HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Sep 2, 2019 at 7:11 AM
    #4401
    Fleabag
    Fleabag Suck it Trebek!
    Uriah
    Vancouver, WA
    2013 Toyota Tacoma TRD Offroad - SSM
    Suspension: SPC Light Racing UCAs Old Man Emu 886 Coils Old Man Emu 90000 Nitrocharger Struts Old Man Emu 60091 Nitrocharger Struts Deaver U402 Stage 3 Leaf Spring Packs Dobinsons Greasable Shackle Bolts Old Man Emu 95PF5 Trim Packer Energy Suspension Bushings Timbren U Bolt Flip Kit And Bumpstops Timbren Front SES Bumpstops Total Chaos Cam Tabs Tires: Pro Comp 87 Series 16's Steel Wheels Goodyear Duratrac 315/75r16 Engine: aFe Cold Air Intake aFe Throttle Body Spacer HyperTech Speedo Calibrator HP Tuner with a JustDSM and nd4spdbh tune file 3° Exhaust Cam Gear from Mightytacoman Peddle Commander Throttle Calibrator Drivetrain: ECGS Front Differential 4.88 gears with Harrop E-locker ECGS Rear Differential 4.88 gears with stock E-locker Tom Wood's One-piece driveshaft Derale Transmission Cooler Derale Thermostatic Switch for fan Mishimoto Fan for transmission cooler Improved Racing Thermostatic Cooler Bypass and filter relocator for transmission cooler Electrical: Eaton RFRM Custom PDM 10 fused relay circuits, 10 fused circuits Feniex 4200 Mini Controller with MeSo Customs mount. LED Bulb Upgrade Front - Rigid D Series Pro - Flood Diffused Rigid D Series Pro - Spot Rough Country Midnight Series 20" single row ARB 9" knockoffs Rear - Rigid D Series Pro - Flood Diffused Communication: Midland MXT275 GMRS Radio Assorted GMRS Handhelds Suburban Assault Armor: MobTown Rock Sliders - Plated MobTown Tail Gate Reinforcement Brute Force Fabrication Plate Front Bumper Brute Force Fabrication HC Dual Swing-out Plate Bumper BAMF Full Skid Set Chaos Fabrication Bed Side Reinforcements Recovery: Superwinch Tigershark 11,500 SR Hi-Lift Extreme 60" Shovel Mattock ActionTrax Recovery Boards Straps & Shackles Exterior: Homertaco Ghost Raptor Grill Alpine Designs Offroad Cab Mount Relocation Brackets Fender Trim Firewall Massage Stubby TRD Antenna Weathertech Window Deflectors Toyota Hood Deflector Soft Tonnaue Cover Color Matched Canopy Custom Aluminium Box on Swingout Modified Bedslide Interior: MeSo Customs Maps Lights and Dome Light ImMrYo Rear View Mirror Relocate Bracket LostSheep's Ram Mount - Mount DynoMat Ram Mount X-Grips and Various Connectors UltraGuage Weathertech Floor Mats Chinesium A/C Knobs Horse Blanket Seat Covers.
    Hello Folks,
    I have went through the majority of this thread and need some input, I am considering purchasing this tuner to improve auto trans shift performance on a 2013 4.0 regeared on 35s as I have not been pleased with shift points and the general drive-ability of the truck.
    so question #1 can I achieve better trans performance in this application? question #2 is there performance improvements on n/a applications that can be expected, while not influencing reliability and MPG?
    Thanks for your time!
    shr133 likes this.
  2. Sep 2, 2019 at 8:04 AM
    #4402
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    You can absolutely change all of the shift points to suit your preferences.
  3. Sep 2, 2019 at 8:38 AM
    #4403
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    @nd4spdbh can help with #1.
    @JustDSM can help with #2.
  4. Sep 2, 2019 at 10:34 AM
    #4404
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Performance in for N/A applications is there and felt mostly in "normal use" scenarios. The WOT gains are relatively minor for stock-ish setups. As you stray further from stock with bolt-ons/cams/etc the N/A tuning will be more worthwhile/necessary. While stock-ish N/A setup gains at WOT are relatively minor, the drive-ability/increased torque in daily driving RPM zones as well as increased fuel economy are worth the price of admission.
  5. Sep 3, 2019 at 8:16 AM
    #4405
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Just did ~ 750 miles round trip and 9k ft of elevation gain and decent over the last weekend to mammoth and back with a JustDSM's engine tune and my v11 trans tune, and ACIS changes. Tons of hills and steep grades as well as a good chunk of headwinds to deal with. The trans tune allowed me to hold gears longer in lockup, use cruise control better etc which made drive ability soooo much better, and the engine tune definitely made for better MPG's and standard driving power.
    Its well worth it for sure!
  6. Sep 3, 2019 at 9:56 PM
    #4406
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    Can’t wait to get one! I’ll be ordering here shortly! This is exactly what I was hoping to hear. Holding gears a bit longer is probably my biggest complaint with how the transmission logic is setup. I hope it makes going up small grades much less eventful as far as shifting is concerned with cruise control on. So excited!!!
    JustDSM likes this.
  7. Sep 4, 2019 at 7:59 AM
    #4407
    nd4spdbh
    SoCal
    cruise behaves a smidge better... but the issue with cruise isnt necessarily the trans logic, its the logic of how cruise reacts to stuff (too slowly, then overreacts). Holding on to gears a bit longer makes it to where it can act slowly and overreact within the same gear.
    henryp likes this.
