HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Sep 16, 2019 at 5:38 PM
    #4501
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Heck yeah on all of that!
  2. Sep 17, 2019 at 7:40 AM
    #4502
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Continued progression from the manufacture. HELL YES!
    Id be curious if you guys can unlock more stuff on the auto trans side of things. Auto downshifting when hills are detected, hanging onto gears... the "intelligent" stuff the trans likes to do.
    12TRDTacoma, Turdyota3000 and JustDSM like this.
  3. Sep 17, 2019 at 7:41 AM
    #4503
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    :confused:
  4. Sep 17, 2019 at 7:45 AM
    #4504
    nd4spdbh
    SoCal
    There are times when our auto trans behaves outside of what the up / downshift maps have laid out. There are "intelligent" functions of our auto trans that look at things like riding the brakes downhill wherein it will downshift to 3rd gear on its own and as the end user, you can come up from that one gear at a time by going D to 4 back to D, or straight back to 5th gear by going D to N back to D. Another example is hanging onto say 3rd or 4th gear after you crest a long hill.
  5. Sep 17, 2019 at 7:48 AM
    #4505
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    That look I give when I find out my truck is actually smarter than I am.
    JacksonTacoma and smelly621 like this.
  6. Sep 17, 2019 at 7:52 AM
    #4506
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Didn't know the D N D back to 5th. Cool!
    nd4spdbh[QUOTED] likes this.
  7. Sep 17, 2019 at 8:46 AM
    #4507
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    The emoti was just a fun poke at anything "intelligent" in the TCU. :p
    JustDSM and nd4spdbh[QUOTED] like this.
  8. Sep 17, 2019 at 8:54 AM
    #4508
    nd4spdbh
    SoCal
    hahaha
  9. Sep 18, 2019 at 7:45 AM
    #4509
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Question on used ECUs, as I've been a bit paranoid about bricking my ECU on an update. I've gotten my ECU numbers and checked out eBay/others and seen several. But, my question is, is there any way to verify that the ECU is good? I suspect the only method is to get one and swap it out, but thought I'd check if there's any other method.
    JustDSM likes this.
  10. Sep 18, 2019 at 7:49 AM
    #4510
    zippsub9
    Halfmoon, NY
    14 DCLB
    Unless you can bench test it. Most junkyards don’t offer any refunds on anything electric for this reason and the fact that A-holes will try and return their broken stuff after getting a good one. I have had good luck taking their word on the condition of the vehicle prior to stripping. They can quickly reference wether the vehicle was submerged or totaled in an accident and usually if it was running when it came in since they will be trying to harvest the engine as well.
    Norton, Lurkin[QUOTED] and JustDSM like this.
  11. Sep 18, 2019 at 7:51 AM
    #4511
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    This has been my experience as well. I've purchased two ECU's from LKQ and they came through with good ECU's.
    Lurkin likes this.
  12. Sep 18, 2019 at 8:03 AM
    #4512
    JustDSM
    Justin
    Ogden, UT
    With these recovery methods, would it be possible to recover ECUs that have been bricked prior to these updates?
    mightytacoman likes this.
  13. Sep 18, 2019 at 9:26 AM
    #4513
    smelly621
    smelly621 Well-Known Member
    SF Bay Area
    2011 AC TRDOR 6MT
    It's DLX son!
    @JustDSM - Any final word on your hunch about pre-2012 trucks behaving a little differently?
    Been enjoying my 3 deg. retarded cam gears on your base N/A tune - wondering if I'm leaving some advance on the table now, but wanted to wait to bug you for help until you had some conclusions since I'm a 2011.
    mightytacoman and JustDSM like this.
  14. Sep 18, 2019 at 11:38 AM
    #4514
    JustDSM
    Justin
    Ogden, UT
    I do have updates to share on this. Short answer is: Yes! There is a difference in operation between 2005-2011 and 2012-2015. I've got some work to do, to prepare a post about it (screenshots and all) but I'll make sure it's done. What you guys need to know for now, is the COT EQ Base table is not used in the earlier ECU as a fuel adder map even though the software indicates the COT is "Enabled".
    Glad to hear the base tune is rocking for you, even more-so with the cam gears I'm sure. I'd wager we could spice it up a little with the gears installed based on the data I've collected thus far. I'd be happy to take a look at if for you if you'd like to pursue?
  15. Sep 18, 2019 at 11:41 AM
    #4515
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    I haven’t had a ton of seat time with my latest tune yet but what little I have done feels great. I may or may not have surprised a few cars on the interstate. I can’t wait to hook up to my trailer and see how much better it is with the new tune.
    BassAckwards and JustDSM[QUOTED] like this.
  16. Sep 18, 2019 at 11:45 AM
    #4516
    JustDSM
    Justin
    Ogden, UT
    You went from STOCK to out-modding me! I've got to get my cam gears, thermostat, and throttle body installed.. Makes me happy to hear you're enjoying the truck. Keep the logs coming and we'll keep it fresh!
  17. Sep 18, 2019 at 12:41 PM
    #4517
    HPTuners
    HPTuners Well-Known Member
    Yes, but it requires opening the PCM, some very basic soldering skills and use of a bench harness
  18. Sep 18, 2019 at 12:43 PM
    #4518
    JustDSM
    Justin
    Ogden, UT
    That's still fantastic news! Big thumbs up!
  19. Sep 18, 2019 at 12:46 PM
    #4519
    nd4spdbh
    SoCal
    Details on this would be ideal.
    12TRDTacoma and Norton like this.
  20. Sep 18, 2019 at 12:48 PM
    #4520
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
