HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 12, 2019 at 2:14 PM
    #4061
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Sounds an awful lot like my "USB cable" incident..
  2. Aug 12, 2019 at 2:41 PM
    #4062
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    Can you elaborate more on this bench harness? It sounds like something I'd be into.
  3. Aug 12, 2019 at 2:48 PM
    #4063
    JustDSM
    Justin
    Ogden, UT
    Chop off some ECU connectors at a wrecking yard along with the OBDII plug and a bit of wiring.
    Consult the EWD to determine the 12v constant, ignition, and ground. Extend the wiring for 12v+ and add a switch for the Ign+/Gnd to a bit so you can connect to a power source.
    Then you'll do the same to wire in the OBDII directly to the ECM harness. Allowing you to flash the ECU outside the vehicle.
  4. Aug 12, 2019 at 2:48 PM
    #4064
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    There absolutely has been a shift in how things were written and verified since the initial release and current.
    Initial release it would write in ~ 1.5-2min total, then another 1.5-2 min to verify. Now its 3-4min of writing with no verify.
  5. Aug 12, 2019 at 2:56 PM
    #4065
    ThomasMore66
    Dallas/Fort Worth & Durango
    What is a bench harness? Does HPT recommend hooking up the truck to a charger when flashing the truck?
  6. Aug 12, 2019 at 2:58 PM
    #4066
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    JustDSM likes this.
  7. Aug 12, 2019 at 3:07 PM
    #4067
    HPTuners
    HPTuners Well-Known Member
    yeah we just got rid of the verifying message becuase some people thought the could disconnect, the underlying process is the same.
  8. Aug 12, 2019 at 3:08 PM
    #4068
    nd4spdbh
    SoCal
    Ah ok. That makes sense.
    Could a disruption in usb connectivity (ie failing cable) cause this? or is this more likely an undervolting / extra draw from accessories (like a fuel pump turning on as previously mentioned) causing disruption to the ecu?
    Does the MPVI2 store (buffer) the whole tune file while writing, or is it pushed bit by bit to the MPVI2 as needed?
    Just asking questions to be more educated and mitigate losses better. As always thank you for your support @HPTuners
  9. Aug 12, 2019 at 4:18 PM
    #4069
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    thanks for this info.
  10. Aug 12, 2019 at 4:30 PM
    #4070
    HPTuners
    Yes, anything that disrupts comunication on the CAN bus or the USB link could cause the problem. We just see a packet timeout becuase usually a USB noise issue or intermittent problem isn't enough to drop the USB link and make the USB driver report anything unusual happened. The communications is buffered to a degree but not the whole tune. In future we will have this option on the MPVI2 as Standalone Flashing, it will help guard against PC or USB issues but these aren't a major source of problems thesedays (not since the debarcle of Windows Vista and USB driver compatibility anyway). The real problem is the robustness of the Toyota system which cannot be changed.
  11. Aug 12, 2019 at 4:44 PM
    #4071
    Jesse
    Poulsbo
    15' DCSB OR S/C
    @HPTuners is removal of fuses an acceptable way of solving voltage hiccups? like fuel pump? s/c coolant pump? make sure radio and climate controls are off? don't touch window switches?
  12. Aug 12, 2019 at 4:47 PM
    #4072
    HPTuners
    It's hard to say, we flashed our Tundra hundreds of times without a problem, we also have a few testers for diesel and other vehicles that haven't reported problems that weren't explained by faulty things. eg. JustDSM's USB cable
  13. Aug 12, 2019 at 4:51 PM
    #4073
    Jesse
    Poulsbo
    15' DCSB OR S/C
    if you have a cable length, type, and quality we should invest in I'd like to know. this truck is my dad, and I'm not as tuner savvy as some guys here. I'd really be poked if I had computer failure.
    garciav and 5thGearPinned like this.
  14. Aug 12, 2019 at 10:51 PM
    #4074
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    @HPTuners, I finally submitted my ticket. #182488
  15. Aug 13, 2019 at 12:22 AM
    #4075
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    My stock fuel pump wiring is disconnected. I have my aftermarket fuel pump wired to come on anytime the ignition is on.
    I’ve been flashing with the MPVI2 while the fuel pump is running the whole time. No issues yet, but I do use a maintainer.
  16. Aug 13, 2019 at 4:27 AM
    #4076
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I also use a maintainer as well, while loading tunes on my truck. Despite being a completely different standalone ECU.
  17. Aug 13, 2019 at 4:41 AM
    #4077
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    So, is the battery main lead about the only stock part of your powertrain left? :D
  18. Aug 13, 2019 at 4:46 AM
    #4078
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think his battery cables have also been modified!
  19. Aug 13, 2019 at 4:50 AM
    #4079
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I figure the ground wire has, just wasn't sure about the positive ??
  20. Aug 13, 2019 at 5:37 AM
    #4080
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    And the cab. :D
