HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Dec 28, 2019 at 6:42 PM
    #5361
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    DG92071 likes this.
  2. Dec 28, 2019 at 8:02 PM
    #5362
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Shit, I thought that was a silly joke. That sucks but I always say shitty experiences make for the best stories. So there's that I guess...
    GT7[QUOTED] likes this.
  3. Dec 28, 2019 at 8:21 PM
    #5363
    GT7
    Grant
    Phoenix
    2013 DCLB
    Its a joke I have normally seen in the firearm community as in “ lost in boating accident is where the gun is when gov comes knocking” so its a joke to include sai being deleted in a “legal” way
  4. Dec 28, 2019 at 9:13 PM
    #5364
    TodayWasTHeDaY
    Russ
    Calgary
    Well that one soared over my head into the great beyond lol
    420taco, DG92071 and GT7[QUOTED] like this.
  5. Dec 29, 2019 at 3:40 AM
    #5365
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Cant we just delete the codes and limp mode in HP Tuners if the SAI gets lost in a boating accident? Why the need for this swap?
    zippsub9 likes this.
  6. Dec 29, 2019 at 4:19 AM
    #5366
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Damn, some of my firearms and SAI were on your boat too that day... ;)
  7. Dec 29, 2019 at 8:07 AM
    #5367
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Haha, naw i got em ill put them in at some point just gotta find the time. And dude... cmon no breakaways in the engine cage?
    For off road use, yes, yes you can. You can turn off the CEL's for it, and move the SAI limp mode throttle blade angle back up to full throttle. But i think this was more meant for those that want again, for off road use, the ability to get rid of it for ~ 50-100 bucks (cost of a 2009-11 ecu)
  8. Dec 29, 2019 at 8:57 AM
    #5368
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    So a bit of an update on the 2009-2011 ECU in a 2012-2015..
    I've purchased a 2009 ECU to fit into my 2015, and due to closing on a house December 23rd, moving the 24th and unpacking that night in preparation for having family over to the new place for Christmas Dinner, I just wasn't able to get in to verify the "swap" yet.
    Well, @12TRDTacoma got ahead of me and performed the swap as noted a few posts back. All works great!.. With the exception of the Temp gauge. The truck runs/operates exactly as it should. Tach works, CEL works (with no codes :D) and everything else you'd expect works as designed. @12TRDTacoma noted coolant temp was checked via OBD2 scanner and temps were reporting ~190ºF as expected. Odd I thought..
    I found it extremely difficult to believe that Toyota changed JUST the coolant temp address/bit on the BUS. And found it equally difficult to believe that the gauge failed at the exact timing of the swap. So we troubleshooted/brainstormed for a bit and found a unique wiring difference on the Coolant Temp Sensor in the 2011 for a particular build (without VSC) and thought we might have found the culprit. Right about the time he signed off for the evening, I noticed one discrepancy that I missed when doing the pin-out mapping.
    I went through things using the 2012+ diagram as my "master", going pin-by-pin confirming the plug/pin location for each wire. As noted previously EVERYTHING is identical (SAI excluded) EXCEPT the 2009-2011 have one pin (E13, pin 19) that is fed directly to the temp gauge in the cluster from the ECU. 2009-2011 trucks do not have the coolant temp gauge on the CAN BUS network while 2012-2015 Trucks drive the coolant temp gauge off the CAN BUS. I originally missed this, as I mentioned I looked at this from a 2012 centric view.
    So what does this mean?
    Simply put, the '09-'11 ECU swap is still viable, especially for those that need to not have any trace of the SAI system for whatever reason (*Cough*). Just be aware that the coolant temp gauge will not function during a simple ECU swap. All other systems/functions are 100% operation, so the truck is good to drive/tune.
    What about being able to monitor coolant temp? Great question. There's a few ways this can be tackled. Some are considerably more complex (ie: niche) than others. But there are solutions, for those that need this for certain reasons.
    1. Getting the '12+ gauge to work in the cluster will require some work but can be done by broadcasting over the CAN BUS. It's not a plug-n-play kind deal, and requires some other hardware.
    2. Wiring in an aftermarket coolant temp gauge
    3. Using OBD2 scanning gauge (ie: Scangauge II or similar)
  9. Dec 29, 2019 at 9:15 AM
    #5369
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Id I'd be interested in the first option to keep things as clean as possible.. ultimately though, if I have to get a scan gauge or have to get a dual coolant gauge for both the engine and blower as part of my boost and AFR gauge setup I don't have an issue with that either. I PM'ed you so if there is any leg work you need me to do on this thing or investigative work, I'm all in!