  8. Sep 4, 2019 at 8:16 AM
    #4408
    TacoFergie
    Iowa
    That's exactly what I was thinking, just couldn't put down as well as you were able to. For me it's the rolling hills of Iowa and South Dakota that bother me. Not really big hills but there's no reason it should over-react like it does on them.
  9. Sep 4, 2019 at 8:19 AM
    #4409
    nd4spdbh
    SoCal
    Yup, It will still overreact for sure, but my incidences of cruising along in 5th locked, then cruise downshifting to 3rd have probably been halved. Lots of times I mitigate any issues with gear hunting by simply popping it into 4th while in cruise before i see a hill coming, this will get it into 4th lockup, and with the trans tune and how much more aggressive it is with holding lockup in 4th cruise is just able to do its thing right up the hill without much wavering from set speed.
    TacoFergie[QUOTED] likes this.
  10. Sep 4, 2019 at 8:54 AM
    #4410
    TacoFergie
    Iowa
    This make me so happy to hear!! haha
    nd4spdbh[QUOTED] likes this.
  11. Sep 4, 2019 at 7:05 PM
    #4411
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Got my ECU back from hptuners! Doing the immobilizer handshake. Finally gonna get a tune on her!
    05Taco4x4 and JustDSM like this.
  12. Sep 4, 2019 at 7:07 PM
    #4412
    S.B.
    Sean
    San Diego
    15 Taco
    @JustDSM I'll be paying you some money soon for your tune
    JustDSM likes this.
  13. Sep 4, 2019 at 7:12 PM
    #4413
    JustDSM
    Justin
    Ogden, UT
    Whenever you’re ready buddy! Hit me up and we’ll get you dialed.
    deeezy likes this.
  14. Sep 4, 2019 at 7:15 PM
    #4414
    S.B.
    Sean
    San Diego
    15 Taco
    Just need to see how I like nd4spdbh's trans tune works first, then on to the engine
    deeezy likes this.
  15. Sep 4, 2019 at 10:26 PM
    #4415
    S.B.
    Sean
    San Diego
    15 Taco
    @nd4spdbh I'm on a mix of your v10 and v11, not getting lock up in 4th (unless I manually shift it and release and press the gas like stock), running between 40-50% pedal and 3500rpm around 65-70, what values to help lock 4th do I need to change?
  16. Sep 5, 2019 at 7:59 AM
    #4416
    nd4spdbh
    SoCal
    Were they able to recover a bricked ECU?
    I believe there is some other logic we are not seeing wherein the trans takes a look at how close other events are. That is I feel, it wont lockup in 4th if it sees that its likely going to be hitting a 4 to 5 shift within x amount of time.
    With the v11 tune my truck will lockup in 4th no problem (definitely a smide earlier than stock which is how i have it setup), in 4th or D, but in D it will typically only lockup if im climbing a hill and it downshifts and stays in 4th (as if i moved the shifter to 4th). Also at lower throttle inputs the 4th lockup event can be rather subtle and hard to feel, best just run some logging and add TCC Lockup state and Trans Current gear so you can really see whats going on.
  17. Sep 5, 2019 at 9:15 AM
    #4417
    S.B.
    Sean
    San Diego
    15 Taco
    Yes they did recover the ecu.
    Its when I'm climbing a hill, it shifts to 4th right away and stays in 4th the whole time but no lock (watching the rpm), but I shift it into 4 then I can get it to lock.
    So on the line graphs, are we talking area above the curve is when it locks?
  18. Sep 5, 2019 at 9:18 AM
    #4418
    Fleabag
    Uriah
    Vancouver, WA
    @nd4spdbh @JustDSM
    Thanks a bunch for the info folks, I am convinced to get the unit.
    Can I assume the process is a matter of flashing the ECU and unplugging the dongle? Also I assume the Pro version would be over kill as I am not looking for that kind of data, at most I could want would be the ability to display sensors that do not have gauges such as the trans temp, but I am not sure this unit supports that or is the best method for me.
    So in summary I should purchase a MPVI2, one Credit, and subsequent tunes from you gentlemen?
    Anticipated cost of the tunes?
    Thanks in advance.
  19. Sep 5, 2019 at 9:23 AM
    #4419
    nd4spdbh
    SoCal
    If its in 4th and is staying in 4th, it will lock if you are above the 4th apply curve based on driveshaft rpms and throttle input. Being on 35's with extra armor you are likely much deeper into the pedal than a stock truck so lockup might be harder to achieve unless you back off the throttle a bit to get your position on the graph above the lockup curve then you can get back in it.
  20. Sep 5, 2019 at 9:30 AM
    #4420
    nd4spdbh
    SoCal
    Process is as described, plug dongle in and follow proper procedures to flash the truck (ideally you do it in your garage on some sort of battery tender, making sure all accessories are off etc.... you dont wanna brick your ecu out in the wild).
    There is no need for the pro version unless you want to data log external sensors (wideband o2 sensor etc), non pro can log all sorts of things including both trans pan and torque converter output temp.
    For purchase you will need the MPVI2, and 4 universal credits 460-500 bucks depending on where you buy them from.
    My trans tunes are public and free because its pretty simple changes without much needed knowledge (compared to engine - spark n fueling etc), engine tunes talk to JustDSM.
    1slow4.0, JustDSM and Fleabag[QUOTED] like this.
