HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Aug 30, 2019 at 4:13 PM
    #4381
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Dropping the PE engagement point too low will cause you some problems with fuel economy, where you’re at isn’t bad though. *Hint* Don't use PE to richen part throttle. Explore other means of getting fuel at those RPMs/Loads.
  2. Aug 30, 2019 at 4:58 PM
    #4382
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I tried that initially, but the easy way I found to richen things up is use the cat over temp (component protection) table.
  3. Sep 1, 2019 at 8:07 AM
    #4383
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    @HPTuners any further development on 2.7L?
  4. Sep 1, 2019 at 8:18 AM
    #4384
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    @HPTuners , or @JustDSM . is there a way to alter the speed sensor input in a manual transmission so the speedometer works when swapping to completely different axles? like Dana 60's out of a ford.
    BassAckwards and JustDSM like this.
  5. Sep 1, 2019 at 8:23 AM
    #4385
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Pretty sure if you have ABS then your Speedo input comes from the sensor at the wheel and remains unaffected by hearing or tire adjustments. Hypertech in-line system will adjust regardless of what axle is underneath.
  6. Sep 1, 2019 at 8:33 AM
    #4386
    Jesse
    Poulsbo
    15' DCSB OR S/C
    what if your abs is disconnected? asking for a friend that has a 15' sport doing a major suspension change.
  7. Sep 1, 2019 at 9:02 AM
    #4387
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I am curious of the same.
  8. Sep 1, 2019 at 9:04 AM
    #4388
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    not on a six speed manual. it comes from a unit in the tcase. changing that plastic gear out would fix the problem
    Norton, zippsub9[QUOTED] and Torspd like this.
  9. Sep 1, 2019 at 9:06 AM
    #4389
    zippsub9
    Halfmoon, NY
    14 DCLB
    I don’t think you will have any speedo input then. Not sure if it reads from only one particular wheel then you could leave that sensor ring in place with a sensor and remove the rest of the system...
  10. Sep 1, 2019 at 9:07 AM
    #4390
    Jesse
    Poulsbo
    15' DCSB OR S/C
    nice. ill relay that. im going back to puyallup today for a bbq with some tw guys if you care to join.
    BassAckwards likes this.
  11. Sep 1, 2019 at 9:08 AM
    #4391
    Jesse
    Poulsbo
    15' DCSB OR S/C
    that was his concern as these axles read completly different.
  12. Sep 1, 2019 at 9:15 AM
    #4392
    wrmathis
    Bonaire, GA
    parts and stuff
    thanks but i have to go get an MRI later today on my wrist. so wont be able to make it. thanks for the offer though.
    on a 6spd manual, a new axle shouldnt mess with the speedo, just the ABS which if he already has it disabled then its more of a doesnt matter anymore.
  13. Sep 1, 2019 at 9:23 AM
    #4393
    Jesse
    Poulsbo
    15' DCSB OR S/C
    well wishes on your wrist!
  14. Sep 1, 2019 at 12:23 PM
    #4394
    JustDSM
    Justin
    Ogden, UT
    Unfortunately there's not a way to alter the speed sensor input in MT vehicles. I had talked to Chris about this early on and there's nothing in the ECU for speedo control.
  15. Sep 1, 2019 at 12:38 PM
    #4395
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Dakota Digital box, or the Hypertech
    JustDSM[QUOTED] likes this.
  16. Sep 1, 2019 at 12:40 PM
    #4396
    wrmathis
    Bonaire, GA
    parts and stuff
    i have the dakota digital box. of course sense rocksolidtoys lost their forum, alot of the diy crawlbox, and other stuff was lost.
  17. Sep 1, 2019 at 12:52 PM
    #4397
    JustDSM
    Justin
    Ogden, UT
    I should have clarified, internal to the ECU.
    Torspd[QUOTED] likes this.
  18. Sep 1, 2019 at 1:52 PM
    #4398
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is sad.
    I only mentioned that for others not in the know. :thumbsup:
  19. Sep 1, 2019 at 2:02 PM
    #4399
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Also very interested:popcorn:
    DiamondW likes this.
  20. Sep 1, 2019 at 6:14 PM
    #4400
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    My truck drive sooo much better.
    I forgot how much better it drives with a tune.
    Truck has been torn apart to rebuild/revalve front shocks and replace a ball joint..
    Now I need to fix the cruise control and build a dune map...
