HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Jan 27, 2020 at 4:54 PM
    #5761
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    N/A every day (I stay true to my roots.. :crapstorm:)
  2. Jan 27, 2020 at 6:07 PM
    #5762
    o0opackersfano0o
    o0opackersfano0o Well-Known Member
    Tony
    North Berwick, ME
    2005 xrunner swb
    Magnuson supercharger, 2.6 quick change pulley, 76mm throttle body, Doug thorley long tubes, urd y pipe, wot box with 2 step, 170 thermostat, airaid intake, urd short throw, djm 3/4
    Stage 3 snow performance tells you injector duty cycle. Just saying lol
  3. Jan 27, 2020 at 9:10 PM
    #5763
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yup super low on the readings even though its in ms... this is an hpt tuner issue with your cal for sure.
    mightytacoman[QUOTED] likes this.
  4. Jan 28, 2020 at 7:23 AM
    #5764
    nd4spdbh
    SoCal
    looowwwww blow haha.
    TBH Id love something like a newer coyote powered mustang.... or that flatplane 5.2.... DROOOL
    JustDSM likes this.
  5. Jan 28, 2020 at 7:52 AM
    #5765
    JustDSM
    Justin
    Ogden, UT
    It’s a pretty mean machine! I need to scratch the Pony Car itch and I just think the S550 chassis is just all around sexy. Not to mention the song at 7k+ RPM.
    The low end torque leaves a bit to be desired, if I have to be honest. Though o think some of that is to do with the new MT82D4 gearing.
    We’ll see what I can do with HPTuners though. You guys should see the calibration in these things. Wow!
    .. and it fits 305’s on all 4 corners without trimming or cmc! ;)
  6. Jan 28, 2020 at 9:25 AM
    #5766
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Dang. And here I thought this was the only way to clear 35's! You learn something here everyday...
    nd4spdbh and JustDSM[QUOTED] like this.
  7. Jan 28, 2020 at 10:59 AM
    #5767
    Fleabag
    Fleabag Suck it Trebek!
    Uriah
    Vancouver, WA
    2013 Toyota Tacoma TRD Offroad - SSM
    Suspension: SPC Light Racing UCAs Old Man Emu 886 Coils Old Man Emu 90000 Nitrocharger Struts Old Man Emu 60091 Nitrocharger Struts Deaver U402 Stage 3 Leaf Spring Packs Dobinsons Greasable Shackle Bolts Old Man Emu 95PF5 Trim Packer Energy Suspension Bushings Timbren U Bolt Flip Kit And Bumpstops Timbren Front SES Bumpstops Total Chaos Cam Tabs Tires: Pro Comp 87 Series 16's Steel Wheels Goodyear Duratrac 315/75r16 Engine: aFe Cold Air Intake aFe Throttle Body Spacer HyperTech Speedo Calibrator HP Tuner with a JustDSM and nd4spdbh tune file 3° Exhaust Cam Gear from Mightytacoman Peddle Commander Throttle Calibrator Drivetrain: ECGS Front Differential 4.88 gears with Harrop E-locker ECGS Rear Differential 4.88 gears with stock E-locker Tom Wood's One-piece driveshaft Derale Transmission Cooler Derale Thermostatic Switch for fan Mishimoto Fan for transmission cooler Improved Racing Thermostatic Cooler Bypass and filter relocator for transmission cooler Electrical: Eaton RFRM Custom PDM 10 fused relay circuits, 10 fused circuits Feniex 4200 Mini Controller with MeSo Customs mount. LED Bulb Upgrade Front - Rigid D Series Pro - Flood Diffused Rigid D Series Pro - Spot Rough Country Midnight Series 20" single row ARB 9" knockoffs Rear - Rigid D Series Pro - Flood Diffused Communication: Midland MXT275 GMRS Radio Assorted GMRS Handhelds Suburban Assault Armor: MobTown Rock Sliders - Plated MobTown Tail Gate Reinforcement Brute Force Fabrication Plate Front Bumper Brute Force Fabrication HC Dual Swing-out Plate Bumper BAMF Full Skid Set Chaos Fabrication Bed Side Reinforcements Recovery: Superwinch Tigershark 11,500 SR Hi-Lift Extreme 60" Shovel Mattock ActionTrax Recovery Boards Straps & Shackles Exterior: Homertaco Ghost Raptor Grill Alpine Designs Offroad Cab Mount Relocation Brackets Fender Trim Firewall Massage Stubby TRD Antenna Weathertech Window Deflectors Toyota Hood Deflector Soft Tonnaue Cover Color Matched Canopy Custom Aluminium Box on Swingout Modified Bedslide Interior: MeSo Customs Maps Lights and Dome Light ImMrYo Rear View Mirror Relocate Bracket LostSheep's Ram Mount - Mount DynoMat Ram Mount X-Grips and Various Connectors UltraGuage Weathertech Floor Mats Chinesium A/C Knobs Horse Blanket Seat Covers.
