HP Tuners for 2005-2015
Discussion in 'Performance and Tuning' started by Hacktacular, Mar 24, 2019.
  1. Apr 8, 2019 at 7:48 PM
    #561
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    Gotta keep it clean for 76mm Tundra throttle body!
  2. Apr 8, 2019 at 8:04 PM
    #562
    12TRDTacoma
    Rob
    Concordia
    Boosted
    When I switch over to non FPR mod I am going to purchase reflowed TRD style PnP orange injectors to 61lbs or slightly more, no one will ever know they have been modified as there will be no adapters or nothing to indicate they are capable of a higher flow rate.
    Ahhh... the workarounds to California emissions. :D
  3. Apr 8, 2019 at 8:51 PM
    #563
    ThomasMore66
    Dallas/Fort Worth & Durango
    I'm late to this party. That's what happens when you turn off notifications because the phone dings all the time.
    loginfailed likes this.
  4. Apr 8, 2019 at 11:02 PM
    #564
    Roostfactor
    Roostfactor Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Dont subscribe to so many threads silly.
    Norton, 12TRDTacoma and loginfailed like this.
  5. Apr 9, 2019 at 5:31 AM
    #565
    ThomasMore66
    I’m in Dallas. I’m running the TRD flash.
    JustDSM[QUOTED] likes this.
  6. Apr 9, 2019 at 5:39 AM
    #566
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    What size pulley and what intake if any? Headers or stock manifolds?
  7. Apr 9, 2019 at 5:40 AM
    #567
    HPTuners
    HPTuners Well-Known Member
    The big problem with SD tuning on these is like the Tundra (and many other gas Toyota engines), the Tacoma has no MAP sensor or any of the code to easily connect one up and enable it. Unfortunately, Toyota (Denso) follows a similar idea to Bosch and uses pre-compile options to add/remove functionality to the code rather than calibration switches (as GM and others do). Nothing is impossible, but Toyota is very difficult for SD. There may be a way to run Alpha-N (throttle based) using Toyota's load estimation code, but it is also very complex. The good news is the MAF is a simple voltage based thing so transplanting a higher flow one is a bit easier if you know the transfer function.
  8. Apr 9, 2019 at 6:48 AM
    #568
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
  9. Apr 9, 2019 at 7:14 AM
    #569
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    No, I’m going the opposite direction. Stock air cleaner assembly. Making room on the passenger side for other activities.
    JustDSM and 12TRDTacoma like this.
  10. Apr 9, 2019 at 7:20 AM
    #570
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm guessing that if you run the stock air cleaner assembly then you will make tuning adjustments in order to compensate for all the turbulence it causes with a smaller pulley?
    I'd like to be undercover as possible at this point, but as of current the stock air cleaner does not play nice with my 2.3 pulley, unless running the FPR mod is that sensitive to airflow changes.
    JustDSM likes this.
  11. Apr 9, 2019 at 7:26 AM
    #571
    JustDSM
    Justin
    Ogden, UT
    Boost referencing the FPR will not be affected by airflow changes, just pressure change.
    The "need" for boost referencing the FPR in this application as it has been applied was to (correct?):
    1. Richen part throttle
    2. Richen up the truck even further under load for small pulleys
    With HPTuners, you can specify when Power Enrichment is applied. Stock as we've identified is >75% throttle. Lowering the PE engagement point will in itself replace the need for #1 above.
    Using the PE EQ table will allow you to richen set the AFR you wish to run at a given RPM assuming you're above the PE engagement threshold.
    12TRDTacoma[QUOTED] likes this.
  12. Apr 9, 2019 at 7:44 AM
    #572
    ThomasMore66
    2.5”, DT shorties, URD y-pipe, fpr mod, 70mm TB, TRD exhaust, AFE intake.
  13. Apr 9, 2019 at 7:45 AM
    #573
    ThomasMore66
    Weak leg?
    Torspd likes this.
  14. Apr 9, 2019 at 7:45 AM
    #574
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My ultimate goal is to become more "compliant" for CA emissions, that way I have less parts revisions to do come smog time... if I run the OE airbox I eventually throw a code some 20 miles down the road for P0171 and P0174 lean on both banks. Would you be able to correct that with the tuning software?
  15. Apr 9, 2019 at 9:26 AM
    #575
    JustDSM
    Justin
    Ogden, UT
    You’re running the stock TRD supplied ~455cc/min injectors?
  16. Apr 9, 2019 at 10:19 AM
    #576
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes I currently am.
  17. Apr 9, 2019 at 10:46 AM
    #577
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    So you're not worried about running up against the limit of the TRD maf table when tuning?
    loginfailed[QUOTED] likes this.
  18. Apr 9, 2019 at 11:22 AM
    #578
    ThomasMore66
    No FB for me.
    rmepilot, JuanitoBonito and DocME like this.
  19. Apr 9, 2019 at 11:25 AM
    #579
    ThomasMore66
    I'm here. Let me know.
  20. Apr 9, 2019 at 11:30 AM
    #580
    JustDSM
    Justin
    Ogden, UT
    I'm waiting for an update from HPTuners before I proceed with pushing the TRD Calibration base much further. It's coming, I promise. :)
    05Taco4x4 likes this.
