HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 14, 2019 at 1:15 PM
    #4161
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    *installed!
  2. Aug 14, 2019 at 1:23 PM
    #4162
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I just did and it works fine. They’ve just changed the process
    DiamondW, Turdyota3000, S.B. and 3 others like this.
  3. Aug 14, 2019 at 1:25 PM
    #4163
    1slow4.0
    Nick
    Colorado
    2012 TRD OR
    Nice!:thumbsup:
    JustDSM[QUOTED] likes this.
  4. Aug 14, 2019 at 1:32 PM
    #4164
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    You should be able to raise the rpm limit in hptuners, I don’t have one yet so I can’t say where it is. But be warned if you are boosted it is not wise to raise the limit unless you understand it is increasing the chance your motor will go boom.
  5. Aug 14, 2019 at 1:35 PM
    #4165
    1slow4.0
    Nick
    Colorado
    2012 TRD OR
    Thanks @HPTuners for the quick response on updating the flash process. I know there will always be a risk but it’s nice to know your here to help out to limit any future issues.
  6. Aug 14, 2019 at 2:05 PM
    #4166
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    FYI stock TRD cal is already 200rpms above (5800) a NA cal of 5600
  7. Aug 14, 2019 at 2:09 PM
    #4167
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    This is interesting. I would assume toyota would be on the conservative side when it comes to the rev limiter. Sounds like i may be able to raise mine from 5500 a little bit and still be safe
  8. Aug 14, 2019 at 2:18 PM
    #4168
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    Yes but can you imagine 6800 rpm? That poor 4.0 wouldn’t stand a chance. I am surprised the trd cal is higher. When/if I get my hp tuner I will bump it back down to 5500 I think.
  9. Aug 14, 2019 at 2:29 PM
    #4169
    BassAckwards
    Now that i think about it more.. there's no way im raising mine since im running twice as much boost as the stock TRD charger. About to drop a pulley size too, so that wont make the motor any happier
  10. Aug 14, 2019 at 2:53 PM
    #4170
    nd4spdbh
    SoCal
    Yeah, I definitely wouldnt be revving our under square 1GR's much past 5800rpms....
    Murphinator and BassAckwards like this.
  11. Aug 14, 2019 at 4:46 PM
    #4171
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Well, that move takes balls! Or in our world,,, a spare ECU to back those balls. :thumbsup:
  12. Aug 14, 2019 at 5:03 PM
    #4172
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    dude, look at the can-am Maverick! I'd trade my truck for one. its turbo too.
  13. Aug 14, 2019 at 5:05 PM
    #4173
    JustDSM
    Justin
    Ogden, UT
    Thanks! But I’m confident in the process. We each drove 3 hours to meet up with each other. No spare Ecu present.
    Just took all necessary precautions and that was that. Uneventful.
  14. Aug 14, 2019 at 5:07 PM
    #4174
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I'd love it if my truck peaked at 7k. but I don't have the bank for a motor able to tolerate that. even @Torspd has the ability too but doesn't. I'll follow his limits.
    Torspd and BassAckwards like this.
  15. Aug 14, 2019 at 5:59 PM
    #4175
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  16. Aug 14, 2019 at 6:42 PM
    #4176
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    @JustDSM is right. I am the lab rat that received the tune/flash. All coms working with the beta. If you have problems with your flash, it’s on you. IMO.
    Edit: I am even new lab rat according to my ecu.
  17. Aug 14, 2019 at 7:18 PM
    #4177
    nd4spdbh
    SoCal
  18. Aug 14, 2019 at 7:41 PM
    #4178
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    My tuner gets here Friday. Get your ass out here and let’s work on it.
  19. Aug 14, 2019 at 8:06 PM
    #4179
    Turdyota3000
    Round da corner
  20. Aug 14, 2019 at 8:06 PM
    #4180
    JustDSM
    Justin
    Ogden, UT
    Thank you for trusting me with your ride!
