    this is good to know. sorry to the fellas that had things go sour. is there anyone that has a link on a premium cable? or do we just buy a spare from hp tuners?
  15. Aug 11, 2019 at 3:59 PM
    #4015
    Jesse
    Poulsbo
    15' DCSB OR S/C
    instead of a like option for posts we need a DAMN option.
    DesertRatliff and Norton like this.
  16. Aug 11, 2019 at 4:10 PM
    #4016
    nd4spdbh
    SoCal
    Its just a standard USB C to A cable. I dont even think its a USB 3.0 A plug.... ill check.
    EDIT - yeah, just a standard usb 2.0 A to usb C cable.
    EDIT2 - also funny, the cable supplied by HPTuners is at the max spec length for usb 2.0.... while i have seen 10-15ft runs of USB 2.0 data work, for something sensitive like we are talking about, a 3ft run is what i would consider safe.
  17. Aug 11, 2019 at 4:41 PM
    #4017
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Seems fishy
    Norton likes this.
  18. Aug 11, 2019 at 4:50 PM
    #4018
    OVTune
    OVTune
    The method implemented for flashing Toyota ECUs is sketchy all on its own.
    Probably just bad luck.
    loginfailed likes this.
  19. Aug 11, 2019 at 4:53 PM
    #4019
    nd4spdbh
    SoCal
    Yup. Honestly if id of known it was such a sketchy process in the first place I would of never touched my original ECU, I would of gotten a same part number ecu that i could mess up... oh well live n learn. Im just glad it didnt happen at work or out n about... i have flashed different tunes in both places a handful of times with no issue... luckily this happened right in my garage.
    Norton likes this.
  20. Aug 11, 2019 at 5:05 PM
    #4020
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    If someone needs a new ecu just remember that new year ones will have the most up todate calibration and might not be able to do the trd flash to it. Junk yard is the way to go.
