HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Dec 6, 2019 at 2:25 PM
    #5021
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    N/A stroker setup in your future?:D
    DiamondW[QUOTED] likes this.
  2. Dec 6, 2019 at 2:39 PM
    #5022
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Only while he waits for twin Nagasaki noisy boiz
  3. Dec 6, 2019 at 3:25 PM
    #5023
    Au1gr
    Au1gr Well-Known Member
    Daniel
    Perth, AUS
    @asgardengineering already has very silly ideas about this. I’m quite excited.
  4. Dec 6, 2019 at 3:26 PM
    #5024
    nd4spdbh
    SoCal
    asgardengineering likes this.
  5. Dec 6, 2019 at 3:28 PM
    #5025
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    haha! Y’all got jokes still! I don’t know exactly what I’m gonna do yet, bet I think it will end up cooler that way.
    BassAckwards[QUOTED] likes this.
  6. Dec 6, 2019 at 3:29 PM
    #5026
    Au1gr
    Daniel
    Perth, AUS
    Lets be serious here for a moment.
    How much injector PW we using stock... dry shots are way easier to plumb
    BassAckwards and JustDSM like this.
  7. Dec 6, 2019 at 4:42 PM
    #5027
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    My truck with only an exhaust was seeing 85% IDC. I went with the TRD Injectors (Thanks @Roostfactor) for my N/A truck. For a N/A dry N2O setup, you're going to want more injector IMHO.
    Roostfactor and BassAckwards like this.
  8. Dec 6, 2019 at 10:32 PM
    #5028
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    Well that would be crazy if a TRD supercharged engine gets over 400 rwhp without nitrous. I know the expected mods and upgraded Kelford cams MIGHT. ;)
    12TRDTacoma and JustDSM[QUOTED] like this.
  9. Dec 7, 2019 at 12:19 AM
    #5029
    JustDSM
    Justin
    Ogden, UT
    Also working with Rotrex folks.
    4.5L cammed engines with more RPM and the MP90 will get it done too I believe. We’ll certainly see. But I’m with you, in that I believe there’s only so much that can be done with the TRD/Magnusson setup.
    12TRDTacoma likes this.
  10. Dec 7, 2019 at 3:40 AM
    #5030
    Au1gr
    Daniel
    Perth, AUS
    I wonder how far you could reliably push the duty cycle into the 100s maintaining fuel pressure and a safe afr. I doubt to far with only 40lb in the rail
  11. Dec 7, 2019 at 6:44 AM
    #5031
    BillDaCat8
    BillDaCat8 Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
  12. Dec 7, 2019 at 6:48 AM
    #5032
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Not just you!
    But I do like the international turn this thread has taken!
  13. Dec 7, 2019 at 7:30 AM
    #5033
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    And no more than a 30 shot, if longevity is wanted.
    Roostfactor and JustDSM[QUOTED] like this.
  14. Dec 7, 2019 at 9:20 AM
    #5034
    nd4spdbh
    SoCal
    How are you calculating IDC? (Assuming a function of injector pulse width? ).
    Also was that 85% with stock injectors or the TRD ones on the NA setup?
  15. Dec 7, 2019 at 9:52 AM
    #5035
    JustDSM
    Justin
    Ogden, UT
    I’m using the built in math functions in the VCM Scanner. It’s a function of IPW. It’s essentially a ratio of how much time your injectors are open versus time available, so it’s dependent on RPM. As RPM’s increase the time available to inject the necessary volume of fuel (to maintain a specified AFR) is decreased, so assuming airflow through the motor was in a steady state, the IDC would go up as the time avail. decreased.
    You can find calculators and formulas if you’re the curious type (and I know you are!) online. Otherwise, log RPM and IPW and let VCM Scanner do the math ;)
    I was seeing 85% with the stock N/A injectors (~320cc/min). I’d have to look to see where things are now with my setup in my sig.
    Roostfactor likes this.
  16. Dec 7, 2019 at 9:53 AM
    #5036
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    I think you can change the value in the log from ipw time to % but not sure.
    The 85% was with stock 330cc injectors, not the TRD SC 455cc injectors.
  17. Dec 7, 2019 at 9:56 AM
    #5037
    Roostfactor
    TX panhandle
    Beat me to it with more detail. :D
    Torspd and JustDSM[QUOTED] like this.
  18. Dec 7, 2019 at 10:42 AM
    #5038
    Au1gr
    Daniel
    Perth, AUS
    https://youtu.be/C44s_GxzebI
    This bloke is also, not interested in spiders
    DesertRatliff and JustDSM like this.
  19. Dec 7, 2019 at 3:33 PM
    #5039
    JustDSM
    Justin
    Ogden, UT
    Thought I'd share my setup. I've seen a post on another forum asking how folks store/carry their MPVI2's. How do you guys store/carry your MPVI2/cables?
    Conveniently fits everything needed minus Laptop and WiFi.
    Contents:
    HPTuners MPVI2
    HPTuners Supplied 6ft USB-A to USB-C
    CableCreation 0.5ft USB-A to USB-C (For desktop use/remote tuning)
    MoKo Power Adapter Case
    Norton, henryp, DesertRatliff and 3 others like this.
  20. Dec 7, 2019 at 3:49 PM
    #5040
    12TRDTacoma
    Rob
    Concordia
    Boosted
    To the crank I know at least a handful of us are hitting over 400 easily, the wheel horsepower is a different story due to all the parasitic drivetrain losses.
    100 HP / liter is not too bad for these fat pigs.
    @JustDSM what were your reported IDC's after switching out to the TRD injectors?
