HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Sep 13, 2019 at 2:23 PM
    #4481
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    You should have it now.
  2. Sep 13, 2019 at 3:07 PM
    #4482
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    At the dunes, truck is running great, was loosing power at full throttle, i think it was the protect high load stuff, max out the delay and adjusted max fuel to match my fuel setting now it seams fine.
    Pulls straight up the dunes no bogging, used to stall out on big dunes, now just holds steady and pulls. Between 3000 and 4000 this engine has tons of torque.
    I also have 5th gear in 4 low for cruising.
    nd4spdbh and S.B. like this.
  3. Sep 13, 2019 at 4:10 PM
    #4483
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I've definitely noticed the power loss in the dunes! Good to know there's a way around that
  4. Sep 14, 2019 at 7:53 AM
    #4484
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Wanting to data log for JustDSM and flash Nd4spd's V11 trans tune but am having a hard time getting the latest Beta version to run/download this morning. What am I doing wrong?
  5. Sep 14, 2019 at 9:03 AM
    #4485
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    whats it doing? (or not doing)
  6. Sep 14, 2019 at 10:09 AM
    #4486
    kgamsg
    kgamsg RedTaco
    Kevin
    Huntsville, AL
    PreRunner Sport
    Hard Tonneau, Cat-Back Exhaust, Heated Leather, Power Slider, OEM Running Boards
  7. Sep 14, 2019 at 10:11 AM
    #4487
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I think I got it. Just un-installed and re-installed it. Thanks!
    JustDSM likes this.
  8. Sep 14, 2019 at 10:12 AM
    #4488
    1slow4.0
    1slow4.0 Be at Peace Brother
    Nick
    Colorado
    2012 TRD OR
    JustDSM and kgamsg[QUOTED] like this.
  9. Sep 14, 2019 at 10:29 AM
    #4489
    kgamsg
    kgamsg RedTaco
    Kevin
    Huntsville, AL
    PreRunner Sport
    Ordered!!! Coming in on Thursday!!! Now, back to my reading assignment...catching up to you guys here on page 225...i'm on page 85...lots of good data coming from some good peeps...
  10. Sep 14, 2019 at 7:21 PM
    #4490
    shr133
    Muskego, WI
    2010 V6 Sport
    I even notice on my street pulls something seamed weird and at the dunes the pulls are so long you know for sure something is up, but ran again today and no problems so I must have fixed it... 3rd in 4low 3500-4000 will climb any dune with no bogging, just climbs right up......
    S.B.[QUOTED] likes this.
  11. Sep 14, 2019 at 7:27 PM
    #4491
    shr133
    Muskego, WI
    2010 V6 Sport
    Lost my tail pipe on the dunes today, so my new exhaust project is being stated early. For N/A do you guys like 2.5 or 3 inch??? I had a 2.5 cat back, and seams like it runs better without the tail plpe.
  12. Sep 14, 2019 at 7:46 PM
    #4492
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Lost your tail pipe? Like the whole muffler or just the tip of the exhaust after the muffler?
  13. Sep 14, 2019 at 7:51 PM
    #4493
    shr133
    Muskego, WI
    2010 V6 Sport
    It broke at the muffler so I had to tear it off, so I still have a muffler, just no tail pipe. It was old and rusted I knew it about done. Have to fix/upgrade it now.
  14. Sep 14, 2019 at 7:56 PM
    #4494
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    If it broke after the muffler, the truck shouldn’t run any different than before. Might have a different sound in the cab based on where the muffler was located and where it broke, but there will be no performance gains. Not saying that you shouldn’t do something about it, just saying that your truck magically running better because you lost the last 3 feet of tube after the muffler is probably in your head because it sounded better from the drivers seat.
    Norton and Torspd like this.
  15. Sep 14, 2019 at 8:51 PM
    #4495
    shr133
    Muskego, WI
    2010 V6 Sport
    Maybe, I have to see tomorrow...
  16. Sep 14, 2019 at 9:40 PM
    #4496
    S.B.
    Sean
    San Diego
    15 Taco
    Dam! I'm usually screaming 1 and second, third is out of the question! I'll be giving it a try.
  17. Sep 15, 2019 at 7:15 AM
    #4497
    nd4spdbh
    SoCal
    What did you end up changing?
  18. Sep 15, 2019 at 7:16 AM
    #4498
    nd4spdbh
    SoCal
    Anytime I have ever been in the dunes 4low and 3rd gear has been the sweet spot for sure.
  19. Sep 16, 2019 at 1:50 PM
    #4499
    shr133
    Muskego, WI
    2010 V6 Sport
    Component protect section, high load settings, max delay and matching the the max F/A ratio to match my high load F/A . Nothing shows up on logs, demanded fuel shows the same and I'm past the range of the o2 sensor so is just maxed out. But no more problems so I can only assume that in high load it was changing the fuel. I don't know if it adds or replaces the fuel settings. I may also match the high load map to my high load settings to 0 everything out.
    S.B. likes this.
  20. Sep 16, 2019 at 5:26 PM
    #4500
    HPTuners
    HPTuners Well-Known Member
    Hi guys,
    Just letting you know we've been working on a lot of writing improvements over the past few weeks. Faster writes and better recovery methods coming soon!
    Also, the 2TR work got a little bit backburnered for now but hopefully will pick it up again soon.
    Chris...
