HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Dec 29, 2019 at 11:58 AM
    #5381
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    Just to get rid of a certain something .....for off road use.
  2. Dec 29, 2019 at 1:19 PM
    #5382
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    gotcha ;-)
  3. Dec 29, 2019 at 2:40 PM
    #5383
    Au1gr
    Au1gr Well-Known Member
    Daniel
    Perth, AUS
    Would an 9-11 cluster in a 12+ work?
    @OVTune you think this would be an issue in the AUDM kline rubbish? I got a 12 hilux i needa try and get a taco ecm to control
  4. Dec 29, 2019 at 2:46 PM
    #5384
    12TRDTacoma
    Rob
    Concordia
    Boosted
    JustDSM and I have been wondering the same thing. If it's a broadcast signal issue then the issue may be as simple as taking the signal and changing it apparently. The issue with that, however, is that none of us are fully educated with CAN network to the point to make mods to that extent and fix it properly at the monent. JustDSM may be investigating it because this will be an issue which will affect his 2015 as well and any other 2012-2015 owner switching out their PCM for a 2008-2011 PCM at this moment.
  5. Dec 29, 2019 at 2:51 PM
    #5385
    Au1gr
    Daniel
    Perth, AUS
    There is hardware out there that will convert. A mate put a 6L80 in his 105 series landcruiser. The bcm used Can for the reverse light. He used a Link or Aim ( suspicion one is made by the other) Can module to convert Can to what i assume a voltage output and switched the relay
    Torspd likes this.
  6. Dec 29, 2019 at 3:02 PM
    #5386
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Interesting. I am not quite educated on the subject matter, so I don't even know how I would even begin to search for something like that.
  7. Dec 29, 2019 at 3:03 PM
    #5387
    Au1gr
    Daniel
    Perth, AUS
    Correction. Was a Can input TO the bcm from the shifter to command the reverse light
  8. Dec 29, 2019 at 3:25 PM
    #5388
    Au1gr
    Daniel
    Perth, AUS
    12TRDTacoma[QUOTED] likes this.
  9. Dec 29, 2019 at 5:42 PM
    #5389
    12TRDTacoma
    Rob
    Concordia
    Boosted
  10. Dec 29, 2019 at 5:56 PM
    #5390
    Au1gr
    Daniel
    Perth, AUS
    Can you send me the pinout? Id love to have a look
  11. Dec 29, 2019 at 6:14 PM
    #5391
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Finances got tight and at $35 a piece for the tubing connectors I had to skip it for now and just finished the cage to get the truck running before winter. They’re an easy add on when funding gets better or if stuff needs to get chopped out
    nd4spdbh[QUOTED] likes this.
  12. Dec 29, 2019 at 6:28 PM
    #5392
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I can send you something possibly later tonight or tomorrow morning. I've been taking things one at a time lately since I've been non-stop under the weather.
  13. Dec 29, 2019 at 6:32 PM
    #5393
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Need to convert analog to CAN in this case. If we were going from 2012+ ECU to 2009-2011 dash we could use something like that.
    We're going to need to add the coolant temp to the BUS to get the gauge to work. I'm "on it" but I'm going to have to do some work to sniff out where the Coolant Temp is on the BUS. Need to get some new toys to sniff around and map things out.
  14. Dec 29, 2019 at 6:34 PM
    #5394
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What a weird issue huh. Out of all things EVERYTHING works EXCEPT that. I'm still trying to wrap my head around why they would change the communication method for that but leave everything else the same.
    Toyota, oh what a feeling. :laugh:
    nd4spdbh likes this.
  15. Dec 29, 2019 at 6:40 PM
    #5395
    Turdyota3000
    Turdyota3000 Well-Known Member
    Round da corner
    07 dcsb trd off-road
    Icon 2.5's, TC, yackety shmackety....
    I’ll donate my truck for experimental purposes!
    :bananadead:
    JustDSM likes this.
  16. Dec 29, 2019 at 6:49 PM
    #5396
    arcenik
    arcenik TRD
    Jon
    2015 X-Runner
    With the 2009 ECU can you read the temp with an obd2 scanner? If so the temp is on the can bus, but its not being picked up by the gauge. Maybe a device ID thing going on?
  17. Dec 29, 2019 at 6:57 PM
    #5397
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes the temp can be read with a scanner. If I remember right, he was thinking it was a potential broadcast signal discrepancy.
  18. Dec 29, 2019 at 8:16 PM
    #5398
    Au1gr
    Daniel
    Perth, AUS
    Analogue to Can makes it easier
    JustDSM[QUOTED] likes this.
  19. Dec 30, 2019 at 3:43 PM
    #5399
    Au1gr
    Daniel
    Perth, AUS
    Also
    Anyone have the PN# for the sockets to go into the ecu harness plugs. Ill have to run twincore from the ecu to my obd plug??
    JustDSM likes this.
  20. Dec 30, 2019 at 4:45 PM
    #5400
    JustDSM
    Justin
    Ogden, UT
