HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jan 21, 2020 at 7:40 AM
    #5681
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Everything we do here is off-road purposes on our off road only rigs. ;)
  2. Jan 21, 2020 at 7:46 AM
    #5682
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    ....except the on-road speeding ticket I got "not testing" because this latest tune and combo of mods absolutely RIPS!
  3. Jan 21, 2020 at 7:49 AM
    #5683
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    Select counties around the big Metro areas have testing. When I lived 10 min down the road, They checked my headlights and blinkers and that was that.
  4. Jan 21, 2020 at 8:45 AM
    #5684
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I still need this for my trail rig.:boom:
  5. Jan 21, 2020 at 10:55 PM
    #5685
    asgardengineering
    asgardengineering Well-Known Member
    Sydney, Australia
    Toyota Hilux SR5
    Tacoma 2009 ECU arrived today for my Hilux, just waiting on OBD2 crimps and I'll be in business!
    Torspd and JustDSM like this.
  6. Jan 22, 2020 at 6:37 AM
    #5686
    Au1gr
    Au1gr Well-Known Member
    Daniel
    Perth, AUS
    Boys and girls. Can confirm that immob chip removal is no fix. The ecu remains powered as if its on ignition, every time you write a tune or pull the unswitched power, ie disconnect the battery, it requires another key resync. Maybe i got a fucked ecu sent over? Idk. I have another en route so we will see. @asgardengineering found some other examples of denso ecus with the chips pulled out doing random shit also. So we are back to square one as far as a long term solution for the AUDM market. I will say tho, @nd4spdbh ’s shift scheduling is on point. I can see why you blokes are having so much fun
  7. Jan 22, 2020 at 6:56 AM
    #5687
    OVTune
    OVTune Well-Known Member
    OVTune
    I bet you desoldering the immo from your old ecu and putting it on the new one solves everything
    Norton, Torspd and zippsub9 like this.
  8. Jan 22, 2020 at 7:05 AM
    #5688
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Worth a try.
  9. Jan 22, 2020 at 7:37 AM
    #5689
    Au1gr
    Daniel
    Perth, AUS
    Haha yeah that is commitment tho. I dont wanna fuck my oringinal working ecu. I still feel like the obd bridge worked, but there is another drama here. Ima See what i can do/see with techstream in the next 24.
    Automotive locksmiths quoted me like $140usd to sort it if the next ecu does a similar thing. I was hoping i could find a way to bridge the board where the eeprom chip was but i Cant get any deets on the specific way it functions other than it confirms the key code and tells the ecu to press play
    Norton, Torspd and chank like this.
  10. Jan 22, 2020 at 7:46 AM
    #5690
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I wonder if there is a way to remove the Immo functionality completely?
  11. Jan 22, 2020 at 7:56 AM
    #5691
    Au1gr
    Daniel
    Perth, AUS
    Ill pm u
  12. Jan 22, 2020 at 11:29 AM
    #5692
    TacoTuesday94
    TacoTuesday94 Well-Known Member
    Ry
    Huntington Beach CA
    Supercharged 4.0 2010
    Okay so I'm pretty late to the game here. I tried searching through the thread for my specific question but after an hour of searching I've given up trying to comb through 285 pages. Any help would be greatly appreciated and, of course, sorry if this has already been discussed.
    2010 with the Magnuson supercharger and 2.85 pulley.
    I'm currently running the Bully Dog tune.
    How would I go about upgrading to the HP tuner? Can I just install a new tune over the Bully Dog tune? Do I need to bring my truck into a professional tuner or does HPT provide already created tunes that I can just download and install?
    JustDSM likes this.
  13. Jan 22, 2020 at 11:33 AM
    #5693
    JustDSM
    Justin
    Ogden, UT
    You can use the MPVI2 to do a "virtual read" over the BD tune, and extract a virgin copy of the appropriate TRD Tune for your ECU. You can then write that stock TRD tune file back to the ECU as a "Step 1" towards a better tune.
    The next step of that would be to use a tailored tune for your specific setup. That would require you to visit a tuner or some remote tuning assistance.
    HPT does not provide any custom tuning services. They only offer the tools to do the job.
    Norton likes this.
  14. Jan 22, 2020 at 11:36 AM
    #5694
    TacoTuesday94
    Ry
    Huntington Beach CA
    Awesome. Any suggestions for finding a tuning shop. When I called around about a year ago, all the shops said they couldn't and or wouldn't tune toyotas. Did you have to find a HP tuner specific shop?
    Edit: I'm in Huntington Beach CA by the way.
  15. Jan 22, 2020 at 11:40 AM
    #5695
    JustDSM
    Justin
    Ogden, UT
    I do tuning for a number of the folks in this thread. I'd be happy to work with you if you'd like.
  16. Jan 22, 2020 at 11:44 AM
    #5696
    TacoTuesday94
    Ry
    Huntington Beach CA
    I saw your name mentioned in many posts, that would be awesome. I'll send you a PM.
  17. Jan 22, 2020 at 12:18 PM
    #5697
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Don’t let his low key, modest approach fool you. He is exactly what you want, correction NEED. You won’t be disappointed and the real beauty is you could be located on the other side of the planet and he can still take care of you. In addition, @nd4spdbh cam hook you up with pretty nasty tranny tune if you are auto. Both are highly recommended.
  18. Jan 22, 2020 at 12:28 PM
    #5698
    TacoTuesday94
    Ry
    Huntington Beach CA
    Luckily I’m on a manual tranny. But from what I’ve been reading @JustDSM is the man.
  19. Jan 22, 2020 at 12:29 PM
    #5699
    TacoTuesday94
    Ry
    Huntington Beach CA
    Anyone else switch over from Bully Dog that can provide some feedback on switching over to HPT?
  20. Jan 22, 2020 at 12:30 PM
    #5700
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Get in on that rev hang delete goodness and throttle mapping