    JustDSM[QUOTED] likes this.
  10. Dec 29, 2019 at 9:37 AM
    #5370
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    So I’m running my ovtune in my 14 supercharged Tacoma. I ironically have an aftermarket AEM temp gauge on my cluster........would there be a way you could track down a 09-11 ECU, tune it with HP (for off road use :cool:), and ship it to me? I’d pay whatever you needed ofcourse. Then at that point once I received it, I could just swap my ECU with one that had hp with added goodies plus I’d have my original with Ovtune as a spare??
    SUMOTNK and JustDSM[QUOTED] like this.
  11. Dec 29, 2019 at 9:44 AM
    #5371
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Because you live in Commifornia like I do and this permanently deletes SAI out of the equation via hardware which ultimately affects it via software.
    If you don't do it, there exists a small chance that despite code deletions and disables that you may have a pending and stored code for SAI in your PCM and if you smog your truck and they catch that despite the check engine light being on you will fail everytime.
    It's a doable thing but you would be paying some good casholas for it. The computer would be anywhere from $50-200 alone, after that you have to reflash the VIN to your trucks VIN which may cost you extra, then relicensing the HPTuners software for that calibration PCM will cost 4 additional credits which will be $200 additional. After you get the PCM you then have to perform an immobilizer reset which no one can do but you alone which will cost you 30 minutes of your time additional to the PCM install time it will take you to do so.
    In short, you are easily looking at $5-800 for all of the hardware to arrive to you all modified and ready to plug and play like you want, @JustDSM would probably be out some time which is why I add in the few extra hundred in costs and if you go to the dealer or am outside mechanic to do the immobilizer reset or PCM install or both, that would drive the cost up as well.
    DesertRatliff and JustDSM like this.
  12. Dec 29, 2019 at 9:51 AM
    #5372
    JustDSM
    Justin
    Ogden, UT
    I can go as far as supplying you a complete setup, or just doing the electronic work.
    Estimate:
    2009-2011 ECU: ~$150
    TRD Tune/VIN recalibration: $75 ($50 w/ HP Tuners Tune)
    HPTuners credits $200
    ~$400 out the door for an ECU already setup/tuned in HPTuners to your spec. Of course will vary depending on the ECU but most of the earlier ones are about $150.
    Correct, as @12TRDTacoma mentioned, you could keep your OV ECU as a spare. You'd just be out 30 min of your time and a paperclip to swap them.
    SUMOTNK likes this.
  13. Dec 29, 2019 at 10:09 AM
    #5373
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Damn you Commifornia! Thanks for the explanation. :thumbsup:
    12TRDTacoma[QUOTED] likes this.
  14. Dec 29, 2019 at 10:10 AM
    #5374
    OVTune
    OVTune Well-Known Member
    OVTune
    I could always remake my tune in a hpt file for you, that way you could have both, and tune from mine if you wanted to.
    It just won't have our extended tables, just stock TRD sized tables.
    Torspd, SUMOTNK, Murphinator and 2 others like this.
  15. Dec 29, 2019 at 10:19 AM
    #5375
    nd4spdbh
    SoCal
    Im curious, for someone looking for the plug and play nature that you describe, why stray from the OVtuned setup?
  16. Dec 29, 2019 at 10:21 AM
    #5376
    OVTune
    OVTune
    If I could answer, it's probably because he has a handheld, and is adding mods, smaller pulleys,etc, kind of beyond what can be done without individual logging and dialing in for maximum benefit.
    And because updating tunes on handhelds (on our side) is a bit of a cumbersome process
    nd4spdbh[QUOTED], zippsub9 and Norton like this.
  17. Dec 29, 2019 at 11:42 AM
    #5377
    JustDSM
    Justin
    Ogden, UT
    Care to post a pic of how you installed your coolant temp gauge in the stock cluster?
  18. Dec 29, 2019 at 11:50 AM
    #5378
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I’m more than happy with your tune, mods are done. Only thing I may add (but probably won’t is going from a 2.7 to a 2.6)......the only reason I’m at all interested in hp is to get rid of a certain manufacturer add on which is for off road use only.......
  19. Dec 29, 2019 at 11:52 AM
    #5379
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Lord Helmet and JustDSM[QUOTED] like this.
  20. Dec 29, 2019 at 11:52 AM
    #5380
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I may have worded that wrong......my temp gauge is on my column. It’s on the right. I used an inline sensor in my upper coolant hose.
