HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 18, 2019 at 7:58 PM
    #4261
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Well don’t speak too soon......actually no way in hell I’ll go back. Just sent you my first log file, sorry if it’s too long, wasn’t sure what you need lol. So you got my full 20ish minute drive to the bar for dinner.
    Murphinator likes this.
  2. Aug 18, 2019 at 8:25 PM
    #4262
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I’ve flashed mine like 50 times. No issues yet, but thanks for the heads up haha. :rofl:
    BassAckwards, Norton, Torspd and 3 others like this.
  3. Aug 18, 2019 at 9:01 PM
    #4263
    NashMan
    NashMan Well-Known Member
    Mine show 5600 rpm on thjetrd map but soon to be 6200 rpm or 6000 when ever the hp stops aprx1 went to 6200 rpm if i remmber right
  4. Aug 18, 2019 at 9:02 PM
    #4264
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    welcome new fella!
  5. Aug 18, 2019 at 9:06 PM
    #4265
    Jesse
    Poulsbo
    15' DCSB OR S/C
    I never will
    #jdsm 4.0 tuninglife
    TodayWasTHeDaY likes this.
  6. Aug 18, 2019 at 9:15 PM
    #4266
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    AMEN TO THAT. Once I get my hands on my contingency plan (AKA original ECU with stock CAL and VIN).... the backup ecu will be flashed where i left off.... driving my truck on a stock cal the last few days has had me less than excited. Truck just feels so anemic!
    the more data the better, captured a few logs of 1-2 hr drives (careful for screen burn in on the laptop! just set it to turn the screen off when lid closed in power settings) ... the more data the more cells get filled in the more that can be seen whats going on.
    Every TRD cal i have seen has shown a 5800 RPM rev limit, while NA cals are at 5600. What year is your TRD cal?
  7. Aug 18, 2019 at 9:24 PM
    #4267
    NashMan
    am i blind i can not find the ve table for fuel or even spark should under air flow but it's not ??????
  8. Aug 18, 2019 at 9:25 PM
    #4268
    NashMan
    it was suppiled by hp tunners
  9. Aug 18, 2019 at 9:53 PM
    #4269
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Time for cam gears and an updated tune to complement it?
  10. Aug 18, 2019 at 9:54 PM
    #4270
    nd4spdbh
    SoCal
    are you supercharged and have been flashed by the toyota dealer with a TRD tune? (fyi TRD Tune, does not mean you have a TRD truck, IE TRD Sport or TRD OR, it means you have been flashed with a Toyota Racing Development tune for use with the TRD supercharger)
    Also these trucks do not operate on a VE tune, and spark is not a normal spark table due to how knock correction learn works.
    JustDSM likes this.
  11. Aug 18, 2019 at 10:28 PM
    #4271
    NashMan
    oh i tired to get the trd tune but i live in canada and I own an american truck so none of the dealer ships would flash my truck and the current aprx1 was used in my truck but had a nasty dip in the power band big rich hickup that I beleav was the acis valve not being there or something. so i had 3 options send my ecu to a guy in the states to flash it for me and have my truck down for 2 weeks guessing or buy a link fury ecu and build a jumper harness or get hp tunners and have the n/a map grid then tune it for the supercharger. so i was not a fan of this because i would have to send a junk yard ecu to get flashed then get my truck read and map given to me from hp the price at that point was about the cost of the link ecu. but our local tunner shop found out for me since I was intrested in hp tunners that they could just send me the trd map for my truck and then loaded it up and she start up and ran fine rather rich but fine so from what i was told they are now converting all the tune tables to be the bigger trd map but made for n/a and supercharged
    no fuel table at all this is kinda odd never delt with this before????
  12. Aug 19, 2019 at 5:19 AM
    #4272
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Are you backed up on getting tunes out right now?
  13. Aug 19, 2019 at 6:28 AM
    #4273
    Gunerbey
    Gunerbey Well-Known Member
    2015 Tacoma
    ...i did, minus the throttle crackle mine's back to stock. after hearing what i imagined to be some knock occurring i reverted back. i still get it after some heavy driving though. i gotta get under the truck and see if its just an exhaust leak when things get hot or maybe use an i.r. gun to check individual exhaust temps to make sure each cylinder is fuelling properly.
    JustDSM[QUOTED] likes this.
  14. Aug 19, 2019 at 7:20 AM
    #4274
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What's the story of your truck's maintenance and life? Miles, year model, service intervals?
  15. Aug 19, 2019 at 7:24 AM
    #4275
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    I'd encourage you to investigate that, your logs were clean as a whistle. I'd honestly be interested in keeping in touch to hear what you find, so please do keep me posted if you would!
    Gunerbey[QUOTED] likes this.
  16. Aug 19, 2019 at 8:18 AM
    #4276
    nd4spdbh
    SoCal
    You are really going to want to get an ECU with a TRD cal flashed to it if you are running the supercharger. Do it right.
    There are fuel tables, but in essence the ecu shoots for a stoich AFR of 14.6:1 unless other conditions are met, one being power enrichment (based on throttle plate angle) other being component protection (based on predicted temperatures) where there are multipliers to that stoich number to add more fuel.
  17. Aug 19, 2019 at 8:20 AM
    #4277
    Gunerbey
    2015 Tacoma
    2015 6mt 110 000km dealer services since new. Every 8k
  18. Aug 19, 2019 at 9:05 AM
    #4278
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have you upgraded your fuel pump and installed a replaceable external fuel filter? I highly recommend doing so, if you have not.
    I doubt that is the source of your issue/s you're trying to find. Just good common sense maintenance.
  19. Aug 19, 2019 at 9:46 AM
    #4279
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    loginfailed likes this.
  20. Aug 19, 2019 at 10:44 AM
    #4280
    nd4spdbh
    SoCal
    Interesting, must be certain years of the TRD Cal that have a 5800rpm rev limit.
