HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jan 14, 2020 at 7:38 PM
    #5661
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    :rofl:Hilarious! Part of the last tank had me doing doughies in the ski area parking lot for about 20 minutes so I'll just plead "incomplete data". :rofl:
  2. Jan 14, 2020 at 9:00 PM
    #5662
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Empty Ski area parking lot doughnies are fun! I say scientific data collected on throttle response and power
  3. Jan 14, 2020 at 11:13 PM
    #5663
    jpyne722
    jpyne722 New Member
    Josh
    Fredericksburg, Va
    2008 Tacoma XRunner
    Apr x-1 Urd cam gears Urd 170 thermostat 76mm throttle body Nst intake manifold spacer NST Crank, Alternator & Water pump pulley IKH24 plugs Urd tcai Urd short shifter with coupe mod Urd traction bar Urd spec-u longtubes Urd spec-u y-pipe & catback exhaust Urd o2 simulators Xii drop 2in drop coils & blocks
    What’s up guys, I’m new to this whole hp tuner stuff. I’m old school and have always had a ucon or x1. I currently have a x1 but have added a bunch of more parts I’m sure I can squeeze out more power but the lack of knowledge to tune the x1 or support is gone as some of you know lol. I’m real curious on how this ob2 tuner works? How far can you go into the ecu with this? From what I’ve seen over the years, the stock Ecu is pretty hard to crack into. Also how is support for this? Do you data log some pulls at wot and normal driving, send them away and they email you back some files to download?
    JustDSM and Torspd like this.
  4. Jan 14, 2020 at 11:38 PM
    #5664
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You can go as far displaying almost exactly what you want the AFR Gauge to read at any point in time during pedal actuation. The only feature this truck computer does not have pretty much is lean cruise and SD tune capability due to limitations of the actual hardware on the engine.
    Yes, it's that easy. Log some pulls and overall running events, send it off to JustDSM and he'll hook you up for a small nominal fee. I promise you'll be much happier than with UCON. HP Tuners is legendary in the big 3s crowd. Now it's huge amongst the Toyota tuning crowd. It's an amazing time to be a Toyota truck owner that's for sure!
    wheeliest, JustDSM and Turdyota3000 like this.
  5. Jan 14, 2020 at 11:46 PM
    #5665
    jpyne722
    jpyne722 New Member
    Josh
    Fredericksburg, Va
    2008 Tacoma XRunner
    With the MPVI2 is the “ pro feature” really necessary? Also is the software easy enough to mess with to where I could raise my revlimiter back up to 6200 then data logg some runs?
    JustDSM likes this.
  6. Jan 15, 2020 at 6:03 AM
    #5666
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's not necessary but since our AFR sensors top out at 11.9 at the PCM it helps further see how much more rich you are running on the aftermarket wideband you have. It's super easy to raise your rev limiter to 6200. I don't encourage RPMs that high however if you are boosted.
    JustDSM likes this.
  7. Jan 15, 2020 at 3:01 PM
    #5667
    Au1gr
    Au1gr Well-Known Member
    Daniel
    Perth, AUS
    Does anyone know if we have a spare 5v input? Can run WB into HP tuners that way. No need to buy pro link
  8. Jan 15, 2020 at 3:57 PM
    #5668
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That's what I have been trying to figure out myself.
  9. Jan 15, 2020 at 3:58 PM
    #5669
    nd4spdbh
    SoCal
    as far as i know there are not any unused 5v inputs.
  10. Jan 15, 2020 at 4:16 PM
    #5670
    Au1gr
    Daniel
    Perth, AUS
    What about sai?
  11. Jan 15, 2020 at 4:17 PM
    #5671
    Au1gr
    Daniel
    Perth, AUS
    Ls we use either ac pressure or egr position
  12. Jan 15, 2020 at 4:51 PM
    #5672
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    They are keenly aware of ppl circumventing paying for pro features and do not define the mapping for the 5v inputs.
    From a business perspective I get it, from a enthusiast perspective, I want it.
    I say, support those who support us.
  13. Jan 15, 2020 at 5:04 PM
    #5673
    Au1gr
    Daniel
    Perth, AUS
    Are the factory O2s a 5v? Surely you could wire in a pair of uegos and just do custom maths
  14. Jan 15, 2020 at 5:05 PM
    #5674
    Au1gr
    Daniel
    Perth, AUS
    I have the maths for it and your WB will
    Provide the values to enter for the interpretation of its analogue output
  15. Jan 15, 2020 at 5:29 PM
    #5675
    Au1gr
    Daniel
    Perth, AUS
    Hah nvmd. What a retarded idea. Then the ecu wouldnt know what the fuck to do. And with no VE tables you cant turn OL of CL off
    nd4spdbh and Torspd like this.
  16. Jan 20, 2020 at 8:00 AM
    #5676
    JustDSM
    Justin
    Ogden, UT
    Just had my 2015 inspected.
  17. Jan 20, 2020 at 8:05 AM
    #5677
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Oh very nice! Was that with the 09 PCM or your 2015?
  18. Jan 20, 2020 at 8:05 AM
    #5678
    JustDSM
    Justin
    Ogden, UT
    Mhm :)
    MattCowsmasher and smelly621 like this.
  19. Jan 20, 2020 at 8:06 AM
    #5679
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Boom! As to be expected. ;)
    ebuyaer2002 and JustDSM[QUOTED] like this.
  20. Jan 21, 2020 at 7:31 AM
    #5680
    nd4spdbh
    SoCal
    hehe secondary.... obviously, this was for testing purposes to see how your off road only vehicle does from an emissions standpoint :p
    Honestly didnt know that texas did emissions testing! Thought they were a "free" state.