    Hello folks, could someone explain the credit situation with this tuner, I am under the impression I need the tuner and 4 credits and I do not understand why, the tuners I have used on motorcycles require a license per VIN. Does this method require the use of a token every upload/download?
    Thanks in advance.
  8. Jan 28, 2020 at 11:03 AM
    #5768
    JustDSM
    Justin
    Ogden, UT
    The credits (the 4 that are required for the Toyota's) are used to license your particular VIN and Calibration ID. Once licensed, you can reflash any ECU with that VIN/Calibraion ID as many times as you like without any additional/future expenses.
    To tune a different combination (VIN/Calibration ID) would require another 4 credits however.
    Hopefully that helps clarify.
    Torspd likes this.
  9. Jan 28, 2020 at 11:05 AM
    #5769
    Fleabag
    Uriah
    Vancouver, WA
    Perfect, thank you!
  10. Jan 28, 2020 at 11:33 AM
    #5770
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Too many oil consumption and reliability issues for me.
    Low-end torque and elevation are the reasons I prefer forced induction over N/A. Your Coyote is probably a better platform from which to start, even if it doesn't sport flat-plane sound and red line.
    Ironically, I prefer my S197 chassis and its 5.8L Trinity powerplant's 733RWHP/713RWTQ over any S550 platform or engine.
    Literally, different strokes for different folks... :cheers:
  11. Jan 28, 2020 at 11:41 AM
    #5771
    OVTune
    OVTune Well-Known Member
    OVTune
    The interior quality of the new Mustangs are worse than my old 2000 Daewoo lanos.
    But that new 5.0 is one hell of an engine. Better than the flat plane
    12TRDTacoma, Torspd, nd4spdbh and 2 others like this.
  12. Jan 29, 2020 at 12:39 AM
    #5772
    asgardengineering
    asgardengineering Well-Known Member
    Sydney, Australia
    Toyota Hilux SR5
    My Toyota ECU crimps are here! Tacoma to Hilux surgery tomorrow to try and sort out the eeprom issues.
    05Taco4x4, nd4spdbh and DesertRatliff like this.
  13. Jan 29, 2020 at 5:32 AM
    #5773
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Exciting! Some real wizardry going on here. I hope this is the path that works for you guys, and then you can share it with the rest.
    nd4spdbh and Turdyota3000 like this.
  14. Jan 29, 2020 at 9:13 AM
    #5774
    dib
    dib Well-Known Member
    Gary
    Escondido, CA
    11 TX Pro
    Camburg LT and Magnuson Supercharger
    What exactly is the Calibration ID? Is that the tune file or something else? The way I interpreted things originally was I needed credits for each time I wanted to flash a new tune file to the ECU.
    JustDSM[QUOTED] likes this.
  15. Jan 29, 2020 at 9:32 AM
    #5775
    JustDSM
    Justin
    Ogden, UT
    You can think about the Cal ID similarly to a version of Microsoft Windows.
    It’s like a version of the operating system used in the ECU.
    Each year, engine, trans, etc. gets a unique Cal ID. So a single part number may be used on multiple vehicle configurations.
    HPTuners uses the credits to license a particular Cal ID and VIN. So should you need to replace an ECU, you can still continue to tune with your original license from HPTuners so long as the new ECU has the same Cal ID, and once you update your “new” ECU with your original VIN.
    1slow4.0 and 12TRDTacoma like this.
  16. Jan 29, 2020 at 9:35 AM
    #5776
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Best of all, @JustDSM updated my junkyard pulled ECU with TRD Tune and put my VIN into it as well. Yesterday, I pulled my original ECU and put in on the shelf to keep for a spare and then swapped in the junkyard ECU without issue and loaded up new tunes off the same HP Tuner device and credits.
    Hawk373, 1slow4.0, nd4spdbh and 2 others like this.
  17. Jan 29, 2020 at 9:48 AM
    #5777
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This was one of my favorite mods of all time actually.
    Turdyota3000 and JustDSM like this.
  18. Jan 29, 2020 at 9:49 AM
    #5778
    dib
    Gary
    Escondido, CA
    11 TX Pro
    Now I get it. Thank you for clearing that up. Not so nervous about the process now.
  19. Jan 29, 2020 at 9:56 AM
    #5779
    nd4spdbh
    SoCal
    come to the darkside grasshoppa!
  20. Jan 29, 2020 at 10:11 AM
    #5780
    ebuyaer2002
    ebuyaer2002 Well-Known Member
    Nate
    Salem, OR
    08 Tacoma TRD OR DCSB 6 Speed
    RC 6" lift, icon coilovers, DK uppers, URD intake, DT Longtube Headers, Cam gears, 70mm throttle body, Custom Tuned with HPTuners
    I was all new to hptuners a few months ago. I read the whole thread and asked a handful of questions. After I got my unit, I had some problems at first, with hptuners not having my calibration. After that was sorted, and I was able to read the ecu, I was able to send it to @JustDSM to work his magic. A few bolt ons and a few tuning tweaks and it's running amazing with way more power across the board. A set of cam gears from @mightytacoman will really top everything off.
