HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 11, 2019 at 5:14 PM
    #4021
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    So for instance.. 304A5000 that is updated to 304A5100 cannot be flashed to TRD spec?
  2. Aug 11, 2019 at 6:45 PM
    #4022
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    CEL will only be on if there is no vin written, like you would get with a new ecu.
  3. Aug 11, 2019 at 8:54 PM
    #4023
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    Well this just freaks me out. Seems like the best option is to have a backup ECU, which ups the cost of doing this (since my truck is my DD). Unless HP Tuners comes out with a more fail safe method, I've gone to being reluctant to play with this.
  4. Aug 11, 2019 at 9:04 PM
    #4024
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    When you recover the ecu is it back to the OE N/A cal or can you recover back to the TRD tune cal for the supercharged guys?
    Norton and TodayWasTHeDaY like this.
  5. Aug 11, 2019 at 10:22 PM
    #4025
    S.B.
    Sean
    San Diego
    15 Taco
    I'll have to find out which ID it had and send it in to you
    Also ordered a 3ft high quality USB, maybe that's a problem
  6. Aug 11, 2019 at 10:32 PM
    #4026
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I’ve already got a “just in case” ECU, but with you guys bricking ECUs y’all have me paranoid so I just went on eBay and bought another one.
  7. Aug 11, 2019 at 10:43 PM
    #4027
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    What’s the best place or deal on HPT setup?
  8. Aug 12, 2019 at 2:37 AM
    #4028
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    I don’t no the exact cal numbers but yes that’s exactly right. If it had the calibrating for the pinging or what ever it was. You can’t flash it with supercharger tune.
    BassAckwards and Norton like this.
  9. Aug 12, 2019 at 4:42 AM
    #4029
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Best price I found was on Amazon a while back, tuner plus 2 credits was $375, then I added 2 more credits for $100. Was cheaper than any of the 4 credit deals I saw.
  10. Aug 12, 2019 at 4:44 AM
    #4030
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    BTW, is the cal ID/SN available electronically, or just via the ECU label? I don't have my tuner pc available right now to look.
    loginfailed likes this.
  11. Aug 12, 2019 at 4:56 AM
    #4031
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    I'm on my 2nd ecm, Toyota told me they weren't able to flash my original one to supercharger spec so I had to get a new one. My plan is to try that ecm again and see if I can hp flash it. If i can, I imagine it was just the dealer that didn't know what they were doing and I'll limp the truck over to a Toyota to have them try again. I'll send my bricked ecm to Matt with OVTUNE to have as a spare if everything goes smooth.
    Norton and Torspd like this.
  12. Aug 12, 2019 at 6:42 AM
    #4032
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Starting on page 54 is the list of calibrations by year and model. Left column is the original non-supercharged ID and the right column is the supercharged ID.
    http://toyotaparts.sparkstoyota.com/install/PTR29-35120inst.pdf
  13. Aug 12, 2019 at 7:41 AM
    #4033
    ThomasMore66
    Dallas/Fort Worth & Durango
    Really freaked out by this. You guys that understand tuning better than me had some great ideas regarding the process of testing the quality of the file before writing. That seems like something that ought to happen. Did anyone else write this weekend?
  14. Aug 12, 2019 at 7:57 AM
    #4034
    OVTune
    OVTune Well-Known Member
    OVTune
    I can put any cal on the ECU.
  15. Aug 12, 2019 at 8:33 AM
    #4035
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I ran into this when I installed my S/C - ended up buying a "virgin" ECU, of the elusive 6MT variety. :spending:
    This is great news! I wish this option had been available a couple of years ago! Now, I'm pissed I sold my original TSB-flashed specimen... :frusty:
    Ditto! I updated my garage laptop to the latest Beta version, in preparation for some datalogging. Thinking about rolling back while I wait for the dust to settle here...
  16. Aug 12, 2019 at 8:35 AM
    #4036
    OVTune
    OVTune
    Sorry, we've only ever had 1 ECU failure with our software so I never thought of offering some ECU service
  17. Aug 12, 2019 at 8:36 AM
    #4037
    ThomasMore66
    :duel:
    Gunerbey, GT7 and jojotoo like this.
  18. Aug 12, 2019 at 9:05 AM
    #4038
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Now that safety net is available though. :thumbsup:
  19. Aug 12, 2019 at 9:36 AM
    #4039
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Your services are VERY welcomed! My original ECU is on its way to you to get unfucked .... and another ecu was ordered from ebay and should get to me by the end of the week *fingers crossed*.
    Once i get my original one back in unmolested original CAL form, ill plug her in, get the imobilizer synced with it and then keep it as it stands in a perfect working stock setup ready to plug in and go. Then the ebay ecu will become my fuck around hptuner ecu.
    Like stated, if id of known that the @HPTuners flash process was so insanely sketchy id of never touched my original ecu in the first place.
    For those who havnt gotten a spare ecu, you can remove the passenger kick panel, stick your phone up between the ecu and side of the truck with flash on and take a pic to get the part number of your ecu without having to remove it.
  20. Aug 12, 2019 at 10:11 AM
    #4040
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    That will save people so much time and hassle not having to do multiple steps of finding an ecu then trying to get the TRD tune back as a baseline.
    Norton, jojotoo and Murphinator like this.
