HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Dec 15, 2019 at 3:49 PM
    #5201
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Getting an ECU from here to you ain’t a big deal. Shoot me your specs, year, trans. I gotta pick up a spare ECU for myself as well anyway.
    Philby, nd4spdbh and DesertRatliff like this.
  2. Dec 15, 2019 at 10:27 PM
    #5202
    Au1gr
    Au1gr Well-Known Member
    Daniel
    Perth, AUS
    anyone able to get me the part numbers of the 5 connectors on dash loom going into the ecu. SHOULD be a 5 digit number embossed on the rear of the plug at the bottom ?
  3. Dec 16, 2019 at 2:04 AM
    #5203
    asgardengineering
    asgardengineering Well-Known Member
    Sydney, Australia
    Toyota Hilux SR5
    :burnrubber:
    Torspd[QUOTED] likes this.
  4. Dec 16, 2019 at 2:05 AM
    #5204
    asgardengineering
    Sydney, Australia
    Toyota Hilux SR5
    I've got them somewhere already. Can buy replacements from Toyota.
  5. Dec 16, 2019 at 2:13 AM
    #5205
    Au1gr
    Daniel
    Perth, AUS
    Tacoma or hilux?
  6. Dec 16, 2019 at 2:29 AM
    #5206
    asgardengineering
    Sydney, Australia
    Toyota Hilux SR5
  7. Dec 16, 2019 at 2:32 AM
    #5207
    Au1gr
    Daniel
    Perth, AUS
    Sling em this way and ill start on some patch looms after xmas
  8. Dec 16, 2019 at 2:34 AM
    #5208
    asgardengineering
    Sydney, Australia
    Toyota Hilux SR5
    Yeah I'm actually doing all that in a spreadsheet with connector part numbers right now.
    Torspd likes this.
  9. Dec 16, 2019 at 4:37 AM
    #5209
    asgardengineering
    Sydney, Australia
    Toyota Hilux SR5
    Ok, going through the factory Tacoma wiring diagrams. Looking at the 2010 one linked earlier, Apparently Pin J3 (connector E14, pin 3) is shown to be used for both FPR and ST1-. Same goes for Pin J3, used for both EPA and FC. I think someone at Toyota made a boo boo.:annoyed:
  10. Dec 16, 2019 at 5:17 AM
    #5210
    Au1gr
    Daniel
    Perth, AUS
  11. Dec 16, 2019 at 7:19 AM
    #5211
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Maybe an 09 pinout might show a difference, or does that pinout range from 09-11?
    The 05-08 will be slightly different than the 09-11. One member did a resolder job, to be able to use the UCON on an 09+ before the plugs 09 plugs were available. He documented everything.
  12. Dec 16, 2019 at 7:24 AM
    #5212
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  13. Dec 16, 2019 at 7:42 AM
    #5213
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    This is for 2012+ which should only have the addition of the SAIS stuff over the 09-11 connectors. Looks like
    FPR = J8
    ST1 = I8
    EPA = J3
    FC = I3
  14. Dec 16, 2019 at 8:21 AM
    #5214
    elnip
    elnip Well-Known Member
    LC,NM
    '98 Tacoma TRD S/C'd / /'16 T4R Trail
    Taco SC'd, fuel mods, Supra TT MAF, TRD Headers, Water Meth Injection, Tundra Brake upgrade Trail w/URD EL Headers. JFR EL Y-pipe, URD Hi Clearance cat back, KDMAX Tune, 4.56's
    Still no support from @HPTuners regarding the Dual VVT-I. Mine is 335F5000....missed it by one F
  15. Dec 16, 2019 at 9:25 AM
    #5215
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Hopefully it’ll be released soon. I want to get out 4Runner tuned and since I already have hpt for the taco we will just need to buy credits when it’s released.
    elnip[QUOTED] and ebuyaer2002 like this.
  16. Dec 16, 2019 at 9:31 AM
    #5216
    ebuyaer2002
    ebuyaer2002 Well-Known Member
    Nate
    Salem, OR
    08 Tacoma TRD OR DCSB 6 Speed
    RC 6" lift, icon coilovers, DK uppers, URD intake, DT Longtube Headers, Cam gears, 70mm throttle body, Custom Tuned with HPTuners
    Same. I cant wait to see the difference it'll make.
    elnip likes this.
  17. Dec 16, 2019 at 9:43 AM
    #5217
    elnip
    LC,NM
    I'm running a beta tune from Matt @OVT now but he is busy with other things to concentrate on the 4R. Always in for options.
  18. Dec 16, 2019 at 9:47 AM
    #5218
    OVTune
    OVTune Well-Known Member
    OVTune
    We've actually been working further in the 4R ecu, but have come up with several limitations.
    a lot of the calibration tables simply aren't in there. The transmission tables, torque control tables, torque converter, etc.
    it all must be in a separate TCU that we cannot access.
    We're limited to throttle, cams, ignition, fuel, etc only "engine" stuff.
    elnip[QUOTED] likes this.
  19. Dec 16, 2019 at 9:49 AM
    #5219
    nd4spdbh
    SoCal
    Thats surprising considering it utilizes the same 5 spd auto as the 2nd gen tacos.
  20. Dec 16, 2019 at 9:50 AM
    #5220
    OVTune
    OVTune
    believe me I have looked in the file 100 times and cannot find the trans control data at all.
