HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Dec 30, 2019 at 4:54 PM
    #5401
    Au1gr
    Au1gr Well-Known Member
    Daniel
    Perth, AUS
  2. Dec 31, 2019 at 4:53 AM
    #5402
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    FIFY. :thumbsup:
    12TRDTacoma likes this.
  3. Dec 31, 2019 at 5:50 AM
    #5403
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    :laugh:
  4. Dec 31, 2019 at 5:56 AM
    #5404
    Au1gr
    Daniel
    Perth, AUS
    With the aussie dollar, theyll be lucky to get the loose change Paypal leaves behind
    nd4spdbh and Torspd like this.
  5. Dec 31, 2019 at 8:25 AM
    #5405
    ebuyaer2002
    ebuyaer2002 Well-Known Member
    Nate
    Salem, OR
    08 Tacoma TRD OR DCSB 6 Speed
    RC 6" lift, icon coilovers, DK uppers, URD intake, DT Longtube Headers, Cam gears, 70mm throttle body, Custom Tuned with HPTuners
    I was searching for an o2 extension harness for my headers and came across this site. They have a ton of different connectors too. Not sure if they'll have the ones you need.
    https://www.bmotorsports.com/shop/
  6. Dec 31, 2019 at 9:16 AM
    #5406
    Au1gr
    Daniel
    Perth, AUS
    Yeah wow, plenty there. Fuck knows which ones for me tho hah
  7. Dec 31, 2019 at 11:09 PM
    #5407
    Au1gr
    Daniel
    Perth, AUS
    Whos bought the pro expansion kit yet?
  8. Jan 1, 2020 at 4:57 AM
    #5408
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Had it from the beginning.
  9. Jan 1, 2020 at 5:19 AM
    #5409
    Au1gr
    Daniel
    Perth, AUS
    Used the wb function much? Or the taco wb sorta negates kt
    JustDSM[QUOTED] likes this.
  10. Jan 1, 2020 at 6:21 AM
    #5410
    JustDSM
    Justin
    Ogden, UT
    Since I’m N/A I’m generally operating within the range of the stock widebands so I’ve not needed to use the analog in.
    On the boosted trucks, it’s so nice to have the aftermarket wideband data in the log, especially when remote tuning.
  11. Jan 1, 2020 at 8:31 AM
    #5411
    Au1gr
    Daniel
    Perth, AUS
    Yeah i didnt think the 1gr would really require it. I have a turbo e85 ls1 im
    Trying to dial in. Maffless with NB and the WB only on the dash is becoming a nightmare. Its like another $350aud tho which is ghey. Itd have paid for dyno by then
    JustDSM likes this.
  12. Jan 1, 2020 at 7:14 PM
    #5412
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm really starting to consider the use of the Pro expansion kit to help you get mine dialed in.
    JustDSM[QUOTED] and zippsub9 like this.
  13. Jan 1, 2020 at 8:33 PM
    #5413
    Au1gr
    Daniel
    Perth, AUS
    I think i already know the answer here. And forgive me for asking about an engine other than a 1grfe. But would it be safe to assume, one of them is fucked if my NB in forced closed loop is showing massive negative fuel trims in the LTFT yet my aem wideband is showing the on the lean side?
  14. Jan 2, 2020 at 10:16 AM
    #5414
    JustDSM
    Justin
    Ogden, UT
    It wouldn't hurt!!
    But we do need to address the MAF overrun situation.
    12TRDTacoma[QUOTED] likes this.
  15. Jan 2, 2020 at 10:23 AM
    #5415
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah that's the biggest issue right now, I think it always has been. Lol. The issue is that I still have to run the OE air cleaner for smog time and a tune made for a 3.5 diameter MAF housing would really screw with the way it runs with the OE housing wouldn't it?
  16. Jan 2, 2020 at 10:54 AM
    #5416
    JustDSM
    Justin
    Ogden, UT
    It would indeed.
    Option would be to have a tune for the OEM intake for testing purposes, then one for your daily duties (ie: 3.5").
  17. Jan 2, 2020 at 12:16 PM
    #5417
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I might just have to revisit the 3.5 intake tube diameter stuff again then. I guess I could probably just run the base TRD tune come smog time and then run the modified TRD tune for when I throw my intake back on.
  18. Jan 2, 2020 at 12:36 PM
    #5418
    JustDSM
    Justin
    Ogden, UT
    That would be how I'd do it.
  19. Jan 2, 2020 at 2:54 PM
    #5419
    mightytacoman
    mightytacoman Mighty-known Member
    Kel
    4.5L 1grfe
    Brian Crower stroker kit, Carrillo pistons moly/ceramic coated, BC sportsman rods, arp s2000 head bolts, Darton M.I.D sleeves, Kelford race cams, Magnusson supercharger, hp tuner tuned, 650cc flow matched fuel injectors, CSF radiator, Walbro 255 fuel pump. pulleyboys quick change pulley with 2.3", fpr mod, NST crank, water and alternator pullies, 160° mishimoto thermostat. Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluids, custom airbox, tundra sized intake. 76mm throttle body, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, URD equal length headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 1- 20" slim light bar in grill, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. North Star agm 27f battery, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    A few of us running a 3.5" intake including myself that could help with a baseline for your MAF tables if or when the time comes.
  20. Jan 2, 2020 at 7:40 PM
    #5420
    Au1gr
    Daniel
    Perth, AUS
    nvmd, my afrs are only set to read for pump not e85. back to lambda it is
    Torspd likes this.
