HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 20, 2019 at 2:15 PM
    #4301
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    hahahhahaha! what a tacoma brick isnt good aero?
  2. Aug 20, 2019 at 2:16 PM
    #4302
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Me too
    Torspd[QUOTED] likes this.
  3. Aug 20, 2019 at 2:23 PM
    #4303
    nd4spdbh
    SoCal
    Also, some interesting findings when looking at logs from @snowsk8air2 's truck, which prompted me to look at the various TRD cal's i have from different years.
    TRD CAL USERS.... yall special supercharged people.... theres stuff left on the table that might be easily grabbed in 1st gear!
    Looks like there is some RPM based max throttle blade angle limiting going on, essentially you do not get max 84* throttle blade angle between rpms of 2000 to 5200... THE MEAT of the power band in first gear. This if found under Engine -> Airflow -> "Fwd/Rev" -> 1st gear
    Tag your supercharged hptuner friends people!
    See below:
  4. Aug 20, 2019 at 2:31 PM
    #4304
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Gotta have that snap crackle pop!
    White lightning boosted and TRON like this.
  5. Aug 20, 2019 at 2:46 PM
    #4305
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello,
    I have a '15 DCSB TRD O/R 4WD and I am interested in bypassing or completely eliminating the Secondary Air Intake System (SAIS). My search lead me to a thread named:
    Hewitt-Tech Secondary Air Injection Bypass kit (2012+ 4.0) (UPDATED 21-OCT-2016)
    In that thread @vssman commented:
    "HP Tuner is a tuner software and module that connects through the OBD port and reflashes the ECU with user modified program. There's about 10 checkboxes that are needed to be modified which turn off the SAIS. Works well for all of the years that the V6 had this system."
    I'd rather go this route and hopefully eliminate the SAIS system entirely thus eliminating the chance that my truck will ever go into limp-mode due to some faulty emissions crap. I have no complaints with the performance of my 4.0 but if I can get a tune out of this as well then why not. It may help the performance later on when I go to 285/70r17's
    @HPTuners, will your tuner accomplish this?
    Thank you
    vssman and BassAckwards like this.
  6. Aug 20, 2019 at 3:39 PM
    #4306
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Me too!
    That would be great!
    I wish you were local, I'd pay you to do so. Thank you for explaining how the credits work. It makes perfect sense.
    So just to clear (sorry, I have never flashed or tuned any car computers before) I can buy this HP Tuner & just have the SAIS system deleted from the ECU? I don't have to mess with the performance? I mean I'd like to but I'm not good at that. It's one thing to BUY a tune & it's quite another to do the tune yourself, meaning m, & I honestly have no issues with the trucks current performance.
    I assume I have to use a laptop besides the OBD II plug, correct?
    vssman and loginfailed[QUOTED] like this.
  7. Aug 20, 2019 at 4:02 PM
    #4307
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Is this for just automatics? Or manual trans as well ?
    Norton likes this.
  8. Aug 20, 2019 at 4:21 PM
    #4308
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    @Roostfactor had a batch made, check with him and see if he has any left.
    TAC1[QUOTED] likes this.
  9. Aug 20, 2019 at 5:58 PM
    #4309
    nd4spdbh
    SoCal
    Hmm good question. Its under Engine - airflow, so its not under the trans tab, that stated honestly not sure as the TRD Cal's i have seen are Autos. Have a looksee in your cal!
  10. Aug 20, 2019 at 6:14 PM
    #4310
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    OK. So he's the HP vendor on TW? I will pm him now.
    loginfailed[QUOTED] likes this.
  11. Aug 20, 2019 at 6:23 PM
    #4311
    nd4spdbh
    SoCal
    No he made blockoff plates. You can buy an HPTuner and credits from many many places online.
    loginfailed and TAC1[QUOTED] like this.
  12. Aug 20, 2019 at 6:28 PM
    #4312
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    OK Got it.
  13. Aug 20, 2019 at 6:36 PM
    #4313
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Does this tune get lost if your trucks battery dies or is this "tune it once & done"? As I previously mentioned my main thing is to eliminate the SAIS.
  14. Aug 20, 2019 at 6:37 PM
    #4314
    nd4spdbh
    SoCal
    No, when you flash the ecu you permanently write to the truck.
  15. Aug 20, 2019 at 6:39 PM
    #4315
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
  16. Aug 20, 2019 at 7:12 PM
    #4316
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
  17. Aug 20, 2019 at 7:18 PM
    #4317
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Thank you
  18. Aug 20, 2019 at 7:32 PM
    #4318
    garciav
    Houston, TX
    TRD SC,HPTuners
    @JustDSM what u think ?
  19. Aug 20, 2019 at 7:38 PM
    #4319
    420taco
    420taco Well-Known Member
    Justin
    PA
    Did they program it that way to reduce wear on the trans? :anonymous:
  20. Aug 20, 2019 at 7:40 PM
    #4320
    nd4spdbh
    SoCal
    Its only in first gear. Im thinking its programmed that way to keep this from happening :burnrubber: Even NA, sometimes ill blow by the braking traction control before it reduces throttle blade angle
    Definitely curious if a MT TRD cal owner can weigh in if its an Auto only thing.
    snowsk8air2 and JacksonTacoma like this.
